Closed Thread
Old 13th May 2006, 00:27   #1
DaPilot's Avatar
Double Clutching... how many of us do this? any disadvantages?
I had learned this technique when I first started driving and have been practicing it for as long as I remember... It is a little tuff at first but once you get it its pretty simple (I am sure who double clutch will agree with me).
I always wonder if there is any downside of double clutching? any drivers here who double clutch that care to share their experience or findings?
For the audience that is not aware of this technique... here is a brief explanation:
Normal Shifting: Press Clutch > Shift into gear > Release Clutch
Double Clutch Shifting:
Upshift: Press Clutch > Shift to nuteral > Release Clutch > wait for a split second for engine to slow down (RPM to come down) > Press Clutch > Shift into gear > Release Clutch
Downshift: > Press Clutch > Shift to nuteral > Rev a little to raise RPM (so engine speed it upto where it should be for the lower gear) > Press Clutch > Shift into Gear > Release Clutch
It only takes split of a second (less then half a second) for the engine speed to match the speed of the gears. It sounds complicated but with practice it really doesnt take that long and you really dont loose any time shifting.
Advantages: Saves the wear and tear on gear box, clutch, clutch plate.. etc
Dis-advantage:
P.S. I did a search for this topic in the forum and couldnt find anything so I started a new thread... if there is an existing thread then MODS please merge this. Thanks!
DaPilot is offline
Old 13th May 2006, 00:30   #2
karthik247's Avatar
Thanked: 30 Times
There are a few threads regarding double-clutching.
I also remember reading that modern cars don't need that, not that its bad but doesn't make a difference.
karthik247 is offline
Old 13th May 2006, 00:39   #3
Rehaan's Avatar
Thanked: 36,067 Times
TBHP : Whats double clutching and whats the reason to use it?
cya
R
Rehaan is offline
Closed Thread
