Old 13th October 2011, 14:07   #31
informmaha's Avatar
Thanked: 41 Times
re: Accidentally downshifted to first gear.
Originally Posted by anilisanil View Post
Yesterday night while driving back home, I thought I was in fifth gear (i am not too sure now) and thought I should downshift to third gear. So when I downshifted, I accidentally engaged first gear
Please help me is there anyway I could check if I damaged any mechanicals?
hey anil,
The only way to find out the damage is by removing the gearbox, If at all there is going to be a damage, it would be on the gear teeth. But no damage would have happened and infact this is the method to be adopted in case of brake failure. I have personally done it few times because of brake failures (I had used that vehicle for nearly 2 years before rectifying the issue), so nothing to worry here. You will not even feel anything different in the vehicle with this manuver. But to be kind to your vehicle, would recommend you not to do this. Put this thought behind you and Enjoy your drive ...
informmaha is offline   (1) Thanks
Old 13th October 2011, 14:14   #32
anky's Avatar
Thanked: 115 Times
In the gear box oil pan there is a magnet to collect metal shavings so even if some damage to teeth if not causing problem should be okay after gear oil and filter change .
anky is offline   (1) Thanks
Old 13th October 2011, 14:25   #33
the-rare-one's Avatar
Thanked: 58 Times
Anil:
I have done this on my Indica a few times when I started driving it 6.5 years back and it really has not been a problem so far (touch wood).
I recall this from my training sessions, the intructor told that one should not change or jump beyond 1 gear even if its a synchomesh box. e.g. If we are driving in 5th gear, its ok to downshift directly to 3rd gear, albeit you reduce the speed at the same time to match the revs and use the engine breaking to your advantage.
Its better avoided to jump from the 5th to 2nd or 1st gear (mostly wont engage, same applies to reverse) in all possible situation. This theory applies to upshifting too and have tried it on the e-way couple of times.
Best, Sameer.
the-rare-one is offline
Old 13th October 2011, 14:36   #34
ACM
ACM's Avatar
Thanked: 4,502 Times
I guess I do it once every year since about 20 odd year, no casualties as yet.
Even if the revs go to red but are for a short period only there shouldn't be any measurable damage.
ACM is offline
Old 13th October 2011, 14:48   #35
vnabhi's Avatar
Thanked: 2,426 Times
As others have said, don't worry too much, as there apparently are no signs of damage to your gear cogs.
My son did it once too when my Fiesta (petrol) was brand new. He shifted from 4th to 1st at a speed of 40 instead of 3rd. All of us were jerked forward with screeching tyres and a revving sound. He immediately pressed the clutch, and this trauma was only for 3 seconds or so.
The reason for his mistake was that he was used to the rubbery gear-shift of the WagonR, and not used to smoother shifts in the Fiesta : he had applied too much lateral pressure.
I did not bother about it for years till I read GTO's thread on over-revving the engine. But all seems ok even today. I guess the rev-limiter did its job, but I was always under the impression that the limiter works only when you accelerate to high revs on a low gear (which is gradual) and not when you downshift and cause the engine to over-rev.
vnabhi is offline   (1) Thanks
Old 13th October 2011, 15:30   #36
lucifer1881's Avatar
Thanked: 2,034 Times
Venu, the rev-limiter does not work when you engine-brake. I did it on a Fabia when I took it for a test drive. Downshifted to first at 100+ kph just for the sake of it. The rpm needle went beyond the red line even. Don't think it damaged the car in any way since I still drove it after that for quite a while.
That said, don't make it a habit to constantly over-rev the engine if it is a car you own or love.
lucifer1881 is offline
Old 13th October 2011, 18:37   #37
swarnava.m's Avatar
Thanked: 284 Times
There was a huge jerk and a high pitch screetch, I immediately realized my error disengaged the clutch slotted back to second and drove off. Now please don't ask me how did I manage to be so foolish :(
Just listen to your car properly now.. Does she emit any kind of strange noises??
In all possibility nothing has gone wrong, after all today's cars are advanced machines and this is a minor occurrence, but just to be on the safer side turn the music off and listen to the car for a few minutes while you drive.
If there is no noticeable difference in any kind of sound, then she's just fine. Chill and enjoy your ride.
swarnava.m is offline
Old 14th October 2011, 22:11   #38
noopster's Avatar
Thanked: 13,244 Times
Anil, remember the golden rule, First gear ONLY to start the car!
Relax, nothing will have happened. Just to be safe you can call up your Ford a.s.s and have them check it.
noopster is offline   (1) Thanks
Old 14th October 2011, 23:19   #39
Thanked: 143 Times
The City does not allow you to down shift to 2nd at 20kmpl without stiff resistance. So do not know how you managed to slot to 1st at 40.
Maybe it is safety feature built in the Honda's, but not sure.
However, in the Ford's and Fiat's allow you to slot in lower gears at higher speeds, but it feels scary and rattles you for some time
Since your car is running fine chill and enjoy the drive!
mkpiyengar is offline
Old 15th October 2011, 01:33   #40
Renjith Rajan's Avatar
Thanked: 56 Times
Once I down shifted from 4th to 1st in punto petrol at around 40. The gear slotted without any resistance. I noticed the sudden jerk and engine roar before releasing the clutch completely. Immediately I applied the clutch again and shifted to 3rd. This was an year back and there is no issues till date.
Renjith Rajan is offline   (1) Thanks
Old 15th October 2011, 02:02   #41
kaushik_s's Avatar
Thanked: 165 Times
Originally Posted by anky View Post
Like I said before look syncromesh gearbox then u will know what I mean . All modern cars have one to prevent incorrect shifting.
Would you please care to elaborate? AFAIK you don't need to shift gears in sequence (i.e. you can directly shift from 1 to 3 or any other gear to any other gear). Except obviously for Reverse gear which is always turning in reverse direction and hence you can't slot-in to reverse while moving forward.
Also Synchro means that you don't need to double clutch for shifting gears. Am I missing something here?
kaushik_s is offline
Old 15th October 2011, 07:21   #42
mashmash's Avatar
Thanked: 157 Times
Interesting conversation. I have an Esteem, and I feel its gears have a miond of their own. It does not allow me downshift to 1, when I am anything more than an almost stand still. Even to downshift to 2, I need to be slow enough, else I feel restriction.
mashmash is offline
Old 15th October 2011, 08:59   #43
VW2010's Avatar
Thanked: 4,558 Times
Anil, now you know how to slow down or stop your car when there is a brakeless emergency.
No harm done.
VW2010 is offline
Old 15th October 2011, 13:23   #44
ashis89's Avatar
Thanked: 12,175 Times
Re: Accidentally downshifted to first gear.
Many times I did 5-2 or 4-2 directly!
So I doubt!
Anyway, thanks everyone for the comforting words!
Even I have done 4-1 and 3-1 many times but after slowing down to the desired speed. Is it ok?
While learning driving 8 yrs ago I used to face difficulty in engaging the 5th gear(our car was a 4 speed M800 and i had no practice of 5th gear) and used to go from 4-3 rather than 4-5.
ashis89 is offline
Old 15th October 2011, 13:42   #45
BoneCollector's Avatar
Thanked: 11,356 Times
Dude,dont worry.These things do happen and can happen to best of the drivers when preoccupied.I remember day dreaming while driving once(albeit at less than 10kmph) and then i hear a typical grinding sound and came out of my dreams only to realise that i had tried to shift from 1st to reverse!
Thankfully nothing happened to the car(Santro). And i'm not trying to convey that i'm the best driver!
BoneCollector is offline
