DUMMIES GUIDE FOR "HOW TO PERMANENTLY REPAIR A SUPERBIKE's PUNCTURE & BALANCE YOUR WHEELS MANUALLY"
(Mods may copy these subsequent posts into a separate Topic also, if necessary, as I feel it can help many Superbike Owners as well as Motorcycle owners in general)
As I had mentioned in my previous posts, that I had found a very minor puncture in the front tyre. And Today I found this embedded in the rear tyre as well... yikes!
Now I could have gone in for the temporary tyre puncture fix, which I presume 99% of bike owners as well as superbike owner's do. But I was not convinced about it's potential safety aspect at high speeds, especially in bikes capable of doing 250+ kmph speeds. Also this is what is specifically mentioned in the Service Manual of the bike by Kawasaki about tyre repair -
So, a permanent fix it was. And the best permanent fix is to do a mushroom or plug type tyre patch which is now being offered by all MRF Exclusive Stores in the country. Here is how it is properly supposed to be done -
So first step first, taking the wheels off the bike. The steps I detail now are going to be common in most superbikes. But still, kindly refer to the service manual of your bike for exact repairs. Starting from the front, first step is to remove the 4 Front Brake Caliper Mounting bolts (2 on each side) -
Then loosen the Front Axle Clamp Bolts on the right side of the bike
Then loosen the Front Axle from the right side of the bike This requires a 14mm Hex key tool.
Then put the bike up on a proper jack. I first used the Rear Paddock Stand and then I used the Triple T Front Stand which I had discussed in my previous posts, so that both wheels were now off the ground. Remove both the Front Brake Calipers (inspect for brake pad wear too)
Insert clean piece of cardboard to help prevent them from sliding closed or falling out.
Remove the front axle completely after being fully assured that the bike is securely supported by the Triple Tree Stand. Also secure the Brake calipers with some plastic rope as I have done, so as to avoid any undue pressure on the brake lines
Remove the front wheel completely
Remove the collars on both side of the front wheel and also note the tyre rotation arrow. This will be useful for refitting the tyre back on the front wheel in the same direction matching the markings on the tyre as well as the rim. The collars are same on both the left and right side of the front wheel (but different on the rear wheel) and need to be properly cleaned and greased with high quality high temperature grease while refitting the wheel.
FRONT WHEEL REMOVAL COMPLETE.
After raising the Rear Wheel on a Paddock Stand, Loosen the Chain Adjuster Clamp Bolts on both the sides of the wheel (as detailed in my previous Chain adjustment post) and loosen the chain adjuster to make Chain Slack. Remove the retaining rings on both side of the rear axle and loosen the Rear Axle Nut
Remove the 2 Rear Brake Caliper Mounting Bolts and remove the rear brake caliper. Once again attach some clean cardboard in between the brake pads for reasons stated above.
Remove the Rear Axle Nut and it's washer from the right side of the rear axle
Remove the chain from the sprocket on the left side, as it has already been loosened previously
Remove the Rear Axle from the left side. Slight gentle hammering might be needed to slide it out.The just slide the rear wheel out.
REAR WHEEL REMOVAL COMPLETE.
Both the front and rear wheels removed. Took me not more than 5 minutes each for each wheel with the proper tools and jack stands even though the process above may seem daunting.
The Bike now bare-wheel supported on the two stands
Pack up both wheels on some clean cardboard in some proper vehicle to take away to the MRF Exclusive Store, in my case this i10...lolz
Also received these tyre valve stems. TR 412 is the shorter one and is the OE size and TR 413 is the longer one. I got 4 of each for about 90 bucks for 4 from AliExpress -
https://www.aliexpress.com/item/4pcs...311.0.0.zF7Mmb . Kawasaki had charged me 1100/- bucks for ONE!!! while replacing my wheel rims under warranty.
Also received these plastic rubber wheel rim protector to prevent the rim edges from getting scratched while removing the tyre from the wheels. 300 Bucks from AliExpress -
https://www.aliexpress.com/item/2PCS...311.0.0.79hIuY
Reached the MRF Exclusive Store. This was not in such a great condition and I later found a different ultra modern MRF Store with latest german machines. However this one had a competent mechanic and all necessary tools and patches to do my job to my 100% satisfaction.
The Puncture repair workshop
Keep the wheels on the ground on the clean cardboard carried from home on two clean wooden blocks (as shown in red) so that the brake discs do not touch the ground and get damaged
The Rear wheel being tackled first and the bead being broken by the semi-automated machine
The tyre being carefully removed from the rim so as to not scratch anywhere
The wheel rim removed from the tyre and being properly supported so as to not scratch anything
The Rear Tyre, which is a Bridgestone Battalax Hypersport S20R 190/50 ZR17 M/C, Made in Japan (73W), opened up
This is the original MRF Tyre valve stem (TR 413) offered by MRF for 50 bucks
Proper pneumatic buffing tool to scrub the puncture site from inside
The culprit screw was removed and the tyre hole was properly drilled and prepared for the mushroom tyre patch
Max 30 photos reached per post. To be continued in the next post...
