Old 26th December 2015, 23:57   #76
petrolhead_neel's Avatar
Thanked: 1,533 Times
Re: Your car's engine rpm at highway cruising speeds
Car: Ford Classic 1.6 Duratec
80 km/h: 2700 RPM
100 km/h: 2900 RPM
120 km/h: 3100 RPM
*in 5th gear
Does not feel strained at all, with 5 people pn board, AC on full blast and luggage to boot.
Drive safe,
Neel
petrolhead_neel is offline   (1) Thanks
Old 27th December 2015, 16:16   #77
amiya.c's Avatar
Thanked: 129 Times
For Ford Fiesta classic 2012: Post remap it feels relaxed at 120 km/h
5th gear stats:
80 kmph comes at 2000 rpm > Engine begs to be pushed for more
100 kmph comes at 2500 rpm
120 kmph comes at 3000 rpm > It cruises effortlessly but this is the point at which the noise starts to build.
I usually maintain 110 to 120 kmph on National highways for relaxed cruising.
amiya.c is offline   (1) Thanks
Old 28th December 2015, 16:29   #78
Thanked: 172 Times
2015 Hyundai Elite i20 Asta CRDi
100 kmph @ 2050 rpm
120 kmph @ 2500 rpm
This is in 6th gear with the ACC running. Haven't tried going much above these speeds as the engine starts sounding pretty stressed.
I usually try to maintain speeds of 100 - 110 kmph on Highways for relaxed cruising and optimal FE.
phoenixash is offline   (1) Thanks
Old 28th December 2015, 22:42   #79
Thanked: 9 Times
Hi All,
My Swift Vxi VVT :
80 kmph - 2200 RPM
100 kmph - 2750 RPM
120 kmph - 3300 RPM
140 kmph - 3900 RPM
I have not pushed it beyond 140 kmph. However , remember that there was a little more to push at the pedal while cruising at 140 kmph on 5th gear.
SAJEESH is offline   (1) Thanks
Old 29th December 2015, 14:44   #80
Thanked: 1,369 Times
Originally Posted by arjithin View Post
Ertiga Diesel (2012)
80kmph @ 1950 rpm
100 kmph @ 2450 rpm
120 kmph @ 2900-3000 rpm
Feels so noisy after 120 kmph that I don't feel comfortable pushing for cruising
The official review of ertiga says 120 kmph is at 2600 rpm, where as I see it in my car with an additional 400 rpm even with just one driver. I can think of the following reasons for variations in rpm, but none are applicable in my car
1. Non oem size tires
2. Slipping clutch
3. Tacho calibration
But I don't 'understand why the load on car makes a difference in rpm for a given gear and speed? Since the gear ratios are fixed, we should be able to calculate the rpm at which the engine should be if speed is known right? Then how load becomes a parameter?
Having owned the Ertiga before, I find the RPM quoted for 120kmph a bit on the higher side. That said, the factors that influence a certain speed at a certain RPM on the motorway are:
1) Direction of the wind: If you're driving against the draft you'll find that your vehicle reaches the same speed at a slightly higher RPM. On the brighter side, if you're on the same direction of the wind draft, you'll find that the intended speed is achieved at a slightly lower RPM, thanks to the wind pushing you.
2) Even on a visually flat motorway, there's always a slight gradient or slope that influences the rolling resistance. Don't believe me? Try cycling down the road that appears visually flat and you'll get my point. A case in point: while driving to Bangalore, my vehicle is usually at a slighter higher RPM at 120 than it is while coming back and that's because the onward journey to Bangalore from Chennai is a mild uphill all the way through and downhill on the way back.
I cannot get into technical numbers or the engineering side of gear ratios because I have no clue. But these 2 factors have consistently influenced the RPM to speed numbers. These are observations not from one but 3 vehicles that I've driven down the same road umpteen times. This could also be the reason for varying numbers on your Ertiga to the official review as roads in Kerala are seldom flat.
swiftdiesel is offline   (1) Thanks
Old 29th December 2015, 17:53   #81
prithm's Avatar
Thanked: 713 Times
Man.. I am seriously jealous of guys who are reporting 100 @ under 3000 rpm.
Car : DZire Petrol ZXi
Passenger : 1
Gear : 5th
80 : 2700
100 : 3000
120 : 3500
prithm is offline   (1) Thanks
Old 29th December 2015, 18:21   #82
SunnyBoi's Avatar
Thanked: 4,460 Times
Cedia : 2200RPM @ 100KMPH
Palio 1.6 GTX : 2700RPM @ 100KMPH
Both at 5th gear.
SunnyBoi is offline   (1) Thanks
Old 29th December 2015, 22:12   #83
breezydrive's Avatar
Thanked: 131 Times
In my 05 days old S Cross DDIS 320 ; still in run-in period with only 440 km on the odometer till date -
120 kmph @ 2000 rpm - 6th gear
100 kmph @ 1700 rpm - 6th gear
85 kmph @1700 rpm - 5th gear
breezydrive is offline   (3) Thanks
Old 30th December 2015, 09:08   #84
Thanked: 5,534 Times
That is effortless! How does it feel at 100 kph in 6th? Would you shift down to overtake?
extreme_torque is offline
Old 30th December 2015, 10:51   #85
PointZero's Avatar
Thanked: 4,124 Times
Mahindra Bolero M2DICR
80 Kmph @ 1800 rpm
95 Kmph @ 2000 rpm
105 Kmph @ 2200 rpm
PointZero is offline   (2) Thanks
Old 30th December 2015, 22:18   #86
Thanked: 131 Times
Not at all, at 100 kmph, it is effortless. The peak power is available @1750 rpm!
In fact, I slowed down till 65 kmph and it was comfortable to pick it up again effortlessly!
This car masks speed so well ! silently.
Whereas, in my Honda City, the speeds above 100 kmph are actually felt with engine sounding a raspy note after Vtec kicks in.
Last edited by Gannu_1 : 31st December 2015 at 05:54. Reason: ANHC > Honda City. Please avoid using acronyms when referring to cars on the forum. Thanks!
breezydrive is offline   (1) Thanks
Old 31st December 2015, 10:41   #87
J.Ravi
Posts: n/a
My XUV 500 with ACC on and 3 people on board with a lot of luggage in the sixth gear:
100 kmph in cruise control in slightly less than 2,000 rpm.
Old 2nd January 2016, 19:32   #88
Thanked: 9 Times
Passenger : 1
Gear : 5th
80 : 2700
100 : 3000
120 : 3500
Hi prithm,
I think this has to do with the additional weight of your car. (I mean compared to a swift vxi ). Both cars ( vxi and zxi ) share the same engine. My car does 80 at 2200 RPM and 100 kph at exactly 2750 RPM.
Experienced friends may shed some more light here.
Thanks & Regards,
Sajeesh
Old 2nd January 2016, 20:29   #89
Thanked: 1,998 Times
Originally Posted by SAJEESH View Post
Hi prithm,
Thanks & Regards,
Sajeesh
Hi SAJEESH,
If Vxi and Zxi have the same engine and the same gearbox, they will have same engine rpm at given kmph in 5th gear.
If prithm notices higher rpm, he shall check the rpm once again (if he is reading the meter correctly). If the reading is correct prithm needs to check his clutch.
Rahul Bhalgat is offline
Old 2nd January 2016, 20:56   #90
Thanked: 21,450 Times
I am jealous of all owners whose cars have 6-speed gearbox rather than 5-speed that makes cruising more effortless and silent.
I hate my Swift's NVH levels when it at 100 kmph @ 2300 RPM.
