Its 2 years and 16,000 kms on my Aquila.
Here is the Summary of all the "Good" and "bad" about this bike.
THE GOOD:- Never did the vehicle refuse to start at any given time in the last 2 years.
- Very reliable ,rugged.
- The Bridgestone tires manufactured in Japan are very good and have done wonderful in all weathers.
- The DSK service has been impeccable and at no time did I have any room for complaints. The DSK Pune staff is very courteous and technical.
- Once you get tuned to this bike, city travel,handling and cornering becomes a breeze.
- Good fuel consumption averages, mixed 22-30 km/litre.
- Very smooth and refined engine as compared to other cruisers available at this price range.
- Quality of the parts is good ,those that were defective were promptly replaced. The Petrol tank started showing rusting at some places, it was replaced with a brand new Petrol tank. Chrome foot pegs showed signs of paint peeling and were replaced with new ones without resorting to any haggling.
- The vehicle is a "crowd gatherer", wherever I went, the black and chrome never failed to attract the crowd.
- In the last 2 years covered entirely by warranty, I just had to spend for oil and service charges. Not a single new part had to be bought .
- Having a global presence, you can order many after market parts for this bike.
DSK had themselves made certain alterations in my exhaust for a better sound.
Although it sounded and worked well, I noted that whenever I wanted to go to higher speeds, the frame used to shudder.
When I brought this ,to the notice of the staff, they changed the entire exhaust at "no cost" to me.
Thereafter the bike turned out to be very smooth.
I fixed up LED light,18V, both sides.
Changed from footpegs to proper foot rests for comfortable long travel
No other modifications done to my bike, although I was suggested to fix a K&n air and oil filter and ECU remap. I didnt do it, since I did not need it.
THE BAD- Although most parts are easily available, it took me a long time to source the original Hyosung battery when I needed a replacement. My left sided air intake panel needs a change ,however this part is yet to be made available( booked 15 days ago).
- As with most cruisers in this price bracket , the suspension is on the stiffer side . Long stretches of highway are consumed without as much as battling an eyelid, but when it comes to rough roads, your speed would come down drastically, so also your comfort level; because of the stiff suspension. Although the front and rear suspension are adjustable, employing the maximum setting also would still leave you wanting for a softer suspension.
- I pushed the Aquila to very high speeds in a crouched position, but realistically travelling more than higher three digits builds up a lot of wind drag and your helmet starts singing eerie songs for you. This could have been helped by a wind shield.
4)City signal-to-signal commute can make you feel the engine heat through your trousers. But so did the HD or the CB1000 I rode.
5) The Aquila has a good range of torque through all the RPM range, but I wished it was better in the "Mid-range", so that shifting gears in the city traffic wouldn't be so frequent .
Oh yes, in the 16,000 km stint , the radiator fan did fail once .Although there were no issues on the highway, once I entered the city, fortunately Pune, the engine heat started mounting. Had to use the "stop-and-go" solution. The fan was changed and thereafter the next 13000 km there was no problem.
Overall it was a very satisfying stint with my Aquila.
The bike is extremely VFM, still is a pleasure to ride.
I would recommend this bike to anybody who wants to put up long hauls comfortably and reliably.
The longest haul was 850 km in a day Mumbai-Hampi, without any undue fatigue.
I am retiring the Aquila from its service, it will however continue to stay with me.
I plan to purchase the Benelli GT 600 tourer, since it has what I need :
1) Strong mid-range torque 2) Softer suspension 3 ) Better ground clearance
4) DSK service 5) and an affordable price .
Will update you with the Benelli GT 600 experience.
