Originally Posted by akhil994
The question pertains to , how should I now be maintaining the car? The conditions in Gurgaon are really dusty and the car gets covered in dust in just one drive. |
Originally Posted by akhil994 Is it okay to use Jopasu duster to lightly dust the car off or will that again cause swirl marks? |
I would strongly suggest you to stay away from Jopasu duster.
For maintenance of the car just spray it down with diluted ONR (Optimum No Rinse) rinseless wash in a graden sprayer and wipe it with an ONR dipped 280 gsm microfiber towel. Especially the ONR wash and wax will leave your with a good glossy finish complimenting the paint sealant used.
Originally Posted by Thad E Ginathom I use a garden sprayer.
ONR is very concentrated. It might be expensive but it lasts a long time. Even at detailing concentrations one spray bottle removes a lot of bird crap.
I agree, ONR is VFM option because of the 1:256 dilution ratio
Originally Posted by arjithin Hello everyone,
Would like to have some suggestions on how to clean my car.
My 10 year old swift's surface has some kind of contamination all over it. Its on the paint and glass areas and makes the paint looks very dull and glass visibility poor. |
Spray your car down with a citrus based degreaser, imo it should help with removing the fallout.
Be careful with the glass and take care of it on priority basis as it might be impairing your visibility.
Take it to a good detailer if the above doesn't solve your problem.
Originally Posted by BlackMamba24 But the main problem I had was that swirls and scratches are same as they were before. Will Meguiar’s Ultimate Polish be good for that.
Also i need some help in choosing the tyre cleaner and how I can make exterior plastic parts shiny and black?
I am adding few pics of the 4 hour hard work |
Your car does look
Your daily maintenance by the colony washing guy along with the water source he uses are the biggest culprits for those deep swirl marks.
The Meguirs Ultimate Polish would give you the instant gratification, but would not last long due to its use of glaze.
You'll have to use a compound to make the paint swirl free and then use a polish to bring that factory clarity back.
Any All purpose cleaner or good shampoo can help you clean the tyres.
You can use Sonax Wheel cleaner for your alloys if needed.
If the exterior plastics are faded you'll got to use the 'Solution finish' to revive them and then add a dressing on top for the gloss.
Originally Posted by adimicra Based on my research, the Carpro Ech2o is supposedly a much more advanced product than ONR. Also, ONR was made as a rinseless wash whereas ECh2o (or ultima waterless wash) was made as a waterless wash.
If the car is really dirty, the waterless wash method is really not useful and it's better or safer to go for a full shampoo wash. |
Originally Posted by saisailendra I might sound harsh on saying this, but with a waterless wash, no matter how carefully we do it, we will end up putting swirls on the paint. Well, if we use a new side of microfiber for every wipe, we might greatly reduce the risk of swirls, but doing that way will result in using many more microfibers, again defeating the purpose of saving water (We have to wash those microfibers after the car wash anyway).
The ONR dilution ratios have worked wonders for me.
Even when the car is very very dirty, unless you've been hardcore off-roading.
And since I usually shy away from water-less washing, rinseless fits better to my preferences.
Its sad to see such myths against rinseless washes/waterless like ONR.
Water usage is a big concern even when its available plenty and we should try preserve as much as we can.
With products like ONR and Ech2o we can wash the car safely
by using proper techniques.
1.Use a high gsm good quality microfiber towel,
2. Use microfiber in straight lines while wiping (top to bottom / left to right),
3. Use different sides of microfiber each time it gets saturated.
These simple steps can not only help preserve water but also your paint health.
A simple 2 bucket wash will consume around 25-30 litres, pressure washing will consume around 90-100 litres while
water conserving methods like ONR can wash your car in 5-7 litres.
Number of microfiber consumed for a 2 bucket wash system is 2-3 nos.
Number of microfibers consumed in ONR wash is at max 4-5 nos.
(Because a microfiber has 8 sides )
