Re: Why you must practice the "Idling Rule" with Turbo-Charged Cars Quote:
Originally Posted by sriramr9 Thanks a lot GTO. I have three of questions.
1. During cold start will it not be wise to keep the aircon off and turn it on later while driving and after the engine reaches desired temperature, i use the radiator water temp guage in to judge it. As during cold start does turning the aircon not put a load directly on the alternator which may transfer to the running engine??
2. This is slightly off topic but wanted to merge my question to the first one, can we turn ON and OFF the a/c while driving based on need, i hear mixed reviews on this, need more clarity as to what effect can this have to engine on long run.
3. is it advisable to let the engine idle with air con on tough traffic signals like minimum wait period of 300 seconds and multiple halts till crossing happens. i see every car, be it cab indica, innova, swift ritz, i10, vento all in idle with air con on. i do generally turn off the engine after 75 seconds but wonder as why no one ever realizes the same ?
4. (car equipped with turbocharger) A scenario where, while on the move in cruising speed, due to broken roads if one had to slow down abruptly due to bad road patches and in the event of down shifting what if by mistake the engine shuts down, improper release of clutch (happens sometimes), in that cse to avoid turbo damage, what if the car is started again immediately & revved beyond 2000rpm to spool the turbo will it help in the lubing process ? |
On 1: More advanced ECU's will disable the AC during the start cycle and only switch on once the engine idles. Once it idles the AC does put a bit of extra load on the engine, but nothing much. Your typical AC on a midsize saloon would probably pull the equivalent off 6-8 HP. Not much to get exited about for you or the turbo. Typically all AC's are automatically disabled below approx 4oC anyway.
Coolant temperature is not the best way to really judge what is happening temperature wise. It's the oil temperature which is relevant for your engine and turbo. And that temperature could lack behind the coolant temperature. Especially with engines with large volumes of oil. Better indication can be, if you have one the oil pressure indicator. Only when the engine oil reaches its normal operating temperature will that start showing normal readings too.
On 2: No worries, you can switch on and off as often as you like. Other than wearing out the on/off switch and possible the AC clutch you have nothing to worry about this engine wise. Accelerating away from a traffic light puts a considerable higher load on the engine, than switching your AC on.
On 3: If you want to keep cool, keep the engine and AC running at all times.
If you want to save fuel and the environment, switch the engine off.
There is nothing else to it.
On 4: Don't worry these things happen all the time. If you do it a couple of thousand times maybe you should worry.
In general and I think I said this before; There are a couple of dozen guys on this forum who worry about the idling rule for Turbo's. There are literally tens of millions other guys out there who never even heard about the rule and are pottering around with their turbo's never getting idled. At least not on purpose.
Reading through this thread you'd think the world would be awash with damaged turbo's. The fact is that a failed turbo due to not adhering to the idling rule is a very rare occurrence indeed.
So just go by what the owner manual advises and if you forget once in a while, just don't worry about it.
Enjoy your car.
Jeroen
