Old 22nd October 2007, 17:17   #61
adheesh's Avatar
Thanked: 53 Times
Cluch wear can be identified by a soft clutch as well as the increase in the free period travelled by the clutch.
adheesh is offline
Old 23rd October 2007, 12:29   #62
yasw_anth's Avatar
i can feel clutch slip in 1st gear, are these symptoms of a bad clutch plate ? and i get to the mechanic every month to adjust the clutch , it gets loose soo quick,wat can be the problem?
new clutch plate running since 22k kms ..
yasw_anth is offline
Old 31st October 2007, 12:38   #63
Vid6639's Avatar
Thanked: 43,811 Times
Originally Posted by anandtheleo View Post
Hi Vid,
You just described what I experience in my alto sometimes, i have told about it here (http://www.team-bhp.com/forum/techni...tml#post572633)
I raised it as a issue with the MASS when i gave for service last month, but since the issue is not predictable was not able to show a demo for the service manager, they told they will look into it, but the problem persists still. But if you press the clutch immediately after releasing in 1st gear the problem lessens. But I agree its a embarrassing situation to be in. the passengers sometimes think you are a novice driver learning to drive.
Anand.S
Just did some googling on this clutch judder only in the morning or when cold. Came up with interesting info. for this:
On certain mornings condensation will build up on the flywheel for the same reasons that a cold bottle of milk from the fridge will quickly be covered with condensation in a warm humid room. This condensation together with slight wear in the dual-mass flywheel bearing causes the judder. As soon as the flywheel is warm and the clutch friction material is dry the clutch works OK.
So experts, is there any solution to this??
I tried slipping the clutch a little more in the morning and the judder subsided faster than normal.
source:Tyresmoke.Net: Fly wheel and Clutch replacement?
Clutch Judder - Toyota Owners Club - UK Toyota Car Club
Fierce clutch judder
Vid6639 is offline
Old 31st October 2007, 15:26   #64
vnabhi's Avatar
Thanked: 2,403 Times
Originally Posted by kiranpashtakar View Post
Zappo
Does this work on an incline as well, Not too sure since the retardation from the incline will limit the speed and hence stall the engine.
Then you are back to square one you either ride on clutch or the brakes
I too have the same view.
vnabhi is offline
Old 31st October 2007, 16:05   #65
anandtheleo's Avatar
Thanked: 436 Times
Good find there Vid6639, but I have faced this problem even in the blazing afternoon heat here in Chennai as well as in the cool evenings. So for me the quest still continues. But the point googled by you is a interesting one nevertheless.
Anand.S
anandtheleo is offline
Old 1st November 2007, 09:27   #66
Vid6639's Avatar
Anand.S
In which case it could be due to contamination of the clutch fluid as mentioned in one of the links.
In my next service I plan to replace the clutch fluid and bleed the entire system as well as get the slave cylinders checked.
Vid6639 is offline
Old 14th November 2007, 08:33   #67
problem in shifting car into 1st gear!
hello friends.. please help me! i own indica turbo.. 42000 km running..since past couple of days.. i have been facing problem in gear shift.. only 1st gear. when car is standstill..i can put it in first gear .. no problems.. but if car is in motion and i have to shift gear from 2nd to 1st say in traffic .. i cannot.. it just doesnt go.. and i have to actually makecar stand still to put it into gear again. kindly help!
for the moderator..i really have no idea wher i can put this post of mine.. so put it in closest relevance.. thnks
khadoos baby is offline
Old 14th November 2007, 10:41   #68
tsk1979's Avatar
Thanked: 23,010 Times
You need to get the gearbox checked, esp the bushes etc., this does not sound like a clutch problem, but a gearbox related issue. But then I could be wrong. Get it inspected from a good mechanic
tsk1979 is offline
Old 14th November 2007, 11:25   #69
vivek_pinkoo's Avatar
Pleeeeeeeeeeeeease donot put car in 1st while moving. IMHO. How long you have been driving?
vivek_pinkoo is offline
Old 14th November 2007, 13:40   #70
DieselFan's Avatar
Thanked: 259 Times
I think there is no problem in shifting to gear 1 if the speeds are below 10 kmph. In a slow moving traffic (read crawling ) gear 1 driving becomes an absolute must, else one would be riding the clutch on gear 2 (Which is not advisable at all).
DieselFan is offline
Old 14th November 2007, 14:02   #71
Thad E Ginathom's Avatar
Thanked: 28,169 Times
If your engine is labouring in 2nd, you must change down to 1st. While moving. Yes, of course no problem.
Please do not engage reverse gear while the car is moving forwards!!!!!!
Thad E Ginathom is offline
Old 14th November 2007, 20:06   #72
thnks
hey vivek u r from gurgaon.. i m sure u r very well aware of metropolitan peak hour traffic.. and i m sure some times u must b shifting to 1st gear on roads than keeping ur car in 2nd gear and puttin more stress on ur clutch ( practically half clutch driving)... and if u r not... then i think u must start afresh .. erasing ur previous driving style... no offence.. just a reply and frank thought.
hey guysthnks.. i ll chek it rite away and ll get back to u with the problemsolution... thnks
Old 14th November 2007, 23:45   #73
I specifically remember being shouted at by my driving instructor for slipping the clutch in 2nd: "Clutch control in first only"
Thad E Ginathom is offline   (1) Thanks
Old 15th November 2007, 12:55   #74
got it consulted
hey.. i went to tata worskhop and got my car checked.. he told me that clutch plate needs to be changed and also something called as pressure plate too.. bush is fine.. i guess at 42,000 isnt it too early for clutchplate to give way! i own palio,accent and a honda city.. all of them have covered 30,000 + km and none of them suffered this problem.. also he gave me estimate of around 7-8 grands to solvethe prob.. and the local mechanic gave me an estimate of 3-4 k.. damn.. wat a difference.. !
Old 15th November 2007, 13:08   #75
iraghava's Avatar
Thanked: 272 Times
KB - Make sure that when you're replacing the Clutch assembly that you replace Clutch Plate, Pressure Plate & release Bearing at the same time. Using one or more old components to save some money can prove to be much costlier at a later time. It is always advisable to change all 3 components at the same time.
iraghava is offline
