Old 20th June 2013, 14:04   #46
DWind's Avatar
Thanked: 238 Times
Re: Symptoms of a worn out timing belt?
Need advice on Timing Chain for 1.5 Ltr CRDI engine on my Verna.
1.As per information on internet, Hyundai's U series engines use Timing Chain. As per manual (based on Service Checklist ) it is Timing belt. Don't know which one is true.
2. My car has done 89K and is due for another service in 6 months. SA has advised changing Timing Chain then. Do I need to do a change on Timing Chain now? I asked him about water pump and he said that it is not required. BTW he has quoted 30K for the change
Should I change as a precautionary measure? Please advise. My car is 6 years old.
DWind is offline
Old 20th June 2013, 15:39   #47
wanderernomad's Avatar
Thanked: 1,296 Times
Generally timing chains last longer than timing belts. Maybe the service manual is still using the old terminology. Chains are costlier but more reliable.
wanderernomad is offline
Old 20th June 2013, 16:05   #48
Thanked: 61,430 Times
Originally Posted by DWind View Post
On timing belts or chain I would go strictly by the book. Stick to the intervals as stipulated in the owners / service manual. You should not have to replace it early, but be very wary of replacing it too late.
Jeroen
Jeroen is online now
Old 23rd June 2013, 03:05   #49
Thanked: 686 Times
Its been so long since, we sold Opel astra, whose timing belt issue actuated me to start a thread about worn out timing belts.
Since, the time we sold that car.Ive been driving 2007 Honda Accord 2.4L AT
There is a particular noise that coming from my Honda Accord for past 1 month. Its nearing 89K k.m. , Here's the situation:-
Whenever I accelerate the car from stop, on the RPM meter, from 1000 to 2000 rpm, my car starts making 'kat-kat'; noise and it begins from the moment the car starts moving from standstill. The rate of that shreaking noise increases as RPM meter needle goes through 1000 - 2000 RPM. But, here whats irronic, after 2300 rpm, that noise starts decreasing, such that after 2500 RPM , no noise!!!??.
However, cars with timing belt or drive belt issues, the noise usually increases as throttle input increases. But, in my car that shreaking noise goes away after 2500 RPM!
I ve checked owners manual, the following:
Inspect and replace timing belt 100k k.m
and inspect water water pump
(except 4-cylinder models)
Inspect drive belts. after every 40k k.m.
interval.
Now, ive been thinking, whether this is a timing belt issue or a drive belt issue or tensioner issue!??
Compounded with the fact, that after 2500 RPM, that noise goes away.
All this has got me a bit confusing, Sure, i'll take the car to Honda ASC, first thing , the first week of July(At that time the service will be due as well).
What I would like to know from my fellow T-BHPians, is :-
Is this a timing belt or drive belt issue or tensioner issue?
What kind of assumption should I make, relating to the estimated cost of repair? (Before going to Honda ASC)
As always , opinions of My fellow T-BHPians will be highly appreciated.
Thanks.
ritedhawan is online now
Old 23rd June 2013, 09:59   #50
d_himan's Avatar
Thanked: 958 Times
Thanks.
Would mostly be a serpentine belt issue and not timing belt. Had a similar issue with my Accord. The belt is quite inexpensive. Get it done along with the service and if you know the advisor well, he'll waive off the labor charges.
As far as I know, timing belts don't give any symptoms most of the time - they just snap.
d_himan is offline
Old 16th August 2013, 11:47   #51
Thanked: 1,911 Times
I have a 2007 Swift Petrol VXI ABS. Is this an interference or a non-interference engine? The manual says nothing about replacement of the timing belt? My car has run 70000 kms. I am going for my next minor service tomorrow? Do I need to do anything extra for the timing belt?
carboy is offline
Old 21st August 2013, 17:16   #52
saket77's Avatar
Thanked: 14,735 Times
What I know about the MS Swift petrol is that it uses the K12M engine and hence has a timing chain, which can last the entire life span of the engine. Thus, a change is not needed and hence, not mentioned in the manual.
saket77 is offline
Old 23rd August 2013, 11:36   #53
Thanked: 588 Times
If it is 2007 Swift then most probably it will have the G13BB engine. As i understand it is a non-interference engine. I have a 2006 Swift Zxi. i am surprised that the manual doesn't mention anything about the timing belt. I will check mine
Mohan Mathew A is online now
Old 8th June 2020, 16:39   #54
Thanked: 373 Times
Now first of all, I'm not sure if the 1 ZZ FE 1.8 petrol Altis has a timing belt or chain. Assuming it is a belt, I'm in the 11th year of its ownership and have run 1,39,000 kilometres, and therefore intend to replace it.
Am I right in assuming that it has a belt? And, what all other things would I need to replace?
Swapnil4585 is offline
Old 8th June 2020, 20:30   #55
balenoed_'s Avatar
Thanked: 5,674 Times
A quick search on a spare parts website tells that it has got a chain.
https://boodmo.com/catalog/part-chain_sub_assy-5433765/
If it was belt, it is due to replace. But the chains lasts much longer is what is being told. Wise thing would be to take a look at the car's user manual which should have a mention of replacement duration.
balenoed_ is offline   (1) Thanks
Old 9th June 2020, 13:28   #56
Thanked: 373 Times
It indeed has a chain, and also happens to be a non interference engine.
Actually I've a 900-1000 km trip scheduled at the weekend. Was a little apprehensive of taking the car straight on the highway after over 2 months of standstill.
A quick chat with Toyota has somewhat assured me. But still is there anything specific to be seen with the chain?
