Ranjan Gupta - a justifiably disgruntled Range Rover owner - shares the following unfortunate ownership experience.
• March 2012: Bought the Range Rover Vogue SE for ~2 crore rupees.
• In 2 years of ownership, the SUV has been with the dealer for about 10 months.
• JLR India, on various occasions, has failed even to accept & diagnose problems with the vehicle...adopting trial & error methods. Due to this, the vehicle had to be taken repeatedly for the same repairs to Dada Motors, Ludhiana. Do note that the owner's residence is 140 kms away from the dealership!
• The car was originally delivered, with two different brands of tyres!
• As of date, the Range Rover suffers from starting problems. Various parts have been changed, but JLR hasn't been able to solve it. The car is currently lying at the dealership since 13th March 2014 for the same problem. They replaced the starter motor, but the issue still persists.
• Ranjan Gupta asked for a loaner vehicle as no timeline was provided for the repairs, but was refused.
• The Vogue met with a frontal accident. It took Jaguar Land Rover's dealer SEVEN months to repair the SUV.
• Ranjan says that no one is responding to his phone calls. He's worried about the upkeep of the SUV once it runs out of warranty coverage.
Problems faced:
• Starting issues (only tuk tuk sound is heard when cranking). Starter motor replaced, issue not resolved
• Transfer case replaced
• Water seepage inside the trunk area
• Water ingress & moisture in both rear tail lamps
• Inside door lock trouble: Doors not opening. Two door latches replaced under warranty
• 3 tyres replaced under warranty (two burst, one bulged)
• Rear camera doesn't work sometimes ((surrounding camera not working, blue screen appears for front lh & rh side camera). Equalizer kits replaced under warranty
• Loud noise above 100 kph in the cabin
• Wind & whistling noise from front doors
• Heater core replaced under warranty
• Squeaking & rattling from front suspension
• Squealing drive belts. Faulty belts replaced under warranty
• Alternator bracket replaced under warranty
• Coolant Pump: Water pump pulley replaced
• Cooling fan: Bracket with pulley replaced
• The entire air circulation cluster was changed
• Misaligned front RHS door
• Unusually loud sound when switching off the engine
• Check engine light error (shows engine oil error)
• Instrument cluster shows "restricted performance" error (limp mode)
• Battery replaced under warranty
• Paint chipping off from the Range Rover badge
• Cloth peeling off from the rear parcel tray
• Horn & switch harness replaced under warranty
• Steering horn pad replaced under warranty
• Front sets heating and cooling not working. Steering wheel heating not working
Light scratches all over the car, and on the front right glass. Dealer's statement:
Rubbing to be done pertaining to light scratches all over the car and on front right window glass, which incurred during this visit (Happened because the person cleaning the car was wearing rings on his hand). As discussed with you, rubbing will be done when car will visit workshop. For Glass which I have already told nothing can be done.
Ranjan adds:
I think problems do occur in all the cars, but if they are resolved in a timely manner no one would complain. But instead dealers careless attitude and inability to diagnose and also non availability of parts adds to the injury.
I have a BMW 525d too but haven't faced such problems at all. In case of my Range Rover, the product has lots of problems and service backup is extremely inadequate.
I would certainly like to spread awareness about product and services, so that people can avoid wasting their hard earned money and make wise decisions.
Service Invoices:
Full History:
