Old 14th July 2016, 14:49   #406
Abhi_rx's Avatar
Re: VCDS (Vag-Com Diagnostic System) for VW & Skoda - Discussion Thread
Originally Posted by rpunwani View Post
After fitting a new left rear sensor (approx. Rs. 4000) and cleaning the back side of the disc the Technician has to reset all faults. Then you should check what faults reappear.
I have had both rear ABS sensors replaced on my Passat and it is not rare for the abs sensor to conk out. Many car owners have experienced the same.
Good luck !
Will try doing this one more time as suggested. Thank you!
Abhi_rx is offline
Old 14th July 2016, 16:35   #407
Thanked: 22 Times
Originally Posted by nitinbose View Post
Hi Everyone,
Just a quick question on the counterfeit VCDS cables. I keep hearing from various sources that these cables can adversely affect your car as it may mess up with the coding or damage some modules.
Anybody heard of this?
Never heard of this one. I am using one my self without any issues.
The cable will only do what you tell it to. Doesnt matter whether it is original or fake.
Mitz is offline
Old 6th August 2016, 15:01   #408
cooljai's Avatar
Thanked: 28 Times
Just bought a Skoda Rapid TDI AT, and thinking of buying a VCDS cable from aliexpress.
Can see that there are primarily two models available, the 12.12 version and the 15.7 version.
Can someone tell me if there are any major features that are only available on the 15.7?
cooljai is offline
Old 6th August 2016, 15:42   #409
newtonMeter's Avatar
Thanked: 414 Times
15.7 will have updated library files recommend for newer modules. I recommend u buy 15.7
newtonMeter is offline   (1) Thanks
Old 7th August 2016, 00:21   #410
Tanveer_2558's Avatar
Thanked: 3,381 Times
Get the 15.7 version please, You would be able to access a lot more compared to a 12.12 version, Ask the seller to check the cable before he sends though.
Tanveer_2558 is offline   (1) Thanks
Old 7th August 2016, 12:49   #411
manas27587's Avatar
Thanked: 81 Times
Any trustable links?
manas27587 is offline
Old 7th August 2016, 13:11   #412
After ross tech took some legal action against the seller's on aliexpress, The sellers aren't keeping the listing activated, Every time i ordered too, A link was messaged by the seller, I bought it and as soon as i have paid for it the link is removed, Got the product on time and in working condition too.
Old 8th August 2016, 14:32   #413
unknown's Avatar
Thanked: 23 Times
HI everyone, I bought the cable from aliexpress but cd that it came with it that doesn't work, so could you tell me where to get the working software for this cable ?
Looking for your support !
unknown is offline
Old 8th August 2016, 14:36   #414
Thanked: 414 Times
What is not working?
Old 8th August 2016, 14:40   #415
unknown's Avatar
Thanked: 23 Times
The cd that came with cable doesn't work, so I need software for 12.x variant cable.
PS : Any seller link/contact for buying 15.7 cable as all links are removed on aliexpress.
unknown is offline
Old 8th August 2016, 15:09   #416
graaja's Avatar
Thanked: 25,620 Times
What is the exact version of your cable? I think you should get the exact version of software. If the cable is 12.12, then you have to get 12.12 version.
graaja is online now   (1) Thanks
Old 8th August 2016, 15:14   #417
Thanked: 414 Times
i have 12.x and 15.x installers.. let me know. you can come over and take them if you are in gurgaon. or any other way?
Old 8th August 2016, 15:14   #418
unknown's Avatar
Thanked: 23 Times
Version is VAG COM 12.12.0, could you tell me where to download it from ? I tried from ross tech sit but it wont work as cable not being genuine.Thanks for the Info.
Could you upload the software on net if you could ? Thanks for your help !
unknown is offline
Old 9th August 2016, 10:53   #419
Thanked: 115 Times
I also need link for 12.x version software. Any help will be appreciated.
saurabhkum is offline   (1) Thanks
Old 9th August 2016, 11:24   #420
Thanked: 414 Times
Here is the link to 12.12.0
https://www.hidrive.strato.com/lnk/B9CVpoHe
newtonMeter is offline   (3) Thanks
