[Update]
Hello BHPians!
This is an update on the oil change after about 7000KMs. I didn't use CeraTec on top of it even though I was planning on adding it. I wanted to have enough time to know the effects of TopTec on the car. Though the effects were apparent just after the oil change, I wanted to make sure that it wasn't just placebo
Also, it takes a bit of time to know the real benefits/nature of the oil after a complete flush.
Car is noticeably quieter, revvs better and a lot of vibrations are gone. Any Laura owner(with a TDi PD Engine) can relate to the subtle vibrations at load conditions in the 1.5k -2k RPM range, these are now gone or hardly detectable. Click-clanks at idle are also quieter - can hardly hear the running engine if somebody is standing at the rear of the car.
I'm pretty happy about the end results. Will be adding CeraTec soon(it is on its way to me as I write this). It'll be interesting to see what CeraTec can do on an already quieter car! Will post an elaborate review on CeraTec because there are a lot of mixed thoughts about the product!
Originally Posted by abhijeetveer Hi,
I just came across this thread. I have used ceratec along with liquimoly synthoil 0w40 after using oil flush and my observations were positive so far. I have been using shell helix ultra 10w40 in my skoda Laura previously but during the last service decided to try liquimoly after reading the reviews on amazon. I have definitely noticed smoother and quite engine after about 100 to 200 kms of running. There is no noticeable difference in average, it's been the same. I get roughly 14 in mixed Mumbai driving. It's been around 3k kms since I've been using it. After reading the thread I believe the top tech liquimoly is the better one. Pls correct me if im wrong. Will try that on my other car next time along with ceratec/molygen |
Originally Posted by saurabhkum I'm little confused on the product line of Liqui moly. There is 5w-40 Tot Tech which is priced at approx 1000 Rs Per Lt. Then we also have 5W-40 Molygen at around 825 Rs Per Lt & Synthoil 0W-30 which is priced at 1400 odd per Lt but gets available as deal price of 900+ Rs per lt. And lastly we have Leichtlauf HC & 5W-40 which is priced at 1250 Per Lt but is available at 960 Rs per Lt under discount. People suggest Top Tech as the best but why? Also Top Tech is mentioned as better for CNG/LPG.
Similar is the case with Liqui Moly Cera Tech friction modifier which is priced as 2250 for 300 Ml and Liqui Moly Molygen Motor Protect which is priced at 3300 Rs for 500 Ml. Can experts comment. |
Hi abhijeetveer & saurabhkum, I've contacted Mr.Khais of Land Rover Labs(From where I bought the oil, they're an exclusive dealer for LiquiMoly & the guy knows what he is doing) and asked about your queries, this was the response I got:
TopTec 4100 is approved by VW AG, that complies with their oil spec VW 505.01 and it's low sub ash engine oil. On the other hand, Molygen is not an OE recommend oil because it comes with performance enhancer tungsten & other additives added to it. Because of that, it doesn't have any OEM approval. Molygen is a good overall oil and it's strictly aimed at performance. Molygen will help in lowering the sounds from engine.
Both Ceratec and Molygen Motor Protect are long time additives. But both of them work in different ways. Company claims that they will work for up to 50K. CeraTec contains micro ceramic compounds. Once its added to the motor oil and the oil reaches the operating temperature, it will stick to metal parts, giving a strong lubricant film that will help overcome the friction forces. This is used in airspace applications to offer longer oil change intervals.
Molygen Motor Protect comes with the same additive as Molygen Oil, Tungsten. It's relatively new, But it can't reach the performance benefits we are getting from CeraTec.
Originally Posted by vignesh.cv For cars from the VW group, please stick to what the manual says in terms of VW oil spec. Going by that the Molygen is VW 505.00 and TopTec is VW 505.01 & VW 505.00. |
Yes! VW AG Cars are extremely sensitive to oil specifications. I have heard horror stories about using wrong oil specs! This is specifically why I went for TopTec 4100 which is of VW Oil Spec rated for TDi PD, VW 505.01.
Originally Posted by saurabhkum How is the oil holding up? Recently I bought it for my Jetta. Yet to get the oil change done. Will share my feedback after few days of running. |
Its holding up pretty good, hope you've read above!
Looking forward to try CeraTec! See you guys soon!
