Old 30th November 2014, 00:43   #1
Thanked: 116 Times
Spraying the underbody with used engine oil
I gave my car ( fiat Petra) for full servicing at servicing station at a fuel bunk
They do servicing of cars since a very long time
They had cleaned the car very well. The engine bay and underbody was spanking new. AC for some reason cooled rather well after servicing and car felt more responsive (air and fuel filters were changed or cleaned)
They had also sprayed the underbody with used engine oil.
Anybody knows how does this help? Does it help with underbody not catching rust?
I read somewhere else that rubber components of suspension get bloated as they absorb oil and later on crack. How true is this?
Basically does spraying of this used engine oil have any advantages or it's harmful for suspension components?
rikhav is offline
Old 30th November 2014, 01:07   #2
D C
D C's Avatar
Thanked: 336 Times
Re: Spraying the underbody with used engine oil
As per various internet sources, this is widely used to prevent rust. It seems to be a short term solution and are mostly used in commercial vehicles / off road vehicles or old generation cars.
D C is offline   (1) Thanks
Old 30th November 2014, 16:01   #3
khoj's Avatar
Thanked: 1,288 Times
The Ac worked better as the washed condenser rid of various debris and dirt would lead to better heat exchange.
Yes the rubber components will suffer on account of being sprayed with degraded oil.
There is no advantage to be accrued from this archaic practice which only tuns the underbody in to a dirt magnet.
In the past the untreated underbody components and the chassis itself were prone to rusting and this was a quick temporary fix.
Today's vehicles chassis and body shell even for the cheapest ones undergo phosphating, a process the seals the metal against rust and chemical fall out.
So effective is this treatment that it renders the need for any sort of underbody coating useless, including the ones offered by the modern car spas and dealerships what to talk about used oil spray.
khoj is offline   (4) Thanks
Old 30th November 2014, 19:28   #4
adrian's Avatar
Thanked: 1,273 Times
We used to spray engine oil mixed with diesel on the underbody of our Ambassador after water service, the main intention being to repel water and reduce the rust build up rate. So far we have not noticed any adverse effects on the rubber parts or the suspension components apart from the fact that they accumulate lots of dust. I also don't feel it is relevant in modern cars with treated panels.
regards adrian
adrian is offline   (1) Thanks
Old 30th November 2014, 21:01   #5
Thanked: 116 Times
Thanks a lot all of you
AC works so well that I am surprised FIAT air conditioning system works so well. I used to service my car at a nearby Hyundai authorized service centra after anuroop auto shut shop
Never ever cleaning has made such a marked difference. That means these company service centres never bother to clean parts like condenser thoroughly. Even underbody is very clean
regards adrian
So the spraying has no use per say. Very true that it will attract lot of dust and maybe in long run affect rubber parts
So I will continue with service and tell them strictly not to spray the underbody with oil
Anybody interested, I am discussing about the BP pump few buildings before Andheri shoppers stop
rikhav is offline
Old 30th November 2014, 21:24   #6
Mr.Boss's Avatar
Thanked: 7,585 Times
It's usually Engine oil + Diesel solution. People do believe spraying this solution after water wash should act as a water repellent and prevent from rusting. As explained by other members it will become a dirt magnet instead. Oil + Diesel will make the suspension (rubber) bushes characteristics deteriorate (by making them hard / brittle)
PS: there are possibilities that warranty claim of suspension bushes getting rejected when the trace of oil found on them.
That's a safe bet.
Mr.Boss is offline   (1) Thanks
Old 30th November 2014, 23:09   #7
Thanked: 116 Times
That's a safe bet.
Mr. Boss
No worries about warranty as its ten year old car
rikhav is offline
Old 1st December 2014, 08:54   #8
Mr.Boss's Avatar
I'm not particular about your car buddy. Shared this info for the benefit of fellow members whose car is still under warranty.
Old 1st December 2014, 15:11   #9
thoma's Avatar
Thanked: 1,486 Times
I thought used oil should be disposed with care, now it is being carelessly mixed with dust and next time washed down the drain polluting the environment.
thoma is offline   (2) Thanks
Old 1st December 2014, 16:44   #10
soumobakshi's Avatar
Thanked: 1,439 Times
Yes, its is illegal to dispose Burnt Engine oil this way. And most of the time this will be done by operators and they will also claim that the entire process is illegal.
This is from my experience in Calcutta a while back. Net off this might be OK for non phosphate coated under-bodies but is strictly not required for modern vehicles.
soumobakshi is offline   (1) Thanks
Old 1st December 2014, 20:39   #11
Thanked: 116 Times
They don't even ask customers if they want the car underbody sprayed with oil
They are bit of old school, typical of fuel stations like checking engine oil is at optimum temperature
I can't make them stop using used oil for other cars but I will make it a point they don't for my car. Apart from this cleaning and servicing is very good
rikhav is offline
