Old 4th April 2004, 12:34   #1
Thanked: 321,621 Times
The Most Powerful Diesel Engine in the world
Heres some hard facts:
1. Displacement - 14 cylinder 25.48 Million CC (25480000 cc)
2. Maximum Horsepower - 108,920 hp at 102 rpm
3. Maximum Torque - 5,608,312 lb/ft at 102rpm
4. Fuel Consumption - 1660 gallons/6142 liters of diesel per hour
Some Pistons
and Piston Rods
The Piston rod assembly
Heres the entire article
GTO is offline
Old 4th April 2004, 13:19   #2
Rehaan's Avatar
Thanked: 36,075 Times
Hahahaah!! awesome!!
There is a ladder leading into the crankcase!! hahaha..how awesome is that!?!
I wonder if we could shoehorn that into one of these > ;-]
cya
Rehaan
Rehaan is offline
Old 4th April 2004, 13:42   #3
RJK
RJK's Avatar
Thanked: 762 Times
Thts korean if i'm not wrong !
M3
RJK is offline
Old 4th April 2004, 14:17   #4
Rehaan's Avatar
Originally Posted by [b
Quote[/b] (rjkulkarni @ April 04 2004,13:12)]Thts korean if i'm not wrong !
M3
Then it would be overrated by atleast a few thousand bhp ;-]
But the article seems to mention Japan.
cheers
Rehaan
Rehaan is offline
Old 4th April 2004, 17:58   #5
Caterpillar and Vatsila make the powerful diesel industrial engines
toyota is offline
Old 4th April 2004, 18:24   #6
Dude it is Korean. U can make out from their Writings itself.
rgowani is offline
Old 4th April 2004, 21:34   #7
Domnic's Avatar
Heh,
I wonder how they torque the head bolts
Dom
Domnic is offline
Old 4th April 2004, 21:42   #8
aadix's Avatar
Thanked: 17 Times
hmm seen smaller versions of there, the generators in our factory are caterpillars, 1 of them were the aux engine of a old contanier ship, man it is huge!
how are man engines??
aadix is offline
Old 5th April 2004, 12:56   #9
Dippy's Avatar
Thanked: 4,137 Times
Some amazing looking machinery .. Is it in the record books? Hey Rehaan I really doubt shoe horning that engine into one of those you showed above
Dippy is offline
Old 5th April 2004, 13:26   #10
Rehaan's Avatar
Quote[/b] (rgowani @ April 04 2004,17:54)]Dude it is Korean. U can make out from their Writings itself.
"The Aioi Works of Japan's Diesel United, Ltd built the first engines and is where some of these pictures were taken."
Maybe its in a korean ship.
Will try and find out what the banners say.
& Dom, i guess they have a motorized torque wrench (with a viper engine on there . I wonder if 500lb/ft of torque would be enough ?
Cheers,
Rehaan.
Rehaan is offline
Old 5th April 2004, 21:21   #11
Already Caterpillar has bought the Mann
toyota is offline
Old 6th April 2004, 16:49   #12
aadix's Avatar
Thanked: 17 Times
when did caterpillar buy out mann(or man???) engines?
u r taliking abt the german company right, toyota?
aadix is offline
Old 6th April 2004, 19:31   #13
ya , i was working for Caterpillar and by that time itself thay had bought
toyota is offline
Old 29th July 2005, 00:12   #14
karizma_devil's Avatar
Thanked: 21 Times
Worlds Largest N Most Powreful Diesel Engine
The Wartsila-Sulzer RTA96-C turbocharged two-stroke diesel engine is the most powerful and most efficient prime-mover in the world today. The Aioi Works of Japan's Diesel United, Ltd built the first engines.available in 6-14 cylinder versions,all are inline engines.These engines were designed primarily for very large container ships.The cylinder bore is just under 38" and the stroke is just over 98". Each cylinder displaces 111,143 cubic inches (1820 liters) and produces 7780 horsepower. Total displacement comes out to 1,556,002 cubic inches (25,480 liters !!) for the 14 cylinder version.Some facts on the 14 cylinder version:
Total engine weight:2300 tons (The crankshaft alone weighs 300 tons!!)
Length:89 feet
Height: 44 feet
Maximum power: 108,920 hp at 102 rpm
Maximum torque: 5,608,312 lb/ft at 102rpm
Fuel consumption at maximum power is 0.278 lbs per hp per
hour. At maximum economy the engine exceeds 50% thermal efficiency. That is, more than 50% of the energy in the fuel in converted to motion.For comparison, most automotive and small aircraft engines have BSFC figures in the 0.40-0.60 lbs/hp/hr range and 25-30% thermal efficiency range. Even at it's most efficient power setting, the big 14 consumes 1,660 gallons of heavy fuel oil per hour!!!!!The internals of this engine are a bit different than most automotive engines. The top of the connecting rod is not attached directly to the piston.The top of the connecting rod attaches to a "crosshead" which rides in guide channels. A long piston rod then connects the crosshead to the piston.
I assume this is done so the the sideways forces produced by
the connecting rod are absorbed by the crosshead and not by the piston. Those sideways forces are what makes the cylinders in an auto engine get oval-shaped over time.
12CYLINDERS CRANK!
PISTON
karizma_devil is offline
Old 29th July 2005, 00:17   #15
now lets put this damn thing under one of my car bonnets - and blast into space ...hehehe
cream is offline
