Old 30th January 2006, 18:14   #1
DRC
DRC's Avatar
Thanked: 67 Times
Why relay for high watt lamps
So I am asking this question.
If I want to go for 100W bulbs, why need a relay.
If I do not use it, what will get damaged? Pl be specific, dont say its electricals
Before you all get on to this.. Here are my thoughts...
A car's wiring system unlike the one in a bike, already has a realy.
A relay is a device whcih translate the light switch setting to the ones capable of handling more current.
a 60W buld takes 5A of current, i.e., 10 A switched through the relay (2 lights), for 110W, it is about 20A.. which I think is still fair being handled through the existing relay...
Now If we opt for the relay, how is the wiring, ... are you going to replace the existing relay by a new one.. may be one with the higher current rating??? Which I think is acceptable if the OEM one is in-adequate for high currents.. But most OEM relays are good enough for the high currents. ( I will edit the thread with accurate current rating later)
In my bike way back in college days I had experimented this one.. nonte the bike wirirng (Kawasaki Bajaj k100 rtz) did not have a relay. still used a 55/60 buld and screwed up the SWITCH. Yes, switch in the bike can not handle the make and break of the high currents, hence gor screwed.. more expensive than the bulb itself.,
But a car does not have this problem.. It already has relay..
Now the last thing.. the wirer it self. are the wires in adequate.. I think these ones are always over engineered for safety reasons.. may be good to use the thicker ones.. but are they obsolutely necessary??
Gurus, comments please...
DRC is offline
Old 30th January 2006, 23:40   #2
Rehaan's Avatar
Thanked: 36,068 Times
Hi DRC,
You seem to have a good grasp of the system as is, but i will just start from square one again....
As DRC mentioned, the reasons why relays are needed in a car is so that the switch (in the light dipper/switch in this case) does not need to handle a very high current that is required for the headlamps.
Also, the fact that there is a lesser length of wire carrying a high current makes it safer in terms of short circuits (=fires).
Not to mention the fact that all conductors have a resistance, hence the longer the wire, the more the resistance. Therefore the shorter your current carrying wire is, the more current makes it through till the end. (= more power for your headlamps)
Now, as you mentioned, all cars already have a relay for headlamps! Why change it? ...it has to do with the ability to safely carry more current (or simply not trusting the OEM relays to handle the larger current your new bulbs will be drawing)
In terms of changing the existing wiring.
I WOULD reccomend it.
The larger wires minimize the voltage drop from your power source to your headlamps.
Intresting fact - a halogen bulb at 95% of its operating voltage puts out only 83% of its rated light output!!
Here is a phenomenal resource for automotive lighting -
http://www.danielsternlighting.com/home.html
cya
R
ps - let me know the ratings for some existing OEM relays and we will redo the math with some tricks
Rehaan is online now   (2) Thanks
Old 30th November 2006, 14:12   #3
Rtech's Avatar
Thanked: 371 Times
Rehaan, what you say makes perfect sense. However, could we go further into detail on this.
1. What gauge wires are the norm for existing cars? That is, if such a norm exists.
2. How does one check their wiring to see if it is sufficient to take a certain load.
3. Similarly, what amps should your relay be able to handle to provide you with optimum performance from 100/90W bulbs?
Rtech is offline
Old 30th November 2006, 14:18   #4
Rehaan's Avatar
1. To quote (and remember higher the gauge (ga), thinner the wire) >
Typically we find 16 gauge wire (1.5 mm2) at best, more commonly 18 gauge (1.0 mm2) and in some cases even 20 gauge (0.5 mm2).
2. By using a voltmeter / multimeter at the bulb terminals and comparing that with the reading at the battery terminals you can check voltage drop.
3. P = VI (watts = volts x amps)
100+100 watts continuous on high beam. 100+100+90+90watts on flash.
Car battery puts out between 11 - 14volts.
Do the math
goodnight.
R
Old 30th November 2006, 15:04   #5
tsk1979's Avatar
Thanked: 23,484 Times
I want to change my indica's wiring(already have a relay) but could not find anybody in Delhi who can do it for me.
Delhi based tuners... help please!
tsk1979 is offline
Old 30th November 2006, 16:25   #6
black12rr's Avatar
Thanked: 349 Times
As i understand , if the battery is 12v 9Ah ( ex bike battery, cars have more Ah batteries) , that means the battery is capable of 12X9 = 108 watts every hour . Is this correct ?
black12rr is offline
Old 30th November 2006, 17:32   #7
Pankaj401's Avatar
Thanked: 7 Times
Wrong!
It means that the battery can supply 9 ampere of current for 1 hour or 1 ampere for 9 hours.
The formula you would be looking at is:
(X ampere) * (Y hour) = quoted charge capacity of battery in Ah.
Quoted voltage is the voltage across the +ve and ground when fully charged and when no current is being drawn.
