Originally Posted by skumare Tried sending a PM and failed.
Please share the vendor details and costing via PM, I live in Miyapur and considering an on-grid unit on the roof-top. Thanks |
Don't see a PM option. I had a vendor contact for Tata from a friend who got it done recently but still decided to go to
https://www.tatapowersolar.com/contact-us/enquiries/ and send an enquiry.
They sent me contact for a different vendor than what my friend gave me, so looks like they have multiple vendors in the city. I decided to reach out to TATA instead of the Vendor directly hoping that they would intervene if you have a service issue with the vendor. However, they had the vendor reach out to me directly, so i don't know if they would have a record of me reaching out to them etc. No email Ack was received from TATA
The vendor working on mine is Kehan sri solar (I verified that they are a empanelled vendor from the list on TSSPDCL website). However, i am still not at the stage of recommending them since mine is still in approvals and i haven't seen their work on the ground yet. May be i will have full feedback in 2 months from now.
The vendor quoted slightly above 3L (Post subsidy - TS subsidy details in my prev post). I also heard from elsewhere that TATA was bumping prices this month and don't know if that is true. Also, reminder that subsidy is lower (20%) for the 4,5 and 6th KW (see my previous post) if this sounds expensive.
I believe you can do a 3KW system for way under 1.5L with an elevated (Super) structure
The following are included in the above price:
- 18 panels - 330/335Wp Tata panels (dimension: 2 mtr x 1 mtr)
- On grid Inverter (3 Phase)- Growatt is what they will deliver i think - single phase inverter is much cheaper and is used for 5KW and lower PV systems irrespective of whether you have a 3phase or single phase circuit at home. Frankly, to a layman end user, 3 phase or single phase does not matter. There is some technicality to using your own power vs exporting out and importing from the grid etc but a regular user need not care about that, the netmeter takes care of all that.
Some approx pricing here ==>
https://www.loomsolar.com/blogs/pric...price-in-india
- Elevated (Super) HDGI structure including all civil work - 6-7 ft elevation on south side. Cost will increase
- Lightening arrestor with separate earthing
- DC DB with separate earthing
- AC DB with separate earthing
- Earthing pit for the above
- DC cables
- AC cables
- Connectors and pvc ducting
- Application fees and net meter fees, processing, under the table processing
etc etc.
Follow the below steps if you want a head start and avoid some initial delay with the vendor processing all of this for you.
Step 1 -
Determine the size of system you will need based on your consumption each month for the last 12 months. I have 2 meters and have been maintaining a spreadsheet with all details for each month for the last 2-3 years so this was a piece of cake for me. Divide by 12 to get monthly average.
General assumption is 4 units of generation per day per 1KW. So a 5 KW system will generate 4x5 = 20 units per day or 600 units per month. Will be lower in rainy and higher when it is bright and sunny but should average out since excess units sent to the grid are carried forward and settled every 6 months and you will essentially consume them in summer months with air conditioning etc.
My avg consumption in 520 Units per month. I probably went a bit overboard when i decided to get a 6KW system but i tried to future proof a bit since this is supposed to be a 1 time thing and will supposedly last for 20+ years. Also had the following considerations:
- Might get electric vehicles in 2-3 yrs. eyeing a E scooter this or early next yr for sure. Car might come later, hoping battery tech will improve eventually and prices will go down.
- Will probably slowly move to induction stoves etc. and reduce LPG consumption.
- Average Consumption increases every year. Can't legally add more panels to the same system and the inverter and wiring size they will provide now cannot be upsized without additional investment even if you have them do structure for future panel addition.
- Power prices always increase and never decrease.
- Panel generation will degrade over time.
Worst case all of this won't happen and by strategy will backfire and ROI will be delayed. They claim ROI in 4-5 yrs right now but we'll see.
Step 2 -
Check Sanctioned/Contracted load of your current TSSPDCL connection. This detail is available on the bill. Mine was 1KW (Irrespective of what i am actually using in reality).
The contracted load should be equal or higher than the size of the system you are planning to get. TSSPDCL changes about 1400-1500 for each KW increase and it takes about a month for them to update the changes and slightly more for it to show up on the bill. Load increase can be requested from "Online New connection and Complaint Registration" section on TSSPDCL main page.
The vendor will follow up and help with the above process but they will charge you separately for the application fees or have you apply online and give them the registration number for follow-up.
All said and done, a system with a different brand panels etc might cost much less. I just went with TATA thinking like a typical Indian off course. Reliable Brand etc etc..
I saw videos like this that clearly show that Tata Panels are way more expensive than some of the other well know brands in the Solar space although i don't really believe TATA is putting in so much more quality into their product compared to any of them. I think they are just cashing in on their brand image and we knowingly fall for this
I know i have been lazy but if someone is ready to put in some time and money, i would recommend screwing the puny subsidy and its limitations and go for Mono perc half cut/bifacial panels etc. and a hybrid inverter. This allows you to be grid connected now but add batteries after a few years and go completely off grid if you wish to.
Haven't read or understood much about the agreements and legality of this with the distribution company but you can do you own research. And i don't really think the official inspecting will check and understand all this on the inverter if you do not put any batteries in his sight.
If you plan to stay on grid but prefer a more efficient system especially if your terrace is partially shaded at any point of time in the day, definitely look at micro inverters if you find a good installer who can do it end to end for you.
