Old 6th June 2023, 13:57   #1141
saket77's Avatar
Thanked: 14,706 Times
Re: Recommended water purifier?
Originally Posted by AltoLXI View Post
The input reading was 700 TDS and output was 20 TDS before filter change today. Very low TDS and technician told it would result in depletion of essential minerals. The optimum should be around 100.
Originally Posted by huntrz View Post
TDS is increased by mixing unfiltered water in small proportion. Too much of it can again lead to same issues as unfiltered water.
I think member huntrz is correct. If you analyse the flow of water filtration process in Kent RO, you will notice that the TDS controller screw adds/ reduces unfiltered water to the output just before the collection tank. Which I think is a weird way to control TDS. I tested the TDS level day before yesterday on my Kent and it came to be 40 ppm. As a time-pass activity, I tested the TDS of my AC condensate and it was 32.
saket77 is offline   (1) Thanks
Old 7th June 2023, 11:41   #1142
Thanked: 417 Times
We have an Aquaguard classic. AMC is always renewed in a timely manner through the app. This is more than sufficient for us.
Once a random guy showed up claiming to be from aquaguard, installed cheap candles & took AMC Cheque, found out later that it was a bogus company which dupes people. Complained to Aquaguard & they said their employees will always have a virtual visiting card, they'll send an sms before visiting.
montsa007 is offline   (1) Thanks
Old 15th September 2023, 21:25   #1143
Thanked: 24 Times
In the market for a Water purifier. I think we get Desalinated municipal water in our area Adyar, Chennai.
I checked the TDS and it varies between 400 to 450. Even our bore water has a TDS of around 450.
I have a doubt, Arent desalination plants basically large-scale RO plants. Do I need an RO at home or a UV+UF is enough?
I have been using a Kent UV,UF all these years but at a different location.
n.arun01 is offline
Old 16th September 2023, 10:31   #1144
Thanked: 3,001 Times
Yes,desalination plants are usually RO based now a days. The output TDS of an RO plant can be tailored to suit end user requirement, so 450 TDS is not surprising. This level of TDS will put a very light load on the plant, so it will work efficiently (less electricity, more water).
If you are fine with TDS of 450, then a filter+UV is sufficient, else go for RO based unit.
https://www.netsolwater.com/ro-in-re...n.php?blog=254
Aroy is offline   (1) Thanks
Old 30th September 2023, 20:00   #1145
rohan_iitr's Avatar
Thanked: 853 Times
I have a Kent RO+UV+UF purifier, which is just 1 year old.
In the last few days, I am observing that a very small amount of water keeps flowing from the outlet pipe even after the purifier is turned off.
Could it be something serious ? Should I call the service guys ? The purifier is anyway due for annual maintenance.
(The inlet water is very hard in our locality)
Rohan
rohan_iitr is offline
Old 1st October 2023, 10:49   #1146
Rohan
This is normaql. In an RO,waste water is thrown away. The amount depends on the hardness and TDS.
For Kent RO I suggest that you go for an AMC. Even though it is expensive, it is worthwhile as most parts are covered as is service. Only consumable (candles etc) are not.
Aroy is offline
Old 7th July 2024, 21:18   #1147
Thanked: 376 Times
I am in the market for a new water purifier. I had a subscription for livpure which I discontinued, since I felt the output TDS was lower than recommended (35), and the monthly subscription was high.
The input TDS (as shown by the aquaguard rep) is around 270. We have a full house Kent water softener.
I am confused on which one to go for and am looking for guidance. I prefer a stainless steel tank. The options with this are:
1. Aquaguard - comes with RO+UV+UF. It has a TDS controller, which basically mizes RO water with just UV filtered water to increase the output TDS. Not sure how good this is. It also has some copper cartridge, which I feel is gimmicky. Costs around 21K
2. LG - comes with RO+UF filter. The UC is in the tank, which I think is good. The cost is high @28K, and have read it's maintenance costs are high too.
3. If I am ok to overlook steel tank, Pureit has a RO+UF with UC in tank. Costs range between 16-20K.
How bad is a plastic tank?
Have heard output TDS should be ideally between 50-150. Is this possible without a tDS controller, the way aquaguard does it (by mixing non RO water)?.
