▲ Go to Top ▼ Bottom
Old 16th July 2016, 21:58   #121
nareshov's Avatar
Thanked: 241 Times
Re: Skoda / VW Group Engine Oils
@avinash_clt:
The Motul 8100 X-Clean is hard to get - I tried sourcing it from my neighbourhood Motul dealer, he wasn't able to. Motul 8100 X-Cess, however, was available.
This Mobil 1 5w30 which is 507 00 is backwards compatible with 505 01.
nareshov is offline
Old 17th July 2016, 06:42   #122
Vikram Arya's Avatar
Thanked: 2,295 Times
Originally Posted by Fiddler View Post
I have recently got my Car serviced at the AUDI service centre in Bangalore.
An A4 2.0TDI
They have changed the oil used from the earlier Mobil 0W 40 to Castrol 5W 40.
As a reply to my email they have said that both are approved by Audi.
What are the implications if any of this change?
Should I change it back to the old oil.
Also I have a sealed container of Mobil1 0W50 manufactured in 2014. Is it still usable?
Please read your owners’ manual carefully.
There are two kinds of service intervals for the 2.0 TDI engine; long life service and inspection/fixed interval service.
For long life service the specs are VW 506.01/507.00.
For inspection service/fixed life service which I believe is 15,000 kms or one year the oil should meet either of the four VW 501.01/506.01/505.00/507.00 specs.
As for the oil in your possession there is nothing like Mobil 0W-50, either there’s Mobil 0W-40 or Mobil 5W-50.
Mobil 0W-40 meets the VW 502.00 & 505.00 specs. Mobil 5W-50 meets the older 501.00 & 505.00 specs.
Castrol Edge 5W-40 meets VW 502.00, 505.00 specs & I don’t see why you should change unless you have a specific preference for Mobil.
Hope this helps.
Vikram Arya is offline
Old 17th July 2016, 18:02   #123
avinash_clt's Avatar
Thanked: 1,260 Times
Originally Posted by nareshov View Post
@avinash_clt:
Heard the same when I enquired for X-clean at a local dealer. I however plan to get a communication from Motul India as the product is listed on their website.
Mobil1 ESP formula is a superior oil. I am however not sure of going from a 5W40 to a 5W30 grade oil, especially since the engines have been running on 5W40 all the time. Unlike VW 507 00 (only 5W30), VW 505 01 was available in both 5W30 and 5W40 grades.
avinash_clt is offline
Old 17th July 2016, 22:18   #124
McLaren Rulez's Avatar
Thanked: 5,512 Times
Originally Posted by VeyronSuperSprt View Post
An interesting observation from an earlier VW catalogue which says: (on the top right hand corner)
"When using 5W-30 oil, avoid high speed long distance driving if outside temperature is above the indicated limits."
Note: This is no more applicable with the current advancements in tribology.
I understand that this is an old catalogue but I'm wondering why the ambient temperature being too high is relevant at all?
For any oil marked xxW-yy, the number xx determines how well it performs when the oil temperature is 0 degrees C (which is of relevance when you start up a cold engine) and the number yy determines how well it performs when the oil temp is 100 degrees C.
As far as I know, the oil temp at which modern engines operate is fixed and is usually around 100 degrees C. On a hot day, the radiator will work slightly harder but as long as your engine is not overheating, it will still run the same fixed oil temp. So why does ambient temperature come into the picture?
McLaren Rulez is offline
Old 19th July 2016, 08:01   #125
Thanked: 1,723 Times
As I've mentioned, Tribology has moved on a little bit but earlier on ambient temperature had a direct reference to manufacturers recommendations. The main reason was (a) hot ambient temperature would break down oil beyond a certain level or (b) it would remain more viscous than required for a longer time in colder temperatures. And while cooling systems are supposed to ensure a specified operating temperature this was a second level of safety so as to avoid a single point failure scenario.
Which is why I have stated earlier - do not use VW 507.00 in India as that is as per the EU standard - VW recommends Magnatec for the same engines in India which isn't VW 507.00.
Skoda / VW Group Engine Oils-image.jpeg
VeyronSuperSprt is offline
Old 20th July 2016, 15:36   #126
Motul X-Clean 5W40 (VW 505 01 oil)
@avinash_clt:
I had submitted a querry through Motul India website regarding the availability of X-Clean 5W40. The local retailers were providing only X-Cess 5W40 (does not conform to VW 505 01). To my surprise, they responded back within half an hour, confirmed the availability of X-Clean 5W40 and provided the contact of their Area Manager based out of Cochin.
