Team-BHP - Engine shuts off in neutral gear
-   -   Engine shuts off in neutral gear (https://www.team-bhp.com/forum/technical-stuff/141495-engine-shuts-off-neutral-gear.html)
I own a 2010 Fabia petrol. During a recent trip to a hill station, I encountered a situation where the engine would automatically go off when idling --- even in neutral. Some one suggested it could be because of the incline, or the low pressure in the hill region. The outside temperature was just about 25 degree C. I encountered this almost every time the engine was idling (especially when I engaged Reverse), and once down hill on the way back. There wasn't any problem while on the move, and the problem hasn't occurred again (this was a month ago). I am yet to take it up with the service guys. Can some experts please explain what could be the problem.
I think it could be due to lower oxygen content (and low air pressure) at higher altitudes and the resultant air/petrol mixture imbalance within the engine. Check out your fuel pump ... probably the fault is with that. Maybe the mechanic will ask you to replace it.
I find that a bit hard to believe - what height was the hill station at? Sure there are differences when one starts climbing higher up but it cannot be so drastic , i have taken my 1.6 - which in fact should possibly be more sensitive to heights , highest i took her was about 10,000 feet - no problem.
I would maybe start off wondering if the engine was maintaining its RPM's in neutral .....
Originally Posted by puchoo (Post 3234438)
I find that a bit hard to believe - what height was the hill station at?....
The hill station was just about 1000m above sea level in Kerala. I had been to similar heights earlier too with no problems (a year ago). The RPM normally is at around 1000 at idle during start. During this incident the needle would raise to 1000 when I start and gradually fall to off, even in neutral. I had to keep pumping a little to keep the engine running for a while and then apply the gears.
At 1000 meters , it cannot be any influence of the height , it simply is not high enough , best if you speak to a workshop and ask them , maybe something to do with the Idle Air control valve.
A Modern MPFI engine will not shut down,if operated at high altitudes.
There is some other reason behind this,that needs to be investigated.
Isn't there some vacuum based switch or something that makes the engine idle without going off? I had my old Zen which used to have engine die down when stopped because of some loose connection.
Could be dirty/clogged or faulty idle air control valve or IAC valve. Also you may want to check for dirty/jammed air filter and air box. Lot of videos on youtube for cleaning the IAC.
Was the idle erratic, or did it drop to 1000RPM and then gradually shut off? When you provide throttle, you're no longer using the IAC, so the engine won't stall. Something surely wrong with the idling circuit.
If its IAC valve or air filter, then the problem would have resurfaced.
My best guess is bad fuel. Temporary block in fuel lines.
look for blocked IAC passage, choked air filter and anything in the intake system that might starve the car of air. 1000 m is not high enough to cause any problems whatsoever. I would also check for a clogged fuel filter, they are known to cause idling problems. I agree with dhanushs though, if it was just a one time thing it was probably just bad fuel.
It is a dirty petrol filter, going up inclines sometimes makes the dirt enter the filter.
By any chance did you happen to fill at a different petrol pump before going on the hill?
This is a high altitude phenomenon which is aggravated due to clogged air-filters.
We faced this , though at a much higher altitude at baralachla pass on way to leh in ford fusion. Severe lack of oxygen and terrible situation being stuck on steep inclines as engine would just stop once you lift your foot off the pedal.
Many would argue that in your case, it's not too high a altitude, but the fact is that it's lack of air being supplied to engine which caused the situation you faced.
Thanx guys for all the replies.
@Dhaushs and @diamond_dawg: I always fill at a HP COCO outlet.
The fact is I haven't faced the problem since that trip. But on that trip though it was regular. It was on an incline, and quite bad roads inside a private hill estate (Braemore) not really meant for cars. Going by the similarity (except for the altitude), I am willing to go by @fastlane's theory for now. My annual service was done just two weeks before the trip (did they change the filter?! at least they billed me) , and I am reluctant to take it to the service center with no problem to show them.
Originally Posted by 2cents (Post 3235000)
...on that trip though it was regular. It was on an incline, and quite bad roads inside a private hill estate (Braemore) not really meant for cars.
Was it rainy / high humidity conditions when this happened? Did you drive through water?
