Old 2nd June 2013, 10:19   #1
lapis_lazuli's Avatar
Thanked: 2,969 Times
Distilled Water : A scam running?
Dear all,
As we all know, distilled water finds use in at least 3 places in our car. The coolant as a diluting agent, the windscreen wash fluid, again as a diluting agent and most importantly, the battery.
I had been buying this almost always from the battery wallah. I have paid anything from 30-50 Rupees for a 5liter jerry can, with 5 rupees refund on returning the can. I always wondered if, given the cost of fuel, electricity(for the boiler) and labour in NCR these days, if distilled means pure H2O, or just a label, for the unsuspecting. I decided to try, and the easiest was to have a few drops of water on a clean surface to evaporate. I tried this with two samples, from the same shop, bought a month apart. It did not leave any residue in the first instance, but definitely a deposition on the second time. Faint, but a deposition nevertheless.
I wanted to ask the dealer. What he replied was something in these lines. There is a special chemical. They use any water, and put the chemical which makes it distilled. Maybe in my case chemical "thoda jyaada dal gaya". I was !
He could not believe that it is a boiling water, and condensation thingy that produced distilled water.
Needless to mention, he lost his INR50 a month customer. Big deal...
I have personally experienced ASS using water filter water liberally for all the three apps I have penned above.
Now my point is probably 99.9% cars and inverter batteries are being served "chemically distilled" water. This is a scientific impossibility. I don't want to treat my car with this junk. (Now, my maternal grandpa in his days, used the second rain water of the season. Not the first rain for contaminants. He was the works manager of an ordnance factory, so he knew his business well. The air was much cleaner then)
Which is the way to go, please..! I had been to Bhagirath Place, where i could find lab grade DW, for much higher price, but would be an overkill.
Would really appreciate some answers. And your experiences.
(My first Tech thread .)
Regards, and enjoy the brunch.
lapis_lazuli is offline   (7) Thanks
Old 2nd June 2013, 11:26   #2
Thanked: 84 Times
re: Distilled Water : A scam running?
Distilled water for windscreen spray and coolant? I never used distilled water for both these. Windscreen gets the normal water and coolant get the 1 liter water bottles.
Distilled water is used only as battery water.
ArunV is offline   (2) Thanks
Old 2nd June 2013, 12:35   #3
Captain Slow's Avatar
Thanked: 2,188 Times
Distilled water has to be used in the radiators, regular tap water has too much mineral content that can damage the water pump/ radiator.
Regarding use distilled water for the windscreen spray, I have never done that but now that I think about it, maybe its about time I start doing so,
In the old car the pump failed. When I tried replacing it the pump had a lot of mineral/calcium deposit on it.
Captain Slow is offline   (5) Thanks
Old 2nd June 2013, 12:46   #4
swarnava.m's Avatar
Thanked: 284 Times
Little OT. Why would you be needing 5 liters of distilled water every month? Coolant does not need replacing/replenishing that frequently, most batteries nowadays are maintenance free.
As for the cost, 30-50 rupees for 5L is not really that expensive. Regular mineral water bottles will probably cost more, and IMHO that is perfectly fine to be used for windscreen wash and coolant dilution.
swarnava.m is offline   (1) Thanks
Old 2nd June 2013, 14:00   #5
Swarnavo,
Good question! I need the water for the windscreen washer. I use it a bit too much and it consumes about 2-2.5 litres each time. NCR is a dusty place! The rest : to the planted aquarium to top up the water level, while not un-balancing the fragile chemistry. What remains, as a quick detailer/car wash diluting agent.
Its not the 50 bucks, I am happy to pay more. But is it truly distilled, is my concern. Remember the old mineral water ad: using cattle drink to fill up and a candle to seal it off?
Maintenance free batteries : well reminds me of that dialogue in "Dont mess with the Johan" : "The watch is water-resistant, not water proof....you see...!!!"
My maintenance free batteries have screw caps, oxymoron or what!
Old 2nd June 2013, 14:07   #6
RM2488's Avatar
Thanked: 123 Times
This is what I go for- lab grade is Rs. 120\5 ltrs where I live. This is the stuff I use for my car and inverter batteries. The coolant and windshield washer get regular tap water. The coolant I use says it's fine with tap water (on the label) and the tap water we get is pretty soft, so no harm done (yet- 9 years). I flush the coolant lines before I put in the new one.
I really don't think Rs. 120 is too expensive- mainly because I only use it for the batteries.