I would be using it when the next service is due for the Polo GT TDI. Meanwhile a friend in Cochin already got in touch with the Motul representative and bought himself 5L of X-Clean 5W40 from the warehouse. Pictures attached below (apologies for the poor quality). So yeh, the oil is available, contrary to what retailers say
Skoda / VW Group Engine Oils-whatsappimage20160720.jpeg
avinash_clt is offline   (2) Thanks
Old 20th July 2016, 17:32   #127
nareshov's Avatar
Thanked: 241 Times
Re: Motul X-Clean 5W40 (VW 505 01 oil)
That's nice to hear! In my case the authorised retailed called up the warehouse in front of me and there was a lot of delay / dilly-dallying at the other end. Looked like they didn't make an effort to check the availability.
Let me know how this oil works for you. I'm on Mobil 5w30 I linked in my previous post right now.
nareshov is offline   (1) Thanks
Old 21st July 2016, 20:54   #128
Thanked: 3,363 Times
Attachment 1531323
Would be interesting to know your experience with it. How much does it cost?
Just ordered 5 litres of Mobil 1 from Amazon for my upcoming service.
Drive on,
Shibu.
shibujp is offline
Old 21st July 2016, 23:04   #129
Drive on,
Shibu.
My friend currently got 5L of the Motul X-clean 5W40 @ Rs.5075 ( 5 x 1L bottles). I couldn't find any other oil other than this in the aftermarket, which conformed to VW 505.01 and 5W40 grade.
--Avinash
avinash_clt is offline   (1) Thanks
Old 1st August 2016, 15:35   #130
Thanked: 217 Times
While the Castrol Edge 5w40 isnt normally VW 505.01 compliant, I have noticed a grade that is recommended in other Videshi TDI forums.
The information and the label(Google'd it) mentions it is compliant. Any experiences here as I plan to use this for my yearly oil change at a FNG soon.
Roomy is offline
Old 1st August 2016, 18:50   #131
I would take the description on the Amazon listing with a pinch of salt. The best thing is to look for the physical label on the bottle itself. Till now I haven't seen any Edge Titanium 5W40 in the retail market (non-imported bottles) that has VW 505.01 approval. I had purchased odd 3 or 4 bottles, in different instances and different locations.
Also there are at times slight changes in the specifications of the, say, same Castrol Edge 5W40, based on the markets they are supplied in. This would be more evident if you go through the technical data sheet section of similar Castrol oils in different markets.
Old 2nd August 2016, 07:20   #132
Thanked: 217 Times
Even I suspect the same and have requested the seller to send me a pic of the actual can.
Roomy is offline
Old 2nd August 2016, 07:52   #133
nareshov's Avatar
Thanked: 241 Times
@Roomy: what you should be looking for is this: Castrol Edge Professional VW 505.01
A spares society might be stocking these. I got some last year from the spare society near the Nandi Utrust showroom on Hosur road.
nareshov is offline   (2) Thanks
Old 2nd August 2016, 16:47   #134
A list of VW approved oils that are currently listed for sale in India. I had made this list sometime before. Please feel free to correct them.
For Diesel Cars requiring upto VW 505 01 spec
1) Castrol Magnatec Professional OE 5W40 (used in VW/Skoda ASC for all the cars from Fabia to Passat)
2) Motul 8100 "X-Clean" 5W40
3) Liquimoly Top Tec 4100 5W-40 (not sure of availability in India)
For Petrol Cars requiring upto VW 502 00 Spec( includes 1.2 /1.6MPI, 1.2/1.4/1.8TSI, 3.6 FSI -- fixed replacement intervals )
4) Motul 8100 ''X-cess" 5W40
5) Castrol Edge Titanium 5W40
6) Shell Helix Ultra 5W40
7) Castrol Edge Titanium 0W40 (better cold start)
8) Mobil1 0W-40 fully synthetic (better cold start)
9) Motul 8100 "X-max" 0W40 (better cold start)
For higher spec of VW 504 00 (petrol) and VW 507 00 (diesel)
1) Mobil1 ESP Formula 5W30
P.S: I am not sure of the official list of Liqui Moly oils sold in India. The information gathered is only from the website listings of the respective brands.
avinash_clt is offline   (10) Thanks
Old 3rd August 2016, 08:45   #135
Thanked: 217 Times
Thanks Naresh, could you also share the co-ordinates of the same if possible. I'll go over and have a look.
Roomy is offline
