Old 13th August 2012, 17:13   #1
Thanked: 124 Times
Skoda Fabia not responding to Ignition
Seek advice from fellow BHPians having SKODA FABIA 1.4 TDI(PD) Elegance, on facing following issue.
Car Background.
1)Purchased from Fahrenheit Automobiles New Delhi on 23/05/2010.
2)Two Free Services completed and the running on the Car is approximately 14000Kms only.
3)Trouble free ride all this while.
Problem Background.
1)Last week 8th August when retired cranking the Car to adjust the vehicle into the Parking Slot, it went blank.
2)All indicators were Normal, Light Horn working fine but absolutely mute on turning the ignition to start.
3)Called SKODA Dealership, was advised to try jump start and if it works change Battery as it is little over two years old.
4)Jump Start worked, so replaced the Battery from stock VRATA 61amp to Bosch 65amp.
5)Worked fine for two days and on evening of 11th August again the ingnition was mute.
6)Waited till next day and now tried ignition with the duplicate key and it worked.
7)Evening of Sunday 12th August while returning again the ignition went mute with the duplicate key too and luckily started after frantic switch on and off and closing and opening the front doors.
8)Checked with Jai Auto Mathura Road and they also appear to be on a trial and error trip.
In light of above please suggest probable cause of this issue which has made my Car vegetable.
kapursaket is offline
Old 13th August 2012, 17:20   #2
vikram_d's Avatar
Thanked: 1,188 Times
re: Skoda Fabia not responding to Ignition
Car Background.
Problem Background.
May be something as simple as a starter motor wiring loose contact. Get it checked ASAP. Does it have an immobiliser with a coded key? If yes, then that may also be the problem. But I would start with basics like the starter motor.
vikram_d is offline   (3) Thanks
Old 13th August 2012, 17:29   #3
Thanked: 124 Times
Yes it has the immobiliser and the corresponding key on the instrument cluster appears and dissapears in 5secs. I suspect issue with a relay/solenoid based contact which is actuating the Self motor.
Old 13th August 2012, 19:22   #4
nim_peter's Avatar
Thanked: 100 Times
Looks like your battery is not charging up properly. If jump start works, then I don't think there is any problem with starter motor, wiring or immobilizer, I maybe wrong too. Checking the charge in the battery will rule that out. We can then look at other angles.
nim_peter is offline
Old 13th August 2012, 19:31   #5
ECM
ECM's Avatar
Thanked: 16 Times
I wonder why dealer used jump start in your car!! In such cases there are all chances that ECU get damaged OR go absolute dead.
ECM is offline
Old 13th August 2012, 19:35   #6
mercedised's Avatar
Thanked: 449 Times
The same issue happened with me too, the problem was found tobe loose immobiliser connector. Get the immobiliser connector cleaned and tightened. I don;t know if Fabia comes with a separate immobiliser unit or not.
mercedised is offline
Old 13th August 2012, 19:43   #7
yogeshnagpal's Avatar
Thanked: 177 Times
Did you get the old battery checked before replacing it ? i.e the charge levels and the voltage levels on the multimeter ?
In the event that you doubt the battery, always ensure that you get the voltage levels checked using a multimeter. If the battery shows signs of weakness (i.e the voltage drops to around 6V - 7V) during ignition, then you can conclude that somethings wrong with the battery.
In normal circumstances, during ignition the battery voltage goes down to approx 9V.
I would suggest get the starter motor checked and also the fuse box.
Thanks,
Yogesh
Last edited by yogeshnagpal : 13th August 2012 at 19:48. Reason: Added few more points.
yogeshnagpal is offline
Old 14th August 2012, 13:42   #8
ragzv's Avatar
The OEM battery in my Fabia 1.4 PD TDI was 70 or 72amps (cant exactly remember) and was replaced with a 74amp SF (DIN74) battery. Please check the required battery capacity properly.
ragzv is offline
Old 15th August 2012, 10:37   #9
rajcs's Avatar
Thanked: 275 Times
Re: Skoda Fabia not responding to Ignition
Had a similar experience last monsoon in my Fabia 1.6. Pulled out the ignition fuse (#30 in my car) and inserted it back. The ignition was normal immediately and never had a problem again. May have been a loose sitting fuse.
rajcs is online now   (1) Thanks
Old 15th August 2012, 10:46   #10
Thanked: 124 Times
Already tried but to no avail. Jai auto also appears perplexed over the issue ... Already one day of investigation over
Old 16th August 2012, 13:57   #11
Thanked: 124 Times
Second Day at Dealership and no briefing of fault finding. This silence is eerie.
Old 16th August 2012, 19:08   #12
Thanked: 124 Times
Total goofup at the Service Center. All information being passed was of other Fabia having same last four digits as registeration number. But yes all well that ends well with a Service charge of INR616.00
Problem was snapping of the wire to the Starter Motor relay and this wire it seems snapped owing to have gone loose because of Diesel Engine Vibration and was skinning the Radiator Fan.
kapursaket is offline   (1) Thanks
Old 16th August 2012, 19:56   #13
swarnava.m's Avatar
Thanked: 284 Times
I think what you are referring to is PUSH START, where the car is put into motion by pushing and then started by slotting it into gear, so it starts with a jerk.
@Kapursaket is referring to JUMP START, which is done using jump cables, and is pretty safe.
swarnava.m is offline
Old 16th August 2012, 21:53   #14
vikram_d's Avatar
Can you please explain how the last 4 digits of a registration number cause this confusion?
vikram_d is offline
Old 16th August 2012, 22:35   #15
Thanked: 124 Times
The last four digits 2782 of the registration plate were same while the initial were different
