Brake Shoe Adjuster Broken! Hi,
I was reversing my car out of my driveway in the morning when I suddenly heard something stuck as if the car had collided with something. I got down and inspected , the car was clear on all sides. I checked under the car but all clear. I put the car in forward drove a few inches and then reversed and there was no problem.
Then i drove all day as usual and everything was uneventful.
While coming back in the evening, I applied the brakes in some traffic and heard some kind of noise in the rear of the car and the rear right wheel got jammed. I somehow parked in the side and inspected, couldn't find anything.
Then I put the car in reverse and moved a few feet and drove the car forward it could be moved properly, but I heard some continuous noise in the rear right wheel. As if there is something in the drum, I realised something has broken in the drum. I was very close to home so I slowly reached home.
I took the car to Mahindra service near my home and they opened the drum and found that the brake adjuster had broken.
I have been advised to not use the vehicle until it is replaced. Nor do I want to take any risks. I talked to the service supervisor at Oberoi Fiat Noida. He advised me to get the brake fluid line blocked for that side and not use the car . The part is out of stock at Fiat's dealership at Noida and may take a few days.
The Mahindra guys insisted that blocking the line may confuse ABS sensors and further complication could occur. I simply drove very slowly and have parked the car until the part arrives.
Now I have a few questions.
1. How and what could be the reasons for brake adjuster to break?
2. What were the risks that I had driven the car even after its failure?
3. Could it have been very dangerous as the broken part could have got stuck and jammed the wheel while at high speed given that my drive is on Noida expressway?
4. What are the implications of driving the car after removing the Adjuster? (Not that I want to or I will)
5. What is the best best emergency procedure to follow in such situations?
6. To get the lines blocked or not?
7. Shouldn't a critical part like this be always in stock (It must not be a very costly part after all)
Thanks.
Reason: Typos
