Old 5th January 2007, 14:05   #1
unknown's Avatar
Thanked: 23 Times
NFS CarBon won't start "NFSE.EXE has encontered a problem & need to close.....
Help, anybody with need for speed carbon when i try to play the game screen goes black than an error come up saying NFSC.exe has encountered a problem and needs to close. We are sorry for the inconvenience. What's the prblem ? I've No problem in running Nfswm .
unknown is offline
Old 5th January 2007, 14:40   #2
abhibh's Avatar
Thanked: 39 Times
Whats your system config. If you have less ram or processor speed game will crash. Same used to happen to me when i downloaded off the net and i thought i had downloaded corrupted 4GB file . Most probably this occurs due to processor speed not upto mark.
My config on which i play MW is:
Celeron 1.3 Mobile
512 MB RAM - 64MB for integrated graphics
Intel Extreme
Graphics settings medium in game.
abhibh is offline
Old 5th January 2007, 15:08   #3
unknown's Avatar
Thanked: 23 Times
Window Xp Sp2
Pentium-4 2.6 Ghz
376MB RAM
Intel 82845G/Gl !
I've no problem with Nfs most wanted runs smooth on above config..so i guess no problem with graphic card & ram & diect x .
unknown is offline
Old 5th January 2007, 15:12   #4
abhibh's Avatar
Thanked: 39 Times
The problem is ram. GFX is ok as my friend with 2GHZ, intel extreme plays the game smooth. Try running the EasyInfo program supplied with Carbon. It can be found in Start menu items..
abhibh is offline
Old 5th January 2007, 15:54   #5
esteem_lover's Avatar
Thanked: 513 Times
Your exe file could be corrupted. If your copy is genuine, try to find another exe file from a friend/foe, copy that into your installation folder & run that.
esteem_lover is offline
Old 5th January 2007, 16:30   #6
unknown's Avatar
Thanked: 23 Times
I've download off net :( Didn't bought .
unknown is offline
Old 5th January 2007, 21:34   #7
Thanked: 19 Times
I had faced same problem, try to install with another Dvd or replace NFSE.EXE
Mugen.
Mugen_Power is offline
Old 5th January 2007, 22:36   #8
unknown's Avatar
Thanked: 23 Times
Mugen.
It's a bug in game ? Is it compulsory to have 512 mb ram ?
unknown is offline
Old 5th January 2007, 23:04   #9
Thanked: 19 Times
You must have more than 512mb Ram.
Why dont you check your system with Easy info which is installed with the game.
Mugen.
Old 6th January 2007, 12:44   #10
unknown's Avatar
Thanked: 23 Times
Mugen.
Yes i did it shows Ram problem & Video card ,But i had no problem in running Nfs mw which require 256 ram to run so i guess have to upgrade ram....Have to replace video card also ?
unknown is offline
Old 6th January 2007, 17:12   #11
boybandreject's Avatar
^ Nfs:Carbon is very VERY fussy about video card requirements. Try your game on someone else's pc...preferable with a gfx card older than the geforce 5 series or the ati radeon 9500 series ...
If it works,its your gfx card that isnt supported. IF it doesnt,then your download must have gotten a corrupted file somewhere.
boybandreject is offline
Old 6th January 2007, 20:28   #12
unknown's Avatar
Thanked: 23 Times
Can any way of increasing Display memory to 64mb ? Currently allocated 8mb i not getting option to increae or it's need a video card ?
unknown is offline
Old 6th January 2007, 20:39   #13
abhibh's Avatar
Thanked: 39 Times
You can in crease it via going into bios. but as you say Most wanted works then then it automatically increases when you start playing the game. Same is with my laptop. It shows 496MB of RAM.. but Most wanted requires 64MB Video ram so i think it automatically increases.
abhibh is offline
Old 6th January 2007, 21:19   #14
pawan's Avatar
the problem is because of the graphic card i had the same problem it requires i had the same problem but when i changed the card it worked.
pawan is offline
Old 7th January 2007, 13:03   #15
unknown's Avatar
Thanked: 23 Times
After updating still unable to run :(
So i guess have to upgrade my graphic card .
unknown is offline
