Re: Swift stuck in mud! Nothing will happen to the engine \ any other parts unless it is a regular practice to rev high.
If you are stuck in mud never ever try to rev the engine if the wheels are slipping, revving will only trap you more.
A better solution would be to reduce the tyre pressure 3-4 psi and use some strips method to get more traction. Sometimes moving the vehicle in a wavy forward-backward movement to slope the ends of the pit, climbing a gradual incline is far more easier than a sharp deep pit. Also control the car w/o over revving so that the wheels get more traction. Also removing the mud from the tyres, by not using much water will also help.
