Re: Looking for a SUV/MUV Quote:
Originally Posted by ACM wanderer
Both the pricing are quite good. Safari should already be on the second battery and if it was recently changed it would not require a change, but if it is the original one then a change would definately be required. The Scorpio should also be able to manage without a change in battery if is from 2011, the battery may be low because it has not been in use for 2 months, and may last another 6-12 mths.
Check Tyres, see if one of them has a new set on already - That is a Rs. 40-50,000 saving. |
Hi ACM,
Thanks for your inputs. Well, as per normal logic even though it seems that tyres and batteries should be okay and would be on the second sets, but I have seen enough repossessed vehicles to know that things are not what they seem to be. The first things the repossessing agencies do is to change the good tyres, batteries, HU, speakers etc and put in bad, bald tyres and used old batteries and then only hand over the vehicles to the yard. So, invariably these are to be changed without even checking them. Quote:
Originally Posted by ACM You are not likely to get lesser used vehicles for less than 4L. |
Well, even with higher budgets, you wont get many low mileage vehicles here. The biggest problem around here is the high mileage of the vehicles like Safari and Scorpio.The culprit for this is the thriving practice of running private registered vehicles on tourist duties. You only have to employ a driver and contact some travel agency, you are good to go even without tourist permits. My budget is around 6 lakhs, but am still to find a vehicle (Safari / Scorpio) with less than 70K on the odo. So, finding a well maintained, self used vehicle is a big task requiring a lot of patience. Quote:
Originally Posted by ACM You are looking at Rs. 7000-9000 per service in both cases. |
I can live with that if that is only what the car will demand, i.e., the regular servicing. But, I hate those out of blue niggles which make one go to the ASC, repeatedly. Moreover, with a 50 year old CJ3B in the garage, I can not afford to have another attention grabbing vehicle.
So, all in all, lets see how it goes. Overall, the final costing for the vehicles would be close to 4.00 lakhs all inclusive. I might go for one only if it is in very good condition mechanically and is available cheap. Otherwise, it does not make any sense to buy a repossessed vehicle as the actual cost after everything balloons up considerably.
But, my original confusion still remains, i.e., to go for the Safari or the Scorpio...
