Hello BHPians,
I am posting this on behalf of a very close friend of mine, he needs urgent help on his 2010 pre-worshipped Landrover FreeLander 2. The vehicle has clocked close to 1 Lac Km till date and had served its purpose to the best of its capabilities.
Currently the vehicle is at Inline 4 Motors, Hyderabad due to power steering fluid and crankshaft sensor issue. After a brief examination the full repair estimate quoted by the service centre is a whopping 5 Lacs (appx.) which raised a question over the reliability of this service centre and the vehicle as well. He is looking for expert advice and needs some suggestions.
A Brief description of the problem:
In recent times, the vehicle had been visiting service centre very frequently due to some sudden stalling (while running), arbitrary warning messages on board: reads
Reduced Engine Performance, starting problem etc. During a recent drive from Hyderabad to Guntur, the vehicle had some sudden loss of power, and stalled. Luckily we're able to pull over to a safe place from the middle of the national highway around 6:30 PM, had to flat-bed it back to service station.
The Service centre people say they had cleaned all components and refilled the necessary fluids and everything should be fine. Once the vehicle is being used, any of these ugly problems come up from middle of nowhere causing a nightmare.
On insisting for a proper examination, they charged a premium for investigating and had come up with a shocking problem and two solutions. A temporary fix and a permanent fix, of which the estimated cost for the latter was shocking 5 Lacs appx.
They say the problem is with power steering fluid of the vehicle. A pipe section which circulates this power fluid seems to contain some tiny metal particles, thereby causing a blockage to the pipe section. This blockage further causes a pressure and this built up pressure causes some leakage. Concerning the power fluid, the leakage is happening at a very slow pace, so they were refilling it for every two months by 50 ml. Till here, issue seems to be small.
However, this leaking fluid is dropping onto a crankshaft sensor which controls the fuel indicators etc. Due to this the vehicle suffers lack of power, sudden stalling, malfunctioning of dashboard messages etc.
Inline Motors had provided a couple of solutions for him, out of which the partial one involves replacing of Power steering pump, pipes, Censor - Crank shaft position (CPS). Estimated to ~2 lacs. The permanent solution involves steering rack, steering assembly and EGR cooler etc. and many others to be replaced. Attached the partial and Full repair costs.
Now, his concerns are:
- Is there any other way to get this pipe section cleaned?
- How good is it to trust these guys and to invest so much money on a 1 Lac Km old engine? Worried about the reliability of vehicle as well!!
- The Current IDV Value stands at around 25 Lacs, is it better to sell it off and buy something else?
Having a little knowledge on the engine bay components, we weren't able to judge the necessity of the replacements suggested by them. We wish there could be some help. I will try to get some more information from SA and will update the thread with a more detailed description on the problem.
