Hey DRC and Fuelled,
You have misunderstood what i meant by Quote:
Originally Posted by Rehaan maybe it is some kinda halfway-there "coolant". ie Prevents corosion but doesn not increase boiling point or vice versa etc. |
I was saying that either it is rust and muck, or it is some adulterated/homemade/cheap coolant in DRCs radiator, with only half of the benefits of real coolant. IE does not increase the boiling point but does prevent corrosion or VICE VERSA.
And just like coolant increases the boiling point (like salt in water, in a pressure cooker in this case), anti-freeze decreases the freezing point for use in sub-zero climates. Not only will it save you from driving around with a slab of ice in the front of your car, but as DRC said, it will save you from a cracked/blown engine, since the cooling sleeves have coolant in them, and theres the small matter of anomalous expansion of h2o as we learnt in science class. Quote:
Originally Posted by fuelled but as the % of EG rises its specific heat(the amount of heat reqd to raise its unit mass solution by 1 degree) decreases n hence its efficiency in cooling... So water is also added. |
Good information there!
DRC, do a radiator flush. I did it once and i was unpleasantly suprised as to how much rust came out of my 19 year old radiator. You can do it yourself if you wish to, just make sure that you let the cleaner circulate by letting the engine warm up so that the thermostat opens and lets the cleaner circulate in the block. Im sure there will be instructions on the bottle.
cya
R
