Re: Engine Decarbonising - Demystified Quote:
Originally Posted by scorpian I would say the EGR is the reason for the extreme carbon soot buildup. One of the reason i did a remap was to close the EGR and also post that i removed the intake manifold and it was clogged by over 70percent at 88k kms.
My advise would be to get a soft remap done and close the egr and get the intake manifold and head cleaned once so that you will not face this issue again. |
Thanks Scorpian. This could possibly be the foremost contributor to carbon deposition.
Has anyone used a blanking plate to isolate the EGR assembly completely?
That would be a much easier option as the assembly is held in place by only two M6 bolts.
The intake manifold on Ford Tdci diesels can be easily accessed by removing the valve train cover. I am seriously contemplating use of carb/choke sprays/scraping off deposits using a screwdriver to clean off the buildup..
Attaching a picture of cylinder head for reference. The four largish round openings at the top lead to the intake valves |