RM2488 is offline   (1) Thanks
Old 2nd June 2013, 14:29   #7
Thanked: 61,326 Times
Dear all,
Well, strictly speaking using an reverse osmosis filter is considered a chemical process. Not sure if you would call the end product distilled, but the result is essentially the same. Very little salts left.
As many mentioned before it baffles me you use distilled water in anything else than a battery. Even the battery is a bit of mystery as most batteries are maintenance free.
To be frank the only home application for distilled water these days is in some steam irons. And even those can cope with non distilled water these days!
Modern car washes (don't know about India, talking Europe/USA) will use distilled or reverse osmosis produced water for the last rinse cycle in order not to have to dry your car.
Jeroen
Jeroen is offline   (2) Thanks
Old 2nd June 2013, 14:32   #8
Jeroen
Just going by the book, Jeroen! Also, the tap water in my location is extremely hard.
Old 2nd June 2013, 14:59   #9
Catalyst_delhi's Avatar
Thanked: 174 Times
I have never filled a battery before , Do i need to do this frequently? My batteries last for about 4 years each.
Catalyst_delhi is offline
Old 2nd June 2013, 16:34   #10
motionfreak's Avatar
Thanked: 68 Times
Sir I stay in Thane (kalwa) too. I want to buy this lab grade water for my inverter batteries. please share the address of the shop.
[@Mods, I'm posting this here and not sending a PM to him, so that other members from thane can get the information too]
motionfreak is offline   (1) Thanks
Old 2nd June 2013, 17:12   #11
Thanked: 21,450 Times
I use distilled water only for the Battery.
The windscreen washer fluid is normal water bottle but the coolant dilution I leave it to the A.S.S to do.
Regarding the distilled water source, for me it is my lab in which I work so when ever I need the distilled water I take it from the lab.
Price if purchased outside LR grade is around Rs 100/5 Lts.
Cheers,
Anurag.
Old 2nd June 2013, 18:12   #12
RM2488's Avatar
Thanked: 123 Times
All you have to do is top up- depending on the charging circuitry, climate, coupled with usage of vehicle/inverter, you may have to do this anything from every month to once every 3 to 6 months. There are indicators for this- the floats for big batteries, and the min/max marks on all. Many people (including many batterywallahs) make the mistake of adding acid. I simply add distilled water and start a charging cycle. Regular maintenance gives a LONG battery life- it is not unusual for my batteries to go 5+ years without significant loss of capacity. I don't have the numbers to prove this (AMP-HOUR tests), but I've never had to replace a battery before then due to a battery not holding enough charge. This, of course, does not go for sealed batteries (although some people drill them), gel batteries, or the hundred other "maintenance free" variants out there.
The place is "OMKAR TRADERS" in Amar Gyan Industrial Estate, on the first floor. It's close to the ST Workshop, bang opposite Akruti SMC. The proper address is:
OMKAR TRADERS,
Complex 160 161,
L B S Marg,
Khopat,
Thane (W) - 400601
NOTE: I have had dealings with them before, they stock a myriad of other chemicals I find useful. However, I am not associated with them in any way. I am sure there are other lab suppliers of repute in the area, and I am not profiting monetarily by mentioning them. This only reflects the good experience I have had with them.
P.S. Sometimes they take up to 15 minutes to process your order- they go through the entire billing process, with VAT etc. And they keep your details on file- I usually get my work done in less than five, since they have me registered. Parking on the street outside MAY result in your vehicle getting towed. It is really up to the RTO's whims and fancies.
RM2488 is offline   (2) Thanks
Old 2nd June 2013, 19:44   #13
latentpotential's Avatar
Thanked: 419 Times
Hi, all battery dealers in thane and kalwa carry distilled water bottles for the same price.
latentpotential is offline
Old 2nd June 2013, 19:50   #14
Tejas@perioimpl's Avatar
Thanked: 9,764 Times
You can get a distilled water maker for approx INR 10,000 if you are really worried about the hardness. We dentists have this since we need distilled water for our autoclaves. Takes a few hours for 5 litres. Uses evaporation technology.
Tejas@perioimpl is offline   (1) Thanks
Old 2nd June 2013, 20:03   #15
Thanked: 255 Times
Distilled water does not come that cheap (Rs.50/5 liter). We get lab quality distilled water in 1 liter bottles for Rs.25-30 per liter and is available at most of the large reputed spare-part shops.
I use distilled water to top-up battery and coolant only and filtered drinking water is used for windshield washer fluid.
Never get the batteries topped-up by the battery wallahs, most of them use ground water to top-up the electrolyte.
interc00led is offline
