Re: How many KMs before clutch overhaul Quote:
Originally Posted by shancz - will it happen again : yes but expecting longer intervals since the driver is aware of it now |
Nearing 44,000 kms without any issues, almost twice the lifespan of the original clutch assembly which leads me to conclude that a misadjusted clutch was a significant contributor to the premature clutch wear apart from the driver slipping the clutch to build speed as pointed out by Indian2003.
The driving style hasn't changed so it leads me to conclude that the misadjusted clutch was the culprit and not the quality of parts. Quote:
Originally Posted by Indian2003 I dont think quality has gone down. My clutch lasted 345,000 km. |
Sorry to bump after years but I had to update and Thank You again for your patient replies and explainers which made things clear for me.
As mentioned above, I can say that the quality hasn't come down although I can say that whatever the clutch is, I won't ever see those numbers as neither I am that good a driver nor is the traffic getting any better Quote:
Originally Posted by fighterace I suspect that it is a case of defective clutch friction plate or clutch cable or faulty clutch adjustment which caused the problem in your car and the replacement parts will be free of the defects. |
Sorry to bump after years but I had to Thank You again and reaffirm that your diagnosis and conclusion were correct.
I had taken the car to a MASS(Maruti Automobiles, Ranchi) for later services (due to issues with the dealer's workshop(Premsons Motors, Ranchi) and an experienced technician(Mr. Yadav) post a test drive said that the clutch was misadjusted. He parked the car and adjusted it then and there, the clutch felt smoother to engage and took 2-3 days to get used to the new settings. I told him that the clutch was changed ~10,000 kms ago and he said that this set won't last as long as it should but it will still last quite some time. It has been almost twice the distance since the last change and 20,000 kms since I had this conversation.
Reason: adding details
