Kulkarni Motors The riveting story continues...
A friend needed the car as his Octavia started leaking coolant and was taken to Kulkarni motors, Vimannagar. This meant I had to get the door trim (that has been in the boot) fitted. So we decided to meet at Kulkarni and ask them to fit the door trim for now, as well as check their readiness to remove and install the rivets (and also their setup for denting painting). Their guy took a look at the rivets and said these are too big for their tool to handle! He said he can remove those properly with a drill, but can not install new ones. The riveting tool they have can only install smaller rivets...
Anyway, asked them to fit the door trim, they did in 5 minutes, but then I found the left front door speakers are not working! Not sure if this is caused by the actual impact on the door or happened during removal of the door trim. Kulkarni guy told me the connection looks OK,and next thing will be to check using s/w and then remove the rivets and open the door assembly. Good to know they have VAGCOM or something equal. Now the question is - are the speakers and music system really controlled and "sanity checked" by ECU? Well, anything is possible with Germans, but seems unlikely.
Friend needed the car so we decided to debug this later.
I did some more search about rivets and found this:
Strange that such a simple riveting tool is so rare to find in Pune!
The guy kept telling me these are pop rivets. Here is what I learned about POP rivets from wiki: Blind rivets, commonly referred to as "pop" rivets (POP is the brand name of the original manufacturer, now owned by Stanley Engineered Fastening, a division of Stanley Black & Decker) are tubular and are supplied with a mandrel through the center. The rivet assembly is inserted into a hole drilled through the parts to be joined and a specially designed tool is used to draw the mandrel into the rivet. This expands the blind end of the rivet and then the mandrel snaps off. These types of blind rivets have non-locking mandrels and are sometimes avoided for critical structural joints because the mandrels may fall out, due to vibration or other reasons, leaving a hollow rivet that has a significantly lower load carrying capability than solid rivets. Furthermore, because of the mandrel they are more prone to failure from corrosion and vibration. Unlike solid rivets, blind rivets can be inserted and fully installed in a joint from only one side of a part or structure, "blind" to the opposite side
Ref: http://en.wikipedia.org/wiki/Rivet
Another good explanation on blind rivets (the small animation image in this is really helpful): http://www.aboveboardelectronics.com...advantages.htm
Also found this company that makes rivets and tool in India: http://www.rivetsindia.co.in/riveting-tools.html
Note: I visited Kulkarni because of the incident with my friend's car. I have noted down all other references that fellow members have provided and will check them out soon.
In the meanwhile, any clue on what could be the problem with front left speakers? (I checked the Balance and Fader settings. both left and right rear speakers work fine, so do the front right speakers).
