HJC Hemlet and Honda CBR spares Honda CBR f2/f3 spares (got them from Canada):
EBS front and rear brake pads
Push-pull cables
Clutch cable
K&N oil filter
K&N air filter
4 NGK spark plugs
All the above for 12000. Ask for individual prices.
HJC CL15 Session Helmet:
The new CL-15 full-face Polycarbonate Composite helmet by HJC features aggressive shell sculpture, innovative features, and comfort. Simply everything you could want in a hyper-sport helmet.
Shell
Injection molded Thermoplastic shell construction which meets or exceeds SNELL M2005 & DOT standards.
Channeled, Dual density EPS (expanded poly-styrene) liner.
3 shell and four EPS sizes provide a comfortable fit for youth and adult sizes.
Flow-Through ACS
Advanced Channeling Ventilation System
Dual flow-through channels.
2 high capacity, multi-stage, forehead intake vents.
Venturi exhaust spoiler.
Anti-Fog System
Side chin bar mounted vortex vents create a low-pressure vacuum effect drawing heat and moisture out of the face shield area.
Adjustable chin vent re-directs air upward and across shield interior.
Anti-Fog treated 3D shield.
Next Generation, 2 Stage Compression Shield Closure System
A two-stage pivot mechanism, compresses the shield into the eye port gasket providing an extremely secure seal.
Improved, no guess work, tool-less shield removal and installation.
Aerodynamic flush mounted fit for reduced turbulence.
Scratch resistant hard coated shield.
Optically superior 3D design.
Rated at 95% UV resistant.
Removable/Washable Bioceramic Nylexฎ Interior
Anti-bacterial Bioceramic Nylexฎ liner and cheek pads quickly wick moisture away from the skin and eliminate odor causing bacteria.
Streamline, wrap-around neck roll reduces wind noise.
Padded chin strap design.
Nylon strap retention snap neatly secures excess chin strap.
Soft Helmet Storage Bag included.
Built-in Communication System Speaker Cavity.
Optional Mirrored RST, high definition (amber), smoke, and tear-off shields.
Brand new for Rs.8000. |
