Re: Instrument Cluster Failure Caution & Apologies for a long read! :(
Hi Fellow Bhpians,
Sorry for bumping onto this thread pretty late. I have been facing an unique problem. I own a Swift 1st Gen (2011) with a 1200cc K-series engine.
Last sunday, during cold start, my engine stalled after running for barely 10 secs. I cranked the engine again with the key still on at Ignition, however it went futile. Switched off the Ignition, pulled out the key, again inserted the key to turn to Ignition and the engine cranked and got running. However, I got a CEL this time. Scanned the code using an Obd2 scanner and got the following DTC:
P0607 - Powertrain Module Control Performance Error
I deleted the DTC with the Ignition On and cranked the engine. The engine started running. However, the car seemed to run on limp mode for sometime before it got back to running as it normally would. Drove the car for more than 120+ kms till the next day (Monday) without any such error code during Cold Start. However, the following day (Tuesday) , the car stalled suddenly during cold start. Removed the same DTC again, however the car didn't start. The following morning, the car did start but with the CEL on the instrument cluster. The engine did feel heavily misfiring, with an unusual smell from the exhaust and ran on limp mode to the MASS. They diagnosed with their scan tool to confirm me that the ECM needs to be replaced. Due to my past experiences at MASS, I did not completely buy with their solution during this time.
I have a trusted FNG workshop near my place in Kolkata which is run by an experienced automobile engineer. I visited him the following day for a diagnosis. He scanned my car using his X-Tool professional scanner. He got the same DTCs as I did scanning the ECM:
P0607 & P2176 (I got this DTC intermittently while scanning with my scanner paired with my phone)
However, scanning the EPS module, the following DTC was found on X-Tool -
C1122 which translates to "Engine Speed Signal Malfuntion"
Hence, he asked me to leave my vehicle at the workshop for a day for his team to diagnose. I somehow stressed them to throughly check the wiring & associated sensors to the ECM. More importantly, I requested them to access & check the Crankshaft position sensor (sitting at the backside of the Engine and difficult to access). The next day, I was informed that it was due to a faulty ECM, they said that they did check the wiring & the crankshaft position sensor (this I highly doubt until I see it for my self). He advised me to replace the ECM at MASS as it would require key programming/pairing which could be done authentically at the MASS using Suzuki Softwares. I agreed.
The next day, I visited a different MASS (apparently known for their good reputation) in Kolkata and thoroughly explained everything that transpired over the last one week. They submitted my car (which was an extremely difficult drive from my home to the MASS as my car stalled more than 10 times during the trip) to diagnose. I was personally there on the floor while they diagnosed. Apparently, there was no fault in the firing anywhere. I also urged them to probe-test both the fuse boxes ( and the fuses) present under the Dashboard and in the Engine Bay. They found no fault!
Using the Suzuki scanning tool, they did get the same DTCs viz-a-viz P0607, P2176 & C1122. I did ask them to diagnose the Crankshaft position sensor by decoupling it. However, they seemed not interested in doing that as they monitored the signals & voltages of all the sensors on their scanning tool which were at normal readings. I agreed to their advice to replace the ECM after the diagnosis continued for almost 2 working days with me being present for nearly 4 hrs each day at the MASS workshop.
Got my ECM replaced and programmed today! There were no DTCs from the ECM i.e P0607 & P2176.
However, scanning the EPS module on their scanner, the C1122 fault code was present at Ignition On. However, it seemed to disappear when the engine was on (or maybe they cleared the code I'm not sure). I had to collect the car today as I needed to use to it reach somewhere. However, the C1122 fault code is bothering me.
On probing the C1122 DTC on Google, it is mostly characterized by a failing power steering motor/module or the associated wiring. Had I known this earlier, must have gotten it diagnosed at the MASS. Surprisingly, I do not feel any Power Steering issue while driving, except at U-turns, I feel the steering could steer back to its original position a bit more enthusiastically or quickly maybe.
Please share your advice upon the same.
N.B - 3/4 months back, during cold start I noticed that my engine cranked at half self, however the RPM needle stood at 0 which is suppose to hover around 1000+ rpm at cold start. At this condition I raved my engine to see if the RPM needle moved and it certainly did but only to point at 0 when the revv is released. Turning off the engine and cranking again, the RPM would be point at around 900-1000 rpms before adequately warming up, which is normal. This particular issue did happen multiple times when I also connected my OBD2 scanner to read the RPM readings on my phone at cold start. Surprisingly, even if the tachnometer pointed to 0 RPM at cold start, the OBD2 reading was absolutely normal at 1000+ RPM reading, gradually going down to hover around 750-800 RPM after warming up (even though the RPM meter points at 0 until I switch off the engine and start again for it point out at the correct reading ). Hence I got my car scanned during that time (3/4 months back) at the same FNG which I mentioned above. As far I can recollect correctly, the same DTC C1122 had popped up. I was advised that it wasn't anything major as long as it was not throwing any warning lights on the Instrument Cluster. 2 months back when I got my front drive shafts replaced, I fiddled with the wiring of the CRANKShaft position sensor which I could access with my bare hands and the RPM pointer at 0 did not come for the last 2 months, however the RPM needle did get stuck at times at 1.5k or 2k RPM at times which got normal at the next start of the Engine. This happened until I got the faulty ECM DTC last week.
Moreover, my knowledge tells me that the First Gen Swift was notorious for it's poor Instrument Cluster. I do have a dimmed CEL ON even if the Ignition is off, steering locked and keys out at all time. I had been living with this Instrument Cluster anomaly as it was not really causing a problem while driving.
Requesting you all to suggest me what else do I need to get diagnosed. I did a major suspension replacement & steering rack overhaul this year in the month of April as a routine maintenance.
Best, Sourav |
