Search Forums |
Advanced Search |
Go to Page... |
Search this Thread | 23,884 views |
30th April 2011, 07:22 | #76 |
BHPian Join Date: Nov 2010 Location: Pune
Thanked: 76 Times
| Re: Camless and electronic timing : The future? Hello Vina, About the thing being obvious: There are certain innovations which are exclusively aplicable to marine engines.e.g 2nd order moment compensators for cancelling such moments arising from big engines, cross head lubrication technologies etc These had been developed with marine engines in mind. However I don't think camless engines idea was developed with marine engines in mind. It should have been an idea which marine engine makers realized useful after its emergence. For example say VGT is still not heard in marine engine turbochargers. I was appearing for my certificate of competency exam when the Dy Chief Surveyor of India asked about latest developements in enigne tech. When I mentioned abt some research I had heard on VGT in mairne engines he gave expressions as if i was story telling some weird sci-fi movie. Point is technologically marine engines lag behind sautomotive engine developements on some fronts. About temperatures in engine room, we have heat detectors at a few places to indicate existence of fire. One of the requirements is that they should give an alarm at 72 deg C ( i will check) apart from some rate of temperature rise etc requirements. And in what is called as purifier room, where all fuel and lube oil heaters and centrifugal separators are located , we often receive the fire alarms in persian gulf. These centrigugal separators too have electronic sensors like speed pick-up, vibration sensors, proximity switches, Differential pressure trx apart from usual Pt100 and pressure trx. These are still going strong. I definitely admit that it is no way close to 200 deg C but 72 deg C itslef is quite harsh to test electronics and I believe that even in automotive applications theses cards need not face 200 deg C. BTW i have a lot of doubts pertaining to electronics. I hope you wouldn't mind if I PM you them. Rgds. |
() Thanks |
30th April 2011, 09:28 | #77 | |
Thanked: 76 Times
| Re: Camless and electronic timing : The future? Quote:
Whenever reversing command is received, first this distributor is shifted to reversing poistion first. This achieved hydraulically in Sulzer engines and pneumatically in MAN engines. In reverse position, the distributor admits the starting air in reverse firing order and entire engine runs in reverse direction. In ME engines this whole hardware has vanished as the ECU just manipulates the sequence of operation of solenoid valves openign starting air valves. BTW this engine runs at 87 rpm with power output of 85% Max Continuous Rating (18.5 MW in this case) which is NCR (normal continuous rating) in marine engines. Rgds. | |
() Thanks |
30th April 2011, 13:18 | #78 | |
Senior - BHPian Join Date: Dec 2010 Location: Ghaziabad/Hyderabad/Mysore
Thanked: 341 Times
Please do feel free to write to me. I'll help you out to the best of my abilities. Last edited by vina : 30th April 2011 at 13:20. | |
() Thanks |
30th April 2011, 13:28 | #79 | |
Thanked: 341 Times
Wouldn't you have to stop the engine first and then start it again to reverse? Also (to others) what would be the purpose of having a car that can use all gears in reverse? Do you intend to drive it at high speed in reverse? So far as I know the gear ratio for the reverse gear is usually such that the wheel-rpm/engine-rpm ratio is less than event that of the first gear. I don't think that is done to improve torque only, I think that is also done to restrict speed of the car in reverse. | |
() Thanks |
30th April 2011, 16:42 | #80 | |
Thanked: 76 Times
There is an interlock called Wrong Direction Interlock which prevents fuel/starting air being injected in reverse firing order. Since I have mentioned so much irrelevent stuff here I would like to share that in extreme emergency cases where collission is imminent, marine engines can be reversed from full steaming ahead to full astern without waiting for engine to halt intermittently. Actually eninge will pass zero prior reversing to full but only momentorily. This is called crash astern or double ring astern in marine lingo. You might remember in some movies say Titanic, the wheel house rings the telegraph (which communicates what engine rpm wheelhouse wants) twice to full astern. The name double ring is from this act which communicates to engine room that crash astern is required. The engine builders usually guarantees only two such crash astern operations in engines entire life (as taught to us in cirriculum). Of this one is spent during sea trials after new shipbuilding in proving emergency stopping distance. This leaves only one guaranteed crash astern operation in life time of engine. Thereafter the engine may or may not survive subsequent crash asterns. Rgds. | |
() Thanks |
30th April 2011, 18:08 | #81 |
BHPian Join Date: May 2007 Location: Bnagalore/Cochin
Thanked: 48 Times
| Re: Camless and electronic timing : The future? Hi Sinbad.sailor I belong to the side who troubles you all the time including the crash astern . What do you think VGT is not of much use to large marine engines as we operate at a very narrow RPM rage most of the times. |
() Thanks |
30th April 2011, 18:19 | #82 | |
Thanked: 341 Times
How is anything you wrote irrelevant? The thread is about camless and electronics timings and yours is almost the only production engine that is camless and uses electronic timing to the fullest. What you wrote is very interesting, however I remember that in the movie they first stopped the engine and then reversed it. Also I believe that one was a steam engine (they were hauling coal). I would assume that in the emergency you described even the propellers (or whatever you have now) will also have to stop first - otherwise those can also get destroyed (along with the bearings etc.) | |