Pankaj401 is offline   (1) Thanks
Old 30th November 2006, 18:16   #8
Jaggu's Avatar
Thanked: 17,294 Times
very simple terms, the gauge of wire that come OE are not sufficient for 90/100 bulbs nor the relays equipped, for that matter the fuse rating also. please note that the fuse handles for each sides in most cars if iam not mistaken, so in effective they handle ur headlights plus tailights.
rest rehaan has given a detailed explanation. one good news is companies like PMP have ready made kits available with proper insulation and connectors along with relays which are very easy to install.
Jaggu is offline   (1) Thanks
Old 7th April 2009, 19:55   #9
Thanked: 58 Times
Not all cars have relays . Maruti 800 ,ambassador , and some of the trucks do not have relays .
For example if you were to use a 100 w halogen bulb directly in a maruti 800 ,the bulb requires a minimum of 8.5 amps typically . So the wire and the light switch should be able to handle 8.5* 2 bulbs minimum . The O.E wiring is not really capable of handling 8.5 * 2 Bulbs =17 AMPS of current . Incase if you do try using higher capacity bulbs ,you might actually end up frying the combination switch assembly .
So that is the reason why relays are used for handling the higher current capacity .
Most of the cars come with 55/60W bulbs only . And for that current the O.E wiring is ok .
The cars which do have relays may not have the proper rated wiring or the fuses to carry huge currents .
greatmana2000 is offline
Old 9th September 2010, 18:56   #10
Thanked: 111 Times
By using the relay assisted switching we have the main supply to the headlamp going thus: From battery, to fuse, to relay contacts, and to lamps.
I can cite two reasons for using a relay for the headlamps.
1. All above components are under the hood and the route length is shortest. Shorter wire means less transmission loss in wire. This enables the headlamps to burn brighter. Also, it is easier to choose thicker wire if it is kept shorter and does not have to be threaded all across the dash-board.
2. The dipper switch on your steering is more delicate and more expensive hence it is better to keep it on light load - just the load of the relay coil.
Good quality relays are built robust, and have contacts made of superior materials and large contact areas for longer life.
gostel is offline   (1) Thanks
Old 9th September 2010, 19:31   #11
Thanked: 81 Times
I had the same logic as the thread starter and plonked in 100/90's into my car. I just had one problem - the plastic bulb holders would melt (slightly) and lose the connection with the connectors on the bulb.
So upgrading the holders to ceramic ones is also important when going for 100/90.
Then, I went the whole nine yards and added the (second) head light relay with beefier wiring and ceramic holders - no problems so far.
CrackedHead is offline
Old 9th September 2010, 22:34   #12
Thanked: 3,001 Times
Originally Posted by Pankaj401 View Post
Wrong!
Slight modification. As ratings go 9AH = 10 hours x 0.9A. For shorter duration the capacity decreases, for example it would be 1/2 hour x 9 A apprx. Refer to battery manufacturers charts for details.
In most cars you will notice that the lights are brighter with the engine on, as the 12V battery has 6*2.2 = 13.2V fully charged, but with alternator on it can go up to 14.5V+ hence brighter light. Thus with relay and thicker wire you get lower voltage drop giving brighter light!
Aroy is offline   (2) Thanks
Old 12th August 2022, 12:32   #13
Thanked: 2,639 Times
Re: Why relay for high watt lamps
The headlight wire in most cars is rated at 15 A, that is a total of 180W in a 12 V system. Now if we subtract the 2 tail lights 7 W each you have 166W remaining.
divided among two lamps it is 83 W each.
Most countries have a limit of 55W for low beam and 60W for high beam, but there are a few that have a limit of 80W.
If you notice the bulb packing anything above 80W is labeled as off road use only.
As car companies do not want to design separate wiring for different countries they have common looms, and so the wiring is capable of 15 A.
Rahul
Rahul Rao is offline
Old 7th September 2023, 22:53   #14
wooka's Avatar
Thanked: 1,197 Times
Infractions: 0/1 (4)
In the context of LED bulbs today, I'd like to revive this thread.. There are a ton of LED lamps available today.
They often overstate their wattage. That's fine, we could care less as buyers as long as they out perform halogens.
The question - for a pair of H7 LEDs that say 220W on the box, and the distributor says '100 starting wattage and settles to 80W after a few minutes', does one still need a wiring harness for them? I understand the concept of constant current however the wiring in the headlight of a scorpio feels anaemic. I have in fact replaced my Z8 headlights with the reflector type ones since I struggled on my last highway drive (900 odd kms one way.)
I'll attach reference pictures.
wooka is offline
Old 7th September 2023, 23:13   #15
Thanked: 21,222 Times
Can't really say how much power these Chinese LED lights consume. However one reason I like to use a relay is to completely bypass the current out of the factory circuits. Especially modern cars with all these circuits routed in the BCM, it's better to take out the current consumed by the headlight and power it separately, just so that it won't cause any harm to the BCM and it's circuits.
