Old 16th June 2009, 11:55   #856
sharma_sanjeevi's Avatar
Thanked: 114 Times
Hi Stefanm,
I have used Waxpol Dashboard polish on the bumpers of my Maruti-800 & they look fabulous after applying the polish, try that.
sharma_sanjeevi is offline
Old 16th June 2009, 11:58   #857
hemanthisgreat's Avatar
Thanked: 51 Times
That Formula 1 car wash costs about 120 bucks in retail shops in J.C road , Mission road and is also available at National market.
hemanthisgreat is offline
Old 16th June 2009, 12:08   #858
Originally Posted by sharma_sanjeevi View Post
Hi Stefanm,
Will give that a try, it's easily available here in Goa.
stefanm is offline
Old 16th June 2009, 13:30   #859
Thanked: 54 Times
Your Formula 1 wash & wax botle seems to be genuine
how is it? Have you used F1 carnauba wax? How is this wash & wax as compared to F1 wax?
thanks , after washing with wash & wax liquid . it really gives that shine and smoothness. lasts for around 20 days when running . when not in use i cover my car.so i wash my car only ones a week.
no i have not used F1 carnauba wax.
here is the pic after washing my i10 with wash & wax.
Last edited by Jaggu : 17th June 2009 at 12:06. Reason: Please donot post oversized images, it causes inconvenience especially for mobile browsing. Thanks
Rjeevan is offline
Old 16th June 2009, 14:27   #860
Doesn't wash and wax leave with an undesirable wax on your glasses too?
neotraveller is offline
Old 16th June 2009, 14:47   #861
Raccoon's Avatar
Thanked: 116 Times
Both are good! You can't really compare them, as they are different products. But if you are asking about the shine, then the Wash & Wax cannot be compared to the Carnuba Wax tin. The results from Carnuba Wax is definitely better. Wash & Wax is to be used between waxings to keep the car clean and retain the shine.
Hi Stefanm,
Be careful - that polish is ment for indoor use only! Applying to exeriours may not be a good idea. Try F1 dashboard cleaner for that.
Raccoon is offline
Old 16th June 2009, 19:25   #862
narayan's Avatar
Thanked: 2,469 Times
D-i-y Scratch Removal And Waxing
guys
i need ur urgent help for a DIY job i am planning on my OHC for minor scratch removal and waxing
the process as i understand is as below
1) wash the car well to remove all greasy stains etc etc
2) use a particular type of emery paper to sand out fine scratches
3) use rubbing compound after usage of emery paper. use a machine based bufffer to apply the same
4) post this apply wax and rub the same using the machine based applicator
5) final clean up with some fine cloth
PLEASE ADD OR CORRECT MY UNDERSTANDING OF THE PROCESS ABOVE
lastly and MOST IMPORTANTLY I NEED PRODUCT RECOMENDATIONS FOR
1) car wash solution which can help in removing tough grease and tar marks
2) specification and brand of emery paper to be used for scratch removal
3) specs and brand of rubbing compound
4) specs and brand of polish
5) any other material to be used
6) brand of cloth to be used for final shine
7) can a regular drilling machine be used for this process by attaching a suitable applicator for the buffing process ?
i await your inputs before starting work and be rest assured that there will be a nice thread coming up on detailed DIY process for "cleaning up" a 8 year old car!
thanks
narayan is offline
Old 16th June 2009, 21:51   #863
Ravveendrra's Avatar
Thanked: 447 Times
Emery Paper?
Originally Posted by narayan View Post
guys
thanks
I am not so sure about the emery paper. I think emery paper is used only for preparing the body for a coat of paint.
Even the rubbing compound is to be used sparingly and rubbed on/off evenly else you will lose your coat of paint.
Cheers,
Ravveendrra is offline
Old 16th June 2009, 22:29   #864
Cheers,
Yes, Emery paper will help if you want to remove the paint and start afresh. Even rubbing compound comes in different grades. Use a fine one and don't use too much force. Better do it with hand. I use 3M Finesse-it for mild scratches.
janitha is offline
Old 17th June 2009, 11:53   #865
narayan's Avatar
I have seen the usage of emery paper in some youtube videos and also heard the 3M people mention that there is a particular grade of paper used to rub the scratch surface primarily to
1) remove the clear coat
2) even out minor scratches
guys - i await your replies on the other points raised.
narayan is offline
Old 17th June 2009, 12:26   #866
SRShrikanth's Avatar
Has anyone used ABRO Wheel cleaner for alloys.?
Any updates, please.?
What application is most recommended for Alloy up-keep.?
SRShrikanth is offline
Old 17th June 2009, 14:18   #867
Thanked: 114 Times
Thanks for the information, but i have been using it since 6 months untill now i didnt face any issues.
I will try out F1 Dashboard Cleaner also as you have recommended.
Cheers..!!
Sanjeev
Old 17th June 2009, 15:19   #868
I have seen the usage of emery paper in some Youtube videos and also heard the 3M people mention that there is a particular grade of paper used to rub the scratch surface primarily to
Yes, there are very fine emery grades like 1500 or above which will not do much harm to the paint but from my experience, rubbing compound is enough for minor scratches.
janitha is offline
Old 20th June 2009, 23:27   #869
My car remains parked in open & I generally use car body cover at nights. Is it alright to continue using car cover during monsoon or should I stop it & let car remains open?
VahanPujari is offline
Old 21st June 2009, 00:21   #870
Roy.S's Avatar
Thanked: 1,130 Times
I'd say that its ok as long as you are not covering a damp car. If it has gotten wet, better leave it uncovered till it dries.
Also, make sure that you use a waterproof cover. A Tyvek cover would be good for this. There must be other options too.
Roy.S is online now
