lets continue the discussion here. so that the topic gets more visibility.
Any examples of Blue printed (Professionaly) motors in India?
Thank you Ram !
Howler, thanks for balancing what has been posted by Foby.
Slightly OT but I think its apt here as the question has been asked here.
Foby, what you have understood is a version of the layman's interpretation of blue printing. Please don't think of this as a critisism but as a learning process. From the work you have been doing in the forum, you have all the amkings of a "petrolhead". So this is to make you a better one.
I quote below from Wiki (which often is the easy source instead of typing up the whole thing
http://en.wikipedia.org/wiki/Engine_tuning
Serious efforts at
blueprinting result in better-than-factory tolerances, possibly with custom specifications appropriate for the application. Common goals include engine re-manufacturing to achieve the rated power for its manufacturer's design (because not all mass-production engines put out the rated power), and to rebuild the engine to make more power from a given design than otherwise intended (because custom engines can often be redesigned to different specifications). Blueprinted components allow for a more exact
balancing of reciprocating parts and rotating assemblies so that less power is lost through excessive engine vibrations and other mechanical inefficiencies.
Ideally, blueprinting is performed on components removed from the production line before normal balancing and finishing. If finished components are blueprinted, there is the risk that the further removal of material will weaken the component. While it has nothing to do with blueprinting per-Se, lightening components is generally an advantage provided balance and adequate strength are both maintained, and more precise machining will in general strengthen a part by removing stress points, so in many cases performance tuners are able to work with finished components.
For example, an engine manufacturer may list a
piston ring end-gap specification of 0.003 to 0.005 inches for general use in a consumer automobile application. For an endurance racing engine which runs hot, a "blueprinted" specification of 0.0045" to 0.0050" may be desired. For a drag-racing engine which runs only in short bursts, a tighter 0.0035 to 0.0040 inch tolerance may be used instead. Thus "blueprint" can mean tighter or looser clearances, depending on the goal.
Unquote:
So from the above you can see it would be rather difficult to blueprint the engine of a vintage or classic.
In a way you are correct in what you stated as that is what would have been done on the Ford's engine but that clearly is not blueprinting.
Best Regards & Drive/Ride Safe
Ram
