Old 28th April 2022, 13:45   #841
Thanked: 37 Times
Re: VCDS (Vag-Com Diagnostic System) for VW & Skoda - Discussion Thread
Originally Posted by durvient View Post
It can only be done by chatting with the seller and agreeing with an "off" aliexpress transaction through PayPal. Most sellers do not get involved however some having experienced of selling on other platform agrees. Such sellers generally have a Skype account as well to chat without leaving traces on aliexpress.
Can you share the contact info of this seller?
codwapeace is offline
Old 28th April 2022, 13:47   #842
Thanked: 37 Times
He has a 2019 Polo as I’ve mentioned in the previous post. Do have a chat with the seller and check.
Do you have the contact info of this seller? Paypal email/skype/anything
Old 28th April 2022, 15:14   #843
Thanked: 56 Times
There is no specific seller, you need to trigger communication with all the sellers to try your luck.
durvient is offline   (1) Thanks
Old 28th April 2022, 16:07   #844
Styler's Avatar
Thanked: 806 Times
As it is not possible to buy Hex Ver2 Cables from Aliexpress, I looked at ebay.com US and found this.
The title says "AUB-Cable For VAG-COM VCDS Scanner Tool OBD2 II KKL FTDI 409.1 VW Audi Ross Tech"
I'm not sure it will work with VCDS as it is not a HEX Canble.
https://www.ebay.com/itm/393981383721
This ships from China to India, so I paid through paypal and ordered it. It's worth taking a $10 risk I guess
Styler is offline
Old 30th April 2022, 14:33   #845
Thanked: 37 Times
I think it is only a reader, i.e., It cannot write to the car.
Old 1st May 2022, 09:21   #846
Originally Posted by mtnrajdeep View Post
Got my Ross-Tech cable recently and was trying to make some changes to my Ameo. Would this help? Many of the modules here are not coded and no details are available even in the latest version of the Ross-Tech software.
Attachment 1620231
However, there seems to be some difference in the modules used in Ameo - was trying to activate the accoustic confirmation on locking but wasn't able to get it working. I saw many references to Terminal 15 when looking at the Alarm options - Does anyone know what Terminal 15 is?
Does the acoustic confirmation option work in the Ameo?
Where can I get Ross-Tech cable? Also, do you know anyone who can help with coding in Banglore?
nusta_throttle is offline
Old 15th May 2022, 23:01   #847
Hi Fellow BHPians,
Hopefully, I will get my Taigun next week and am excited to do my first coding. Anyone has VCDS cable/OBDEleven in Pune, which works with 2022 VAG vehicles?
Any source to get VCDS cable in India?
theexpert is offline
Old 16th May 2022, 12:00   #848
Thanked: 37 Times
Originally Posted by theexpert View Post
Hi Fellow BHPians,
I have an OBDeleven that I no longer need only a week old. I can help you out. PM me.
codwapeace is offline   (1) Thanks
Old 16th May 2022, 19:03   #849
Thanks, codwapeace. I don't have PM privileges yet, can you please PM/email me? Thanks
Old 28th May 2022, 18:59   #850
Thanked: 237 Times
Originally Posted by Tanveer_2558 View Post
Was at AVS tuning today, And tried the following with the Original ross tech cable, But unfortunately did not work with my Jetta 2014, The system accepted the new coding, Both 95 and 99, But none of them worked to autofold the mirrors,
I recently bought a VW Jetta and was tinkering with VCDS. The said 95 and 99 coding works with only LHD cars. For our Jetta's its adaption channel "ENG109285-System_Parameter_14" change the first bit which reads E0 to E5(open with ignition) or E9 (open when driver door is opened). It's working on my 2014 Jetta Highline.
Hope it helps
duker2997 is offline   (2) Thanks
Old 29th May 2022, 20:25   #851
Thanked: 130 Times
Hi Fellow BHPians,
Get OBDEleven Pro (black version). It is the next best thing to VCDS. There is an ultimate version which is an yearly subscription model cost just over ₹10k; but worth every penny. I am using one and hence suggesting the same. Suggest you not to get the white model as it is the older version.
livelyyoungman is offline   (1) Thanks
Old 29th May 2022, 20:52   #852
Thank you for your suggestion. I am also looking at VAS 50454A which works with ODIS.
Old 30th May 2022, 08:42   #853
ssjr0498's Avatar
Thanked: 690 Times
So, I checked on the VAS and there seems to be a newer model 6154 which is in the market! Now there is a confusion on which I need the experts to comment! If accessibility to the devices are no issue, which one would you guys suggest, the vcds (ross-tech) or this VAS 6154/5054A?
Thanks in advance!
ssjr0498 is offline
Old 3rd June 2022, 08:43   #854
Hey Nusta! Any luck on this? I'm looking to get the following mods on my 2011 Vento TDi Comfortline:
Enable reverse camera on the radio module as I retrofit an RCD340G (the whole ISO to quadlock and everything) and the camera doesn't seem to work
Enable tearwipe
Increase lane change indicator to 5
Antitheft if possible for the 2011 model
Autolock post 15km/h
Needle sweep on startup
@Sen I would be immensely grateful if you would be able to lend me a hand with this if you're still in Bangalore
D3MON130 is offline
Old 11th June 2022, 21:29   #855
Enable tearwipe
Hey, D3MON130, I have an OBDeleven device (Gen2) and got a pro subscription just to do a Throttle Body Alignment for my vehicle. I tried a few other settings too, like changing parking assist volume, etc.
BTW my vehicle is old and doesn't have many features to play around.
I might be able to help you with the mods you mentioned.
TheTurboGuy is offline
