1:72 Lockheed Martin F-35A Lightning II 32-05/MM7336 XIII Gruppo (13th Squadron) CACCIA (Hunting) / 32 Stormo ( Wing), Aeronautica Militare (Italian Air Force)
The Lockheed Martin F-35 Lightning II is a family of single-seat, single-engine, all-weather, stealth, fifth-generation, multirole combat aircraft, designed for ground-attack and air-superiority missions.
Specifications Lockheed Martin F-35 Lightning II
Role Multi-role stealth fighter
First Flight December 16, 2006
Crew 1
Powerplant 1 x Pratt & Whitney F135-PW-100, 40,000 lbs thrust with afterburner,25,000 lbs without.
Internal Fuel Capacity - 18,250 lbs (8,278 kg)
Weights
Empty 29,300 lbs (13,000 kg)
Maximum 70,000 lbs (31,800 kg)
Dimensions
Length 51.4 ft (15.7 m)
Wingspan 35 ft (10.7 m)
Height 14.4 ft (4.38 m)
Performance
Speed with full internal weapons load Mach 1.6
Combat Radius with internal fuel 590 nm (1,093 km)
Range with internal fuel 1,200 nm (2,200 km)
Weapons (Standard Internal)
1 x 25 mm GAU-22/A cannon
2 x AIM-120C air-to-air missiles
2 x 2,000 pound GBU-31 JDAM guided bombs
6 Χ external pylons on wings with a capacity of 15,000 lb (6,800 kg)
The F-35 has three main models: the conventional takeoff and landing F-35A (CTOL), the short take-off and vertical-landing F-35B (STOVL), and the catapult-assisted take-off but arrested recovery, carrier-based F-35C (CATOBAR). The F-35 descends from the Lockheed Martin X-35, the design that was awarded the Joint Strike Fighter (JSF) program over the competing Boeing X-32. The official Lightning II name has proven deeply unpopular and USAF pilots have nicknamed it Panther, instead. The F-35A is the only model equipped with an internal cannon on the port side. The F-35B & C can carry a gunpod on the centerline station. In USAF service, the F-35A is intended to replace the F-16 and A-10.
The Italian Air Force's 13th Squadron is equipped with the Lockheed Martin F-35A Lightning II.
On June 24, 2017 an event was held marking the 100th Anniversary of five of Italys most noted combat squadrons. Four of the five are equipped with the Eurofighter Typhoon while the fifth is the XIII Gruppo (13th Squadron) CACCIA (Hunting) / 32 (Stormo) Wing and Italys first unit equipped with the F-35A Lightning II. For the occasion F-35As MM7336/32-05 and the MM7357/32-07 were given special markings on the port side tail only. It depicts Don Quixote, the number 100 and the dates 1917-2017. These F-35As were built at Plant Cameri FACO.
Italy is the second largest JSF contributing partner after the UK. In October 2008, the Italian government outlined a requirement for 131 F-35s for the Aeronautica Militare( Air Force) and Marina Militare(Navy), consisting of 69 F-35As and 62 F-35Bs.Under this plan the Italian Navy would have received 22 F-35Bs while the Air Force would get 69 F-35A and 40 F-35B STOVL version aircraft. In 2012,Italy became the first country to announce a reduction of its overall fleet procurement, cutting its buy from 131 to 90 aircraft
One of the partners of the F-35 development, Turkey, was kicked out of the F-35 programme recently. On 17 July 2019, following the delivery of Russian S-400 air defence systems, the United States announced that Turkey would be removed from the F-35 programme. Besides the ban on training of pilots and delivery of the aircraft, the move also included removal of Turkey from the supply chain.
The F-35s Electro-Optical Targeting System (EOTS), a sensor complex housed beneath the aircrafts nose and designed as a stealthy alternative to external sensor pods. The EOTS features short-wave infrared imaging, high-definition television feed, improved range+resolution and an infrared pointer.
The canopy can be set in the open position
The cockpit detailing - a great feature of HM models.
Special markings on the port side tail. It depicts Don Quixote, the number 100 with years 1917-2017(100th Anniversary of 13th Gruppo) and a high viz Italian AF finflash.
The Internal Loadout: 2X AIM-120 AMRAAM, 2 X GBU-31 GPS guided bombs
Optional External weapons [ 2 X AIM-9X, 8 X GBU-38s( bombs mounted on Twin Ejector Racks)] are available to be mounted on the wings, but I prefer the clean, stealthy look.
The F-35A is armed with a GAU-22/A, a four-barrel version of the 25 mm GAU-12 Equalizer cannon. The cannon is mounted internally with 182 rounds for the F-35A or in an external pod with 220 rounds for the F-35B and F-35C.
How the internal gun works on the F-35:
With the Hogan 1:200 F-35B
F-35A 32-05/MM7336
There was an old PC flight sim from the late 1990s titled "JSF (Joint Strike Fighter)" by Eidos Interactive, which let you fly the Lockheed Martin X-35 & Boeing X-32 and it was the only flight sim that was ever developed based on the F-35 . I still have the CD but it does not work on Windows 7 or higher. I had hours of fun flying that very dark themed flight sim. So the the F-35 models hold a special place in my heart.
