Old 3rd March 2011, 16:02   #121
lohithrao's Avatar
Thanked: 226 Times
re: Recommended water purifier?
RO based water purifiers is amust for all who depend on borewell water, about 5+ears back the borewell water started to taste bad and thate when we asked for a demo from eureka forbes and the water looked more dangerous next moment we got the RO filter and been using it from then on...
hallik9, you can to to eureka forbes guys they will tranfer the AMC to your new purifier, that is if you pick ef product only we did the same.
Originally Posted by hallik9 View Post
Folks,
I have a Eureka forbes water purifier and have been using it for the last 2 years now.I also have an AMC which I purchased for 2 years till 2011 end.
Now that I have shifted to my new apartment(the water is pretty hard here),I've been thinking of changing to a RO based water purifier.
2 questions.
Will any showroom offer me an exchange for a new RO based purifier?
Which is the best purifier considering that the borewell water in my apartment is pretty hard?
lohithrao is offline
Old 7th March 2011, 10:15   #122
JMaruru's Avatar
Thanked: 426 Times
The Eureka Forbes sales guy did a check on the TDS for borewell and BWSSB supply, and it came out as 160 for borewell and 190 for BWSSB supply.
Would you still suggest RO based water purifier for these TDS levels?
JMaruru is offline
Old 10th March 2011, 09:45   #123
JMaruru's Avatar
Thanked: 426 Times
Re: High Radon in borewell water across B’lore
Originally Posted by carboy View Post
I think even the regular UV filter with activated Carbon would remove radon from drinking water.
However, Radon isn't good even in bathing water, since you would be inhaling it.
But they say, the radon gas will escape when you store it in overhead tank for couple of hours. This should mitigate the risk.
Has anyone got Zero B Emerald? It is a compact wall-mount RO based water purifier from ion exchange, competing with Kent Mineral RO.
Please share your experience.
JMaruru is offline
Old 26th March 2011, 14:52   #124
quadra's Avatar
Thanked: 68 Times
Can anyone help me with deciding between kent grand+ vs Aquaguard total sensa? They both are top of the line models.
Initial experience: (Pre-pre-sales)
Kent were quick to give a demo. Aquaguard have not even called up yet. I registered on their sites on the same day (one after the other).
Pointers (Need your help here)
> Price - 17k approx (for either of those)
> A.S.S - Kent comes with 1 year warranty. Next year onwards its 500 approx for a year of service. Aquaguard = no clue.
> Technology - Apart from only knowing the name of the technology (ro / uv / tds etc) i know absolutely nothing.
TDS controller = Configurable in Kent ~ Constant in AquaG.
Reverse flush (read it here) = N/a in Kent ~ No clue about AquaG.
Water availability in my apartment (It sucks)
No fresh water option in my apartment. They use tankers to fill it up in case govt decides to close the taps. Water is pumped to the massive tanks on the top.
TDS (Super bad)
Tap water = 950
Bisleri 20ltr container = 190 (same expression as above)
Help (I mean it)
What do you think should i do. Really confused here...
quadra is offline
Old 26th March 2011, 15:46   #125
JMaruru's Avatar
Thanked: 426 Times
TDS (Super bad)
Tap water = 950
Help (I mean it)
Even i am looking out for a purifier, but the TDS levels at our place is much better, like it is 160 with the borewell water and 190 with the corporation supply. The quoted TDS at your place is way too high, and i feel you have no other choice but RO based purifiers. And for RO, i feel Ion Exchange(Zero-B) and Kent are the best bets.
JMaruru is offline
Old 26th March 2011, 17:50   #126
quadra's Avatar
Thanked: 68 Times
Thanks JM. Is RO treatment sufficient to make the tap water (remember 950 TDS) fit for drinking? really doubt that.
Is it just the TDS that i should be worried about? Arent there other things like lead, chemicals, bacteria etc etc in water?
quadra is offline
Old 26th March 2011, 18:09   #127
JMaruru's Avatar
Thanked: 426 Times
Yes, Indeed. But most of these RO Based purifiers have additional stages of filtration to take care of these. If i recall correctly, Kent Grand n Zero-B Pristine has some 6 - 7 stages of filtration. TDS, anything above 400, they say RO membrane based filters are the only bet. You can call these guys for live demo at home, and check the TDS after filtration.
JMaruru is offline
Old 26th March 2011, 21:27   #128
quadra's Avatar
Thanked: 68 Times
Thats what i think as well. Are you using any purifier?
quadra is offline
Old 26th March 2011, 22:22   #129
JMaruru's Avatar
Thanked: 426 Times
Right now, just the good old butterfly candle based water filter. I might go in for one of the UV based water purifiers, coz TDS levels does not warrant a RO based one.
JMaruru is offline
Old 26th March 2011, 22:55   #130
lohithrao's Avatar
Thanked: 226 Times
Am not sure if its safe or notbut am sure the water would taste a lot better with the RO.
Old 27th April 2011, 14:38   #131
rohan_iitr's Avatar
Thanked: 853 Times
Help (I mean it)
Which one did you purchase ? Please mention the prices also.
I am also in a similar situation right now. I need to purchase a water purifier. I am looking at RO+UV+UF+TDS controller models.
I find the Kent Pearl model to be aesthetically better than Kent Grand+. They both offer the same features.
Rohan
rohan_iitr is offline
Old 27th April 2011, 15:07   #132
Thanked: 32 Times
Morph water purifiers - I came across this company's ad recently and opted for a demo of their RO purifier. They seems to be quiet competitive to Kent and Aquagaurd. This company is based out of chennai and bangalore. They had an impressive clientele list. Moreover they have purifiers for industrial use as well. They follow aquagaurd type sales and service model.
The aquagaurd RO model that I have demand replacement of the RO membrane every year and the AMC for this comes to Rs3500. I believe that higher the TDS, the higher the chance that the membrane gets clogged and needs replacement. Pay attention to the AMC aspect of the purifier as well.
rajakumar is offline
Old 27th April 2011, 15:13   #133
anujmishra's Avatar
Thanked: 529 Times
For past 1 and half year, I am using EcoCrystal RO water purifier in my apartment. In our area TDS is around 450 - 500 range and this water purifier is doing great job without any issue.
Best part is EcoCrystal guys are not money centric like Kent, Aquaguard etc for AMC contract. This is their biggest source of money and replace the parts even it is working. Yes, in the name of hygiene and this is the point where everyone get scare and always gives consent to replace and heavy amount AMC.
I have their 7 Stage water purification system installed at my home with auxiliary 8 liters of pressure storage tank.
Their products are on display in Cosmos Mall and Forum Value Mall in Whitefield. I must say I am satisfied customer of EcoCrystal RO water purifier. Here is website address "Eco Crystal,Water treatment with environmental friendly technology.".
anujmishra is offline
Old 1st May 2011, 18:22   #134
JMaruru's Avatar
Thanked: 426 Times
Could you please let me know about the model you opted for, and also the cost of the same?
JMaruru is offline
Old 1st May 2011, 20:10   #135
anujmishra's Avatar
Thanked: 529 Times
I have their RO Elite version installed at home.
