Old 31st May 2023, 18:55   #946
maglev's Avatar
Thanked: 157 Times
Re: VCDS (Vag-Com Diagnostic System) for VW & Skoda - Discussion Thread
MotoScan Chennai - Hex v2 Cable + Software
Would this cable support long coding/ adaptations, etc.? Their description only mentions soft coding.
They're offering instruction manuals and support for installing/ running the vcds software. I am tempted to buy.
maglev is offline
Old 31st May 2023, 19:31   #947
eagle_bush's Avatar
Thanked: 58 Times
This is the one I have. It does support long coding. For MQB cars, Ross Tech doesn’t have all the secure access codes I believe.
eagle_bush is offline
Old 31st May 2023, 21:58   #948
maglev's Avatar
Thanked: 157 Times
Its a series of adaptations…
If I recall correctly, BHPian AudioHolic is using Hex v2 & VCDS for coding his Slavia, and if that’s the case then maybe they’ve managed to get the secure access codes.
maglev is offline
Old 31st May 2023, 22:03   #949
Thanked: 21,217 Times
It works for most of the controllers and functions as far as my experience goes. But this is in Slavia. I was not able to run VCDS 21.9/22.3 on a colleagues Virtus since it is not able to read the VIN number.
audioholic is offline
Old 7th June 2023, 13:11   #950
HMV
HMV's Avatar
Thanked: 111 Times
Originally Posted by teja030 View Post
Could there be any real difference between both these VCDS cables except for the price? I am looking for one for my VW Vento TSI 2022. Suggestions would be helpful.
Hi, were you able to get one from AliExpress? If yes, do they work with 2020+ Ventos?
HMV is offline
Old 7th June 2023, 21:53   #951
maglev's Avatar
Thanked: 157 Times
I bought this VCDS Hex V2 cable from MotoScan on Sat, June 03, 2023, it was delivered today, unfortunately, the CD accompanying the cable is corrupt and unreadable.
Is there any workaround? downloading the software from Ross Tech website would probably lock the cable making it useless.
Any suggestions? (Apart from contacting seller and asking for another copy, as I am trying to do this.)
maglev is offline   (1) Thanks
Old 7th June 2023, 23:39   #952
eagle_bush's Avatar
Thanked: 58 Times
Which version is the cable for? If it is for 22.3 I can help. Most important is the loader. You can still download VCDS from Ross Tech
Old 8th June 2023, 00:04   #953
maglev's Avatar
Thanked: 157 Times
It might sound silly, but I am not sure, is there a way to check?
In terms of Software Version, I was told VCDS V23.3
Attaching a pic of the cable for reference.
Would it be okay to download the latest version from RossTech’s website, disconnect wifi, and then use the cable?
VCDS (Vag-Com Diagnostic System) for VW & Skoda - Discussion Thread-vcds-cable.jpg
maglev is offline
Old 8th June 2023, 01:30   #954
teja030's Avatar
Thanked: 57 Times
Hi, I've decided to buy an original VCDS Hex-V2 cable directly from RossTech USA when I need one. I felt safe to avoid the duplicate to avoid any hassles arising out of it later on. Hence, I've stopped trying with the vendors from Ali Express. My plan is to ask a friend to get it from the US when he visits India. For now, I am hunting locally for a genuine VCDS Hex-V2 cable to get my Steering Angle Sensor calibrated on my 2022 VW Vento .
teja030 is offline   (1) Thanks
Old 8th June 2023, 19:03   #955
maglev's Avatar
Thanked: 157 Times
The seller shared a link, my VCDS version is 21.9, will install and check later today.
I am still clueless about the loader though...
maglev is offline
Old 8th June 2023, 20:41   #956
21.9 is the most stable version for my car however didnt work with a colleagues Virtus. I updated to 23.3 and realised that many coding flags are no longer displayed correctly and instead represented as ‘TNFxxxxxx’. Even the long coding of Auto HVAC and Instruments are no longer shown correctly hence I had to revert to 21.9.
Old 8th June 2023, 22:15   #957
eagle_bush's Avatar
Thanked: 58 Times
I would recommend the below steps:
1. Install VCDS
2. Install the VII Plus Loader
3. Map the VCDS executable to the loader The loader should be able to identify automatically.
4. Launch the loader while your cable is connected
5. Cable firmware would be updated.
6. Launch VCDS through the loader.
You should be able to get VCDS to work correctly.
These steps helped me. Please try and let us know if these worked for you.
eagle_bush is offline   (1) Thanks
Old 9th June 2023, 11:51   #958
maglev's Avatar
Thanked: 157 Times
1. Install VCDS
Received 4 files, but VII_Plus_Loader .rar is not opening as its infected, and windows defender is only allowing deleting it.
Was able to install VCDS, License Status: Valid / Activated -- Unlimited VINs
Do I still need the Loader?
Changes made (through adaptation menu in Instruments):
- Kushaq: successfully removed 80 & 120 KMPH speed alerts
- Jetta: Activated refuel quantity and oil temperature, they show in cluster, but do not work.
Am I on the right path or am I missing something?
VCDS (Vag-Com Diagnostic System) for VW & Skoda - Discussion Thread-vcds-image.jpg
maglev is offline
Old 9th June 2023, 11:56   #959
eagle_bush's Avatar
Thanked: 58 Times
If you are able to get security access to the modules, you should be ok. Security Access for Engine and instruments modules didn’t work for me without the loader.
Have you tried refuelling post enabling the feature on the Jetta?
My error attached
VCDS (Vag-Com Diagnostic System) for VW & Skoda - Discussion Thread-img_5422.jpeg
Old 9th June 2023, 13:19   #960
My error attached
For me it worked with 23.3 and 21.9 but not with 22.3. 31347 works for the BCM.
@Maglev I am not sure how it worked for you without the loader. For me without the loader VCDS doesnt even recognise the interface.
