Old 25th November 2005, 20:47   #1
viper's Avatar
Thanked: 20 Times
help with windows XP
Hi Guys,
I keep getting this error when I run Norton Win doctor 2005.
"C:\Program Files\Common Files\InstallShield\Professional\RunTime\10\00\Int el32\DotNetInstaller.exe" cannot access a necessary file, "mscoree.dll."
Have been getting this error from some time. Can anyone here help me on how to solve/get rid of this problem.
Viper
viper is offline
Old 25th November 2005, 21:31   #2
jkdas's Avatar
Thanked: 1,496 Times
No worries mate. read this:
Problem
Missing File: "C:\Program Files\Common Files\InstallShield\Professional\Run Time\0700\Intel32\DotNetInstaller.exe" cannot access a necessary file, "mscoree.dll".
More Information
You received this error message after running a diagnostic scan using antivirus software, such as Norton AntiVirus or Norton WinDoctor. Some diagnostic software recognizes DotNetInstaller.exe as a .NET application that depends on the .NET Framework and reports it. DotNetInstaller.exe is a .NET application that is used when an installation is installing .NET assemblies. InstallShield installs DotNetInstaller.exe as part of its engine files. DotNetInstaller.exe does not work on systems that do not have the .NET Framework, but the file is cached with the InstallShield engine files just in case it is needed in the future when the .NET Framework is installed. It is technically correct, but InstallShield always checks for the Framework before trying to use it. You can safely ignore this message.
Fix
This message can be safely ignored. However, if you do not want the message to appear, you must download and install the .NET Framework. As a forewarning, the .NET Framework is fairly large, approximately 20 MB.
Visit the Microsoft .NET Framework Redistributable 1.0 page and click on the Download link on the right.
In the File Download dialog, select Save.
Browse to the Desktop.
Click Save.
After the download is complete, go to your Desktop.
Double-click on the file dotnetredist.exe to start the .NET Framework file extraction.
Read and accept the license agreement.
In the dotnetfx.exe dialog, click Browse and select the Desktop.
After the file extraction is complete, go to your Desktop.
Double-click on the file dotnetfx.exe to start the .NET Framework Setup installation.
http://www.smartcomputing.com/messag...=&pg=51&uname=
ther! hope it helps.
jkdas is offline
Old 26th November 2005, 10:57   #3
viper's Avatar
Thanked: 20 Times
Hey JkDas,
Thanks a ton. Did what you suggested and voila problem gone.
Viper
viper is offline
Old 26th November 2005, 11:26   #4
jkdas's Avatar
you are welcome. love fixing bugs and stuff.
jkdas is offline
Old 26th November 2005, 14:26   #5
Sam Kapasi's Avatar
Thanked: 2,479 Times
I must say JK, I am terribly impressed.
Sam Kapasi is offline
Old 26th November 2005, 22:39   #6
kpzen's Avatar
Thanked: 1,882 Times
Hey JK.....
Great work.....Very well explained...
I believe computer is one heck an unreliable machine....I've seen comp engg trying to solve a monitor display problem and concluding with a faulty UPS problem....
Will buzz you next time if i'm in some computer problem..!!!!
kpzen is offline
