Re: Help & advice on constructing a basement Quote:
Originally Posted by nec2152 Hello dear folks,
Thoughts of what the usages and cons are for having a basement ?
Thanks ! |
I have done this in 2012 in Pune, by shifting the parking down by 5 feet from outside road level. This has to be in your building plan approved by PMC.
Please note that I am not an expert into construction and narrating my experience as a house owner only.
1. It worked well for us but cost went up as you need additional full RCC wall starting from the base foundation upto at-least 2 feet above the ground level in your plot. Drainage lines have to have drawn accordingly
2. In our case this was treated as a parking hence it was free of FSI however you need to build a ramp for it or provide for vehicle lift which increase cost further. The ramp design and implementation was tricky and required precise calculations execution and might not go correct in smaller plots where plinth is around 1000 sq feet
3. The level of the road outside, with current trend of putting in layers over layers of tar the road height goes increasing and could cause some water issues in future especially during torrential rains. One also needs to have a corner in the basement with a "sunk" where slope is given and the water in basement would accumulate and fitted with a pump so as to drain out the water
4. Check the termite level in your surroundings as they could easily get in
5. If you are planning to have large trees in your plot the roots could over period of time build pressure on the RCC wall of the basement.
6. In case you have lift planned then the pit of the lift would go even deeper and would have to be planned accordingly.
Overall I would not recommend the basement option purely from additional maintenance overhead point of view
Reason: Please avoid Quoting entire large post for short replies.
