Old 28th July 2013, 22:36   #16
mayankk's Avatar
Thanked: 8,456 Times
This is what the OP is actually talking about. Not from a commercial, this one's from the end episode itself.
Last edited by Rehaan : 29th July 2013 at 15:36. Reason: Using http link for video instead of httpS. Thanks.
mayankk is offline   (1) Thanks
Old 28th July 2013, 23:29   #17
Thanked: 394 Times
re: Waterless Coolant For Cars - Does it really work?
Hey that's the wheeler dealers episode I am talking about. Any one has used this stuff, specially asking our friends abroad.
norhog is offline
Old 29th July 2013, 22:09   #18
Thanked: 6,227 Times
Re: Waterless Coolant For Cars - Does it really work?
For an animated discussion, you need to post this in the 4X4 section!
Sutripta
Sutripta is offline
Old 31st July 2013, 20:17   #19
im_srini's Avatar
Thanked: 490 Times
One more video...
im_srini is offline
Old 1st August 2013, 00:08   #20
FlatOut's Avatar
Thanked: 385 Times
On a high-value, expensive component engine, it sounds as if it could make sense. For day to day cars, personally I wouldn't bother.
The online community seems to have concerns over its much lower heat capacity, meaning that although engine hotspots won't create localised vaporisation of the coolant, the temps for the engine may locally be higher. And that it is rather gloopy, which this http://speedtalk.com/forum/viewtopic.php?f=1&t=31361 isn't.
Those who live where it never freezes suggest Redline's WaterWetter product makes more sense, mixed with water = this increases the heat capacity of the water, so making hotspots cooler and provides corrosion protection. But this link http://www.thetruthaboutcars.com/200...%C2%AE-review/ reckons even this isn't what it's cracked up to be.
More reading:
http://www.pistonheads.com/gassing/topic.asp?t=1187245
http://www.3si.org/forum/f11/dumping...-setup-206021/
FlatOut is offline
Old 1st August 2013, 02:14   #21
Thanked: 56,121 Times
Water is still the best and cheapest coolant. There are a lot of other liquids used as coolants
. Water with a lot of additives - raise the boiling point
. Oils - raise the boiling point but require higher pressures
. Sodium used in nuclear reactors - have extremely high boiling point and thermal transfer characteristics but requires a high pressure closed system
Couple of points:
Water is the cheapest, but not necessarily the best. Most modern cars do require a proper coolant solution which typically does raise the boiling point but also preserves the various components in the cooling system. It's only part water.
Sodium in not only used in nuclear reactors. It has been used for decades in the automative industry to help cool outlet valves. I believe early 1960 -1970 Alfa's had them, Audi has used them and I'm sure a whole lot more manufacturers have at one point in time used sodium in their valves.
Jeroen
Jeroen is offline
Old 24th February 2015, 21:17   #22
Thanked: 24 Times
Hi Friends,
This is but it is quite intriguing. I came across an ad for Golden Cruiser Coolant. It mentions a code that you can actually use to confirm the veracity of the product! I am coming across such a product for the first time.
Ashok Naik is offline
Old 25th February 2015, 10:33   #23
arunphilip's Avatar
Thanked: 6,388 Times
Originally Posted by Ashok Naik View Post
Hi Friends,
This is best covered off by ACM's great thread/presentation on anti-counterfeiting measures. While I'm quoting the relevant part below, I'd urge you to click through and read his entire thread.
Originally Posted by ACM View Post
How exactly does one combat counterfeiters?
A solution that works for all Stakeholders:
Serialization when matched with Mobile Product Authentication Technology can be the most effective solution to Anti-counterfeiting.
MPA allows for Authentication via SMS using the simplest and most basic phones with immediate response at the Point of Purchase. It also provisions for 2D QR Codes that can be deployed for use via Smartphone based scanners that can engage the reseller channels for track & trace solutions.
arunphilip is online now   (2) Thanks
