Old 19th June 2022, 13:18   #151
Thanked: 2,377 Times
Re: Solar power! Turning my roof to a power plant
Originally Posted by skumare View Post
In the past eight days, my 3KW system @ Hyd is showing a peak generation of 2500..3000W (83% to 99.8% of installed capacity), a sudden departure
Hi SK, just a quick question. What is the generation capacity % during cloudy weather or when the panel is not under direct sunlight (e. g. shadow on panels)?
ajayc123 is offline   (1) Thanks
Old 19th June 2022, 13:27   #152
skumare's Avatar
Thanked: 154 Times
Currently, it is dark, raining in my location, generation is 250 to 500w. In general, I see that the generation from 16:30 to 18:00 varies between 600w to 200W (in a 3KW system with 9*330W poly panels), this is when the light starts to fade and a shadow is cast from an apartment complex in the vicinity.
In general, the system will be viable if you can have no (man-made) shadow from 9..10am to 3..4pm. Attached is a snapshot of generation on a typical summer day (Jun/07). It reaches 1000W by 9am and crosses it backwards at 4pm.
skumare is online now   (2) Thanks
Old 19th June 2022, 13:36   #153
And how much does a 3 kw setup cost? How much area is needed?
ajayc123 is offline
Old 19th June 2022, 13:49   #154
skumare's Avatar
Thanked: 154 Times
2L for a subsidized 3KW system incl elevated structure, each 330W panel is (2*1=) 2sqmt. For more details, pls refer the last 3..4 pages on this thread.
Old 19th June 2022, 15:21   #155
Durango Dude's Avatar
Thanked: 5,210 Times
Pardon my saying but I've vivid memories of a storm that hit Chennai in 2016 and it uprooted trees and must've damaged the solar panels too as the Sheet roofing on the terrace of some houses were just blown away. The structure anchoring the solar panels look rather flimsy will they be able to withstand gale force winds and storm. Just imagine after taking all the troubles of setting up the solar panel if storm blows it away: all that trouble, effort and money spent would really be "Gone with the wind"...
Durango Dude is offline
Old 19th June 2022, 19:42   #156
Captain Slow's Avatar
Thanked: 2,200 Times
Sorry if this post is not relevant -
I have started noticing some black marks/stains on our solar panels - Is this normal? The panels are close to a year old.
Are these panels getting damaged due to water/moisture buildup? Can this Cause the panels to degrade faster? I was told these panels have a 15-year warranty!
Name:  panel damage.jpg
Captain Slow is offline   (1) Thanks
Old 19th June 2022, 21:10   #157
Thanked: 2,512 Times
Who is the manufacturer of that panel. Is it on all the panels or just one panel. Is it on the positive side or the negative side, look under the panel. Also check the area where its become dark on the back side, to see if there is dark or black marks.
Causes for this could be many reasons moisture inside, PID( potential induced degradation), dust present on the corner caused it over heat.
aim120 is offline   (2) Thanks
Old 19th June 2022, 21:51   #158
These are waaree panels , I see these marks on all the panels towards the corners.
Its only on the top side of the panels. Will this cause any problems ? Can this spread ?
Old 19th June 2022, 22:36   #159
It can spread to more regions of the effected solar cells. But I doubt it will spread to another cell. But if this is due to PID, then it can effect more cells.
Its will certainly have a effect on panel output, these things are best diagnosed with a thermal imaging camera, which will show which cells is causing issues.
Old 19th June 2022, 23:48   #160
With so many problems with setting up and getting the solar panels, no wonder there hasn't been wide spread acceptance of this tech at least in India. It's maintenance intensive (more so than a car or bike that moves) God knows what substandard material we may be saddled with by the seller/contractor, whether the warranty will be honored or not or whether the seller/contractor will be around or just vanish. I'd rather have the regular electricity supply and have an inverter or a genset rather than this fickle thing from an unorganized sector with 0 credibility. Even inverter batteries need distilled water: the hybrid battery pack will also need this and battery will degrade with time and will need to be replaced say every 2-3 years and on top of it maintenance. And who is to clean the pigeon poo that most of our houses have?? In less than a month the whole panel will be splattered with pigeon poo.
Durango Dude is offline   (2) Thanks
Old 20th June 2022, 08:45   #161
deep_bang's Avatar
Thanked: 1,517 Times
In the past eight days, my 3KW system @ Hyd is showing a peak generation of 2500..3000W (83% to 99.8% of installed capacity), a sudden departure from the previous average high of 1800w? I guess the panels are washed in the rains and are more efficient in the cool climate, but want to confirm if others are also seeing the same kind of numbers.
On the same note, the total generation on Jun/15 was 25.3 units, while for the rest of the month so far the max is 15 units. I am wondering if this is a malfunction of the system or can a 3KW system generate 25 units on a day with clean panels, good light and cool climate?
My 3kw unit generates about 15 units with good sunlight. I live in Bangalore - so obviously we cannot compare apples to oranges here.
However, I do think there is some issue if your own system was earlier generating 15units and now generating 25. Do you have a meter that measures the output of the panels?
Also, it may be genuine too as the rains may have washed the panels. However, I always thought that the 3kw was like the ARAI mileage - and realistically I have only seen peaks of 2.7kw once in a while. 3kw on a 3kw system is possible, but not likely is my opinion. If your meter also verifies your numbers then I think it's good news for you
deep_bang is offline   (1) Thanks
Old 20th June 2022, 09:20   #162
jkrishnakj's Avatar
Thanked: 4,615 Times
Its been a year and many months since my installation and I have never bothered about the upkeep of the panels. Seems fine to me thus far. Is there some kind of preventive maintenance required?
jkrishnakj is offline   (2) Thanks
Old 20th June 2022, 10:13   #163
skumare's Avatar
Thanked: 154 Times
It happened only one day and now that I think about it, to generate 25units, it needs to be at 100% (3KW) capacity for 8hr, and the image for that day doesn't reflect that. Maybe a system malfunction. Rest of this month is fine and showing normal figures.
Old 20th June 2022, 10:32   #164
Thanked: 493 Times
Our installation of 5KW( grid-connected i.e without battery) is running fine for the last 8 years. There is a fear of the unknown and the hefty initial investment which keeps masses away from such installations. Over time, I have seen multiple installations coming up that are cleverly offsetting their ever-increasing electricity bills. A simple and small 3KW power unit on the rooftop can take care of all the power bills and even give back some money if there is a surplus( all this for around 2L at this juncture).
On the cleaning part, as the saying goes "No pain, No Gain", there are automatic cleaning sprinklers and cleaning equipment which make cleaning more or less easy.
I'm no affiliate with anyone. But this is one such investment which has given better returns than all LIC policies I ever had in my past
Now we have reached the breakeven point and getting positive returns for the next many years to come.
Swarup5 is offline   (5) Thanks
Old 20th June 2022, 13:44   #165
skumare's Avatar
Thanked: 154 Times
The volume is improving, albeit slowly.
For an on-grid system, it's zero maintenance except the occassional cleaning of panels, that too if you can't wait for the rains.
Tata, Adani, Luminous etc are the corporates who are offering end-to-end solutions, both on-grid and off-grid. The service credibility need to be ascertained,but so far, so good.
Exactly, if you have an off-grid system, you will need to top up the batteries like what we do for inverter batteries, nothing less, nothing more.
Overall, the technology is now mature and ready for mass deployment, the eco-system will improve as more of us adopt the same.
skumare is online now   (3) Thanks