Any suggestions in general which would suit my input TDS.
Bh.P is offline
Old 25th July 2024, 10:46   #1148
Thanked: 1,201 Times
Originally Posted by aravind.anand View Post
The V-Guard Zenora purifies input water with 500 TDS down to 60 TDS (as demonstrated by the installing technician) and the water tastes very neutral. Highly satisfied with the performance on this regard.
Would be helpful to know your thoughts regarding the product now. Thanks.
PS: Saw all your previous comments in this regard.
adisan is offline
Old 25th July 2024, 22:06   #1149
aravind.anand's Avatar
Thanked: 6,002 Times
I am very happy with the service V-Guard has been providing. They are usually prompt when we raise a ticket for any issues. the product is relatively quiet and trouble free too. I have never had an issue with the build quality or the taste of water we get from it.
Only concern I have is that it wastes about 3-4 times the amount of water that it gives us. Which I find to be on the higher side and feel bad for the environment. I now collect that and use it for secondary applications like mopping the house to make myself feel a bit better
aravind.anand is offline   (1) Thanks
Old 25th July 2024, 22:21   #1150
ashkamath's Avatar
Thanked: 3,559 Times
I have a Urban Company Native M2 water purifier in my home. Even this purifier wastes about 3-4 times the amount of water that gives us. I havent thought of using the discarded water. Time to use it for some house cleaning.
Regarding checking the TDS level in the water, I have purchased a KONVIO Neer TDS meter from Amazon which I use regularly to check the water TDS level. It's super useful and peaceful to the mind knowing that we are drinking safe water.
ashkamath is online now   (1) Thanks
Old 10th October 2024, 22:44   #1151
Thanked: 173 Times
Can anyone point me to a reliable online dealer for kent replacement cartriges? I have been buying from Amazon, but I feel many are selling fake products.
9216 is offline
Old 13th October 2024, 18:57   #1152
HTC
Thanked: 1,375 Times
I have a Kent pearl RO with 8 ltr storage tank. Last week, there was a spark near 3 pin plug. I took it to the nearest repair center. Though it said Kent and aquaguard service center, they had all refurbished adapters and I had to adamently ask for finding an adapter having exact same ampere and wattage. Else they will fit what ever they get their hands on. Costed me close to 1k. The purifier worked for 1 day and stopped swithing on. Took it again to same shop and they said the pump is gone and that is causing the adapter to blow. He said he has the parts and will repair. I refused, thanked him and came back.
Will book Kent service and see how much they quote. If anything above 3k, I Wil refuse and get a new one in range of 8k. RO service costs close to 6k every year. Simply not justified.
Attaching pump pic which the repair guy said is kaput.
HTC is offline
Old 13th December 2024, 15:35   #1153
Thanked: 743 Times
Are there any water purifiers in the market like Native M2 where you can track the filter usage and TDS levels on app? After 5 years of faithful service my Mi Water Purifier has conked off. I was looking at Native from Urban Company, but it's way to big to fit in the dedicated space we have, along with the pre-filter. Mi was so compact, fuss-free and sturdy.
So any other, tech advanced, water purifiers in the market you folks would like to recommend?
creative420 is offline
Old 13th December 2024, 16:48   #1154
saket77's Avatar
True. I replaced all filters and cartridges some time last year and it cost me north of 6K. I did it all by myself, so this includes only the cost of spares (OE). Else if I would take the service of technician, it will be easily 7K. Not justifiable by any means.
On the other hand, we just bought a new RO unit from Eureka Forbes for 9999/- inclusive of installation (Amazon). It has a TDS adjuster (like Kent Grand +). Need to see how much the spares cost for this one.
saket77 is offline
Old 13th December 2024, 18:21   #1155
tchsvy's Avatar
Thanked: 876 Times
Originally Posted by vinu_h View Post
Considering buying a water purifier. TDS where I live is near 700 but I am not interested in an RO. Anyone tried the brand Peore ? They claim to be able to function well w/o RO at high TDS levels ? Reviews are good on Amazon.
Have you bought it? and if you are using it, what is your experience with this purifier, I am in the same boat. I am fed up with Aquaguard RO purifier and their service in my area is pathetic.
tchsvy is offline