() Thanks |
30th April 2011, 21:01 | #83 | ||
Thanked: 76 Times
Jokes apart.I was guessing there would sure be lot of seafarers over here. Anyways lucky me nobody has ever troubled me over crash astern so far. Nice to make acquaintences with you. I think VGT can have applications on ship's main engines. You must be aware of FUSS engineers make when wheel house asks for some intermediate speed. That is all because if speed set point not chosen wisely at speeds below half manoeuvring speed the auxiliary blowers will keep cutting in and out and we might burn them out. With VGT, Turbos can be matched even for this part load operations and in the long run would you not like marine engines to be step less? Quote:
BTW Vina, I had a problem few years back. The amplifiers for Exhaust temperatures were fitted on to exhaust receivers. Temperatures there used to be severe. Once i went there and burnt the sole of my safety shoes. Due to this intense heat the isulation of cables running from PT100 to amplifier used to burn away and these cables used to short with body causing erratic readings and engine slowdown. These PT100 were supplied integral with special cables of specific resistence. Hence whenever I used to replace the grounded bare cables with high temperature cables from my store, the readings used to go hayway due to change in the resistence. I know if I use 3 -wire loop instead of 2 wire loop, I can cancel the effect of resistence variation. However I am unable to remember how to go about 3 wire looping. Though this is more an electrical problem than electronics one, I hope you can help. Rgds. | ||
() Thanks |
30th April 2011, 21:45 | #84 | |||
Senior - BHPian Join Date: Jul 2009 Location: Calcutta
Thanked: 6,227 Times
General: Reversing an automobile engine is problematic, because ancillary services like water and oil pumps are direction sensitive. That said, one of the bubble cars had to be reversed by stopping and reversing the engine. I forget which. DAF? Regards Sutripta | |||
() Thanks |
30th April 2011, 22:13 | #85 | |||
Thanked: 76 Times
But nowadays it is all contactors getting closed and opened sending electric signals. Quote:
But these new age ships have distributed control system and hence it is much easy to read out local reading and force the engineered output for the specific channel using computers. Though the layout on these ships is better hence no such problems have occured so far. Rgds. | |||
() Thanks |
30th April 2011, 23:15 | #86 | |||||
Senior - BHPian Join Date: Mar 2007 Location: Bangalore
Thanked: 2,919 Times
Going by your economic principles, we wouldn't have seen Diesel Injection systems: development of electrically controllable injectors cost a few hundred million dollars over 20 years. And common rail injection systems started 60 years back. Surely you wouldn't have seen an opportunity there either? As far as cooling is concerned, anyone who has done it at least once knows how simply and economically it can be done. To those who haven't, it is complex. Of course, those involved in insides of components don't often think at sub-assembly and system level. Just like a brick-maker does not think of walls or architecture. Quote:
A simple spectrum analysis of these inflections (FFT will do well) will show you which frequencies are produced. Part of that is the famous 'alternator noise' in audio (badly grounded systems, that is). Another part is RF noise. Same thing happens in ignition systems based on contact breaking - ever heard an old auto or scooter crackle your audio at a red light? Old cars with contact breaking ignition don't do that, right? That's 5 side shielding for you. What challenge? Solenoids are comparatively benign, and are much easier to shield. No, they don't directly work against the high pressure - the pressure helps it lift the constricting pin very fast. And the power consumed is about 20W for a few milliseconds depending on the injection profile). Piezo ones consume even less. | |||||
() Thanks |
30th April 2011, 23:44 | #87 |
| Re: Camless and electronic timing : The future? |
() Thanks |
1st May 2011, 00:40 | #88 | |
Thanked: 341 Times
Regards Vina Last edited by vina : 1st May 2011 at 00:43. | |
(1) Thanks |
The following BHPian Thanks vina for this useful post: | aravindwarrier |
1st May 2011, 01:04 | #89 | |
Thanked: 341 Times
My honour to help you in this, and I hope this works. In the attached picture, the top picture is the structure you have. With the stock cables with your PT100 sensor, R1 is constant and any delta(Rab) you get (after calibration) is coming almost entirely from the PT100. If you replace the stock cables with the high temp cables then the R1 changes as well and the delta(Rab) = d(Rpt100) + 2*d(R1) and since d(R1) is not something easily calibrates your readings go haywire. If you use the bottom arrangement then all you need to do is instead of using delta(Rab) you use delta(Rdiff) = delta(Rab) - delta(Rbc) then delta(Rbc) = 2*delta(R1) and delta(Rdiff) = delta(Rpt100) as you wanted it in the first place - do remember to calibrate it, though if original stock cable R1 was substantially constant then this would work fine. EDIT: the bottom port is C, forgot to include in drawing. Last edited by vina : 1st May 2011 at 01:05. | |
() Thanks |
1st May 2011, 11:27 | #90 |
Distinguished - BHPian Join Date: Jan 2008 Location: Gurgaon
Thanked: 3,229 Times
| Re: Camless and electronic timing : The future? Ahhhh even more intense engineering and application thereof. Interesting. Professors please carry on. Poor Tanveer his thread is royally hijacked but I am sure he would be pleased with the direction(S) it is taking. Fascinating. |
() Thanks |
