Dear All, Thank you for all the kind words. That made all the effort worthwhile.
Here's my analysis of all the data:
- Total 177 issues reported by 35 owners. That means average 5.06 issues reported by each owner.
- 68 - sort of unique issues. 32 unique issues with more than one occurance. The remaining 36 unique issues are faced by only one owner each (so could be one-off).
- 21 owners (out of 35) faced some or the other issues with the infotainment system.
- 17 owners not very happy with the brakes because of the noise and/or the braking effectiveness.
- 17 owners not very happy with the steering/wheels because of alignment, leakage and noise issues.
- 16 owners had some or other sensor malfunctioning (Security alarm and TPMS warning going off w/o reason have been most common).
- Only 1 or 2 complaining about the engine responsiveness and the mileage
- Around 10 owners complaining about rattles
- Umpteen number of brake-pads have been replaced. 1 clutch assembly, 1 right front suspension, 1 transaxle, 1 thermostat, 1 water-pump, a couple of speakers, a couple of steering racks, a couple of headlight units, 2-3 tyres and multiple nippon units have been replaced.
- At least 7-8 newer versions of the infortainment system s/w have been released.
- A couple of instances of vehicle refusing to start temporarily.
- No full-blown breakdowns reported by any TBHPians, but multiple sightings of XUVs on flatbed-towtrucks. One unconfirmed report about a enire wheel coming off.
- Only around 20 issues (out of 177) have been satisfactorily resolved. At the same time, most owners are happy with the responsiveness from M&M and A.S.S. Request owners to update any resolved issues at the earliest.
If you want to report update on any issue, you can use the following list:
1 Brakes don't feel effective
2 Grinding noise from the brakes
3 Scraping noise from front left wheel during acceleration from 20-40 kmph
4 Vehicle pulling to the left
5 Power steering lightness reduced / fluid leaked (Hard steering)
6 Steering mis-alignment (~10 degrees off center)
7 Tyre quality (JK/bridgestone for vrrraju) / tyre squeal
8 Steering column hits the toes when steering is turned and clutch is depressed
9 Screeching sound/vibration when steering from LtoR or RtoL
10 Rust formation on wheels/around brakedisks
11 Gear shifting not smooth
12 Clutch Throwback & clutch hardness
13 Regular and continuous noise during acceleration
14 'Thuk Thuk' noise/vibration from right front wheel / Suspension noise
15 Wheels appearing like \ /
16 Engine response is sluggish
17 Vehicle failed to start
18 Infotainment system issues (restart, hangs, BT not working, UI, OneHourMode, mileage indication)
19 Need to shout to get heard while using the integrated bluetooth
20 Crackling sound from speaker
21 Clock shows incorrect time (lags)
22 Fan-noise from infotainment system too loud
23 Reverse camera image take time at startup as the infotainment system boots
24 GPS not getting a satellite lock / Not working at all.
25 AC giving hot air (inconsistently)/ Not working at all
26 Outside smell/air seeping in even in the internal air-circulation mode
27 AC gives out a foul oudor when u turn on the car after it had not been used for over 2-3 hrs
28 Coolant leak from thermostat
29 Cruise-Control (not engaging/switching off on its own)
30 Triangular dark spot in RHS headlight
31 Low beam intensity went down
32 DRL illumination too feeble
33 Left side LEDs working inconsistently
34 Bulbs especially stop lamps getting fused
35 Front door not closing/opening properly
36 Windows rattle when lowered partially
37 Passenger side seatbelt keeps on hitting the door panel
38 Creaking/knocking sound from the boot lid as soon as you open it.
39 Rattles from door panels
40 Rusted hinges
41 Hissing sound near the passenger door when vehicle in motion
42 Driver side ORVM hits window beading when closed
43 Front passenger door locking - weird
44 Low mileage (11kmpl on mostly highway usage) / wildly fluctuating mileage
45 Security alam goes off without any reason
46 TPMS warning/error
47 Reverse parking sensor malfunction (false STOP warning)
48 Start/Stop not working
49 Engine-Check indicator light comes up
50 Airbag light glowing
51 Hill-descent/ascent erroneous display
52 ABS light glowing
53 Autoheadlight flickers when operating the stalk
54 All dashboard lights blinking with beeping sound
55 Rattling sound from the instrument panel
56 Front seats squeaking
57 Rear AC switch LED not working
58 ODO has a black line (crack?)
59 Dirt getting caught in numerous crevices
60 Front bumper cladding becoming loose
61 Wiper speed (Initially fast, then slow)
62 Wheel-cap holding clips break easily
63 The cluster switch ( On the left side of tachometer ) stopped functioning
64 Rubber cap missing from top of the shock absorbers
65 Water pump making weird noise
66 Hill-descent did not work
67 ODO got reset once
68 The Silver color on Gear knob and door handles (inside) have started to give way
