Old 17th March 2004, 16:42   #1
Rehaan's Avatar
Thanked: 36,071 Times
A lesson in acceleration:
First, some useful info:
* One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower
than the first 4 rows at the Daytona 500.
* Under full throttle, a Top Fuel dragster engine consumes 1½ gallons of
nitromethane per second; a fully loaded 747 consumes jet fuel at the same
rate with 25% less energy being produced.
* A stock Dodge 426 Hemi V8 engine cannot produce enough power to drive the
dragster's supercharger.
* With 3000 CFM of air being rammed in by the supercharger on overdrive, the
fuel mixture is compressed into a near-solid form before ignition. Cylinders
run on the verge of hydraulic lock at full throttle.
* At the stoichiometric 1.7:1 air/fuel mixture for nitromethane the flame
front temperature measures 7050 degrees F.
* Nitromethane burns yellow. The spectacular white flame seen above the
stacks at night is raw burning hydrogen, dissociated from atmospheric water
vapor by the searing exhaust gases.
* Dual magnetos supply 44 amps to each spark plug. This is the output of an
arc welder in each cylinder.
* Spark plug electrodes are totally consumed during a pass. After 1/2 way,
the engine is dieseling from compression plus the glow of exhaust valves at
1400 degrees F. The engine can only be shut down by cutting the fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds up in
the affected cylinders and then explodes with sufficient force to blow
cylinder heads off the block in pieces or split the block in half.
* In order to exceed 300 mph in 4.5 seconds dragsters must accelerate at an
average of over 4G's. In order to reach 200 mph well before half-track, the
launch acceleration approaches 8G's.
* Dragsters reach over 300 miles per hour before you have completed reading
this sentence.
* Top Fuel Engines turn approximately 540 revolutions from light to light!
* Including the burnout the engine must only survive 900 revolutions under
load.
* The red-line is actually quite high at 9500 rpm.
* The Bottom Line; Assuming all the equipment is paid off, the crew worked
for free, and for once NOTHING BLOWS UP, each run costs an estimated
$1,000.00 per second. The current Top Fuel dragster elapsed time record is
4.441 seconds for the quarter mile (10/05/03, Tony Schumacher). The top
speed record is 333.00 mph (533 km/h) as measured over the last 66' of the
run (09/28/03 Doug Kalitta).
-Unknown Source.
Rehaan is offline   (1) Thanks
Old 17th March 2004, 17:27   #2
Shan2nu's Avatar
Thanked: 127 Times
At 533kmph that car would have completed the 1/4 mile in around 4.2 secs. That's really awesome.
BTW, do you think using launch control on one of these might help?
Regards...
Shan2nu
Shan2nu is offline
Old 17th March 2004, 20:24   #3
Umm Shantanu Its 533 Km/h Dude not m/h. I think they already have Lauch Control dont they?
rgowani is offline
Old 18th March 2004, 05:43   #4
Rehaan's Avatar
Also correct me if i am wrong, but dragsters dont have clutches!
It would just be waste of time as well as clutches just wouldnt be able to hande that kinda immediate power!
cya
Rehaan is offline
Old 19th January 2005, 17:30   #5
Psycho's Avatar
Thanked: 111 Times
cya
Was going through the old posts when I came across this and thought that I would correct you on the last statement
Pro Fuel Dragsters use a progressive clutch that is controlled by an air-timer management system. This locks up the clutch beyond a certain RPM. This is required to let the engine idle...
Psycho is offline
Old 19th January 2005, 19:08   #6
shravan316's Avatar
Mindboggling facts!! really cool stuff guys!
shravan316 is offline
Old 20th January 2005, 01:18   #7
oh man i just drank a glass of water!
joel is offline
Old 20th January 2005, 03:24   #8
Rehaan's Avatar
Hey Psycho,
Thanks for that info....
I guess i would rephrase what i was saying to "dragsters dont use the clutch when shifting between gears as the clutch wouldnt be able to handle the power at higher RPMs"....correct?
R
Rehaan is offline
Old 20th January 2005, 11:18   #9
Tom
Tom's Avatar
lock up clutches and air-shifters?
Tom is offline
Old 20th January 2005, 11:46   #10
Psycho's Avatar
Thanked: 111 Times
Top fuel dragsters & the funny cars usually only have a forward and reverse gear as the reverse gear is mandatory in most classes.
At the RPM's with the given torque these engines go to it is impossible to shift gears (Imagine trying to shift gears on a 6000 bhp engine on full power) hence they do not have gearboxes rather the clutch handles the complete load directly to the wheels.
Maybe the best way to define the power is locking your car's to the 4th gear and running a drag on that.(as it results in close to a 1:1 ratio to the wheel assuming that your differential is also a 1:1)
Psycho is offline
