Thought i'd post this here, found from some forum while googling. This is not applicable to our emission norms but still found it interesting.
Credit to the actual uploader in that forum.
Originally Posted by SS-Traveller Sankar, I'm no expert in this, but a couple of thoughts:
- Wouldn't lower FE (or any other change) depend on the ECU codes written for the specific car/engine where the error occurs?
- Would P0420 error indicate only a downstream O2 sensor issue? This site seems to suggest otherwise...
Causes
A code P0420 may mean that one or more of the following has happened: - Leaded fuel was used where unleaded was called for
- A damaged or failed oxygen sensor (HO2S)
- Downstream oxygen sensor (HO2S) wiring damaged or connected improperly
- The engine coolant temperature sensor is not working properly
- Damaged or leaking exhaust manifold / catalytic converter / muffler / exhaust pipe
- Retarded spark timing
- The oxygen sensors in front and behind the converter are reporting too similar of readings
- Leaking fuel injector or high fuel pressure
- Cylinder misfire
- Oil contamination
Yes, the lower FE will depend on the specific cars and models, if the downstream sensor is being used for fueling calibration it will definitely affect FE. Some cars use the downstream sensor for fueling and some don't, but in the case of my K12M VVT Swift (2012) i'm not sure if it does or not. The vehicle supports P2270 and 2271 DTC which mean Stuck Rich or Stuck Lean, both are associated with the downstream sensor. But there is no failsafe operation mentioned for this code.
From what i understand, if the P0420 doesn't accompany any other error codes and is on its own its mostly due to a bad cat, leak or bad sensor
1) Leaded fuel damages the cat so it can be teamed with inefficient cat
2) Bad sensor - might throw other codes related to that sensor like voltage or resistance too high or low depending on the problem. Mostly only 420.
3) Will throw other codes related to that sensor like voltage or resistance too high or low depending on the problem.
4) Will throw an error code for coolant sensor
5) And will prolly richen the mixture too since sensor is reading more oxygen.
6) If the knock sensor is gone it should throw an error for that too.
7) Failed or deleted cat con only error 420 will be reported, like it was in my case when i went for headers.
8) Leaking fuel can be detected upon inspection. The too high fuel pressure should generate a code me thinks.
9) Error code will be given for cylinder misfire.
10) Physical check only i guess.
Originally Posted by SPIKE ARRESTOR The wideband lambda sensor is used upstream and is one of the main inputs for fuel control. The downstream lambda sensor are primarily present for emissions and OBD. Additionally, they also fine tune the inputs for fuelling (signals given by upstream sensor) so that a stable and well controlled close loop is maintained.
Various combinations of 2 point lambda and wideband lambda sensor are used by different manufacturers, depending on cost and other relevant parameters.
Spike |
Usually a narrow band is used as the upstream and downstream O2 sensor in most vehicles, but some cars do use a wideband upstream sensor like the post 2005 Impreza. If a wideband is used then the downstream narrow band sensor is also used for fueling trim correction, this is what i've understood so far. My car uses a 4 wired narrow band upstream and downstream sensor, 4 wired sensors are narrowband and wideband sensors are 5 wired.
I'm interested in understanding whether the car manufacturers in India (for eg: Maruti in their new BS4 engines) use both sensors for fueling or only the upstream one. Why would they limit the use of 2nd O2 sensor for emissions check? Unless constrained by bean counters i guess they will use it for fine tuning the fueling too.
Originally Posted by Mpower A failed downstream O2 sensor should not affect FE.
If it is used for setting fuel trim, then its probably under a transient condition.
Which Indian cars are using wideband sensors? |
I too would like to know which Indian cars come with a wideband upstream sensor. The mango cars i've come across all use narrow band upstream.
