Re: Indigo TDI - Oil coming out of dipstick tube! Thankyou all for the responses. Quote:
Originally Posted by Catalyst_delhi Get a new dipstick and check if the oil is leaking still. You could check the PCV system as well. Get the compression test done again at another garage. I am sure this would be just due to weak o rings on dipstick. | Quote:
Originally Posted by SS-Traveller 'Back compression' or blow-by past the rings doesn't do this. You get oil vapour pouring out of the dipstick hole, not oil itself. You're probably getting oil trickling out only because the dipstick is fitting loosely.
Change the dipstick. Or wrap the neck of the dipstick with thread seal tape (Teflon tape) to make it fit snugly, and then check again for leaks. | Quote:
Originally Posted by dhanushs Also, if your dipstick is not fitting well, means the O-Ring is worn out. Please replace it ASAP, as it prevents contaminants from entering. |
There are no gases coming out, so I'm hopeful that it is not backpressure, lets see. I got the dipstick replaced with a new one. At idling I did not notice any oil coming out of dipstick now(it was like this even with the old one), but I should check if the oil has stopped coming out after running the car a bit. I'll update on this. Quote:
Originally Posted by mayankjha1806 The other thing you should check is how much oil, in terms of quantity you are loosing, this should be checked when engine is cold and the dip stick to measure the oil level.
If there is a significant drop in oil levels over a decent time frame (probably one month), then its something i would be worried about. Otherwise it is a problem which needs to be fixed but not immediately. |
Yes, I have noted the level now, I will check it over the next 1000 km. Will update. Quote:
Originally Posted by coriollis 56k is not a huge mileage for failure.
I had 2003 Indigo Lx. Had experienced similar thing when odo read 65k, but nothing whatsoever happened and we clocked 130k on the odo(Stock clutch)
If there is compression loss then I feel that:
1.There would be noticeable drop in acceleration.
2.There is prominent gain in mileage as oil is also consumed as fuel.
If nothing of that sort is happening then:
Check your catalytic converter.. It has a tendency of getting clogged up, resulting in back pressure on engine causing untimely head gasket failure.
Please do have a check on your chauffeur's left foot. Clutch change at 56k is not acceptable.
Please don't lose patience. I made a blunder by selling mine. There is lot of life left in your car.
Drive safe
Cheers! |
Thankyou Coriollis,
The problems loss of acceleration, gain in mileage are not happening. Car is normal to use, I may not have noticed anything at all had I not opened the hood to see the source of oil drops on the floor(power steering oil, not the engine oil)
How do we check the catalytic converter? I'll ask the service guys next time but they seem to be mostly unaware of anything other than the routine oil changes and routine problems.
Actually the problem is not with the clutch itsel, but the clutch release bearing is making noise. TASS asked me to use it till the clutch needs replacement, but somehow I'm not happy with the noise so thinking of a change. But I will observe the car for two more months before deciding on anything.
The next day after the car came from TASS, I opened the hood to check the oil leakages, and guess what, the morons at the TASS left the intercooler hose unconnected. This is heights and a call to them gets us the same usual answers. I will probably never go back to a TASS.
I'll update on the dipstick oil leak after observing it for a week.
