FEAR THE BONES,BABY!!! ![Scale Models - Aircraft, Battle Tanks & Ships-vf84_jolly_rogers_tomcat_tail.jpg](https://www.team-bhp.com/forum/attachments/shifting-gears/1920218d1688418575t-scale-models-aircraft-battle-tanks-ships-vf84_jolly_rogers_tomcat_tail.jpg)
VF-84 "Jolly Rogers"
Callsign: VICTORY
1 July 1955 - 1 October 1995
Most Tomcat fans would immediately point to VF-84 as the most recognised Tomcat Squadron ever. The famed Jolly Rogers have always displayed some of the most recognizable squadron markings in the world in the form of sinister white skull-and-crossbones on all black tails, with gold bands wrapped around the tip of the tail fins, and black bands with gold chevrons (known as vagabonds strips from the F-8 Crusader days of VF-84) run down the sides of the forward fuselage.
Flying over nine different types of fighter aircraft in the past 63 years, the Skull and Crossbones have become the most recognized insignia in the world.The unit’s mascot is a set of skull and crossbones enclosed in a glass encasement that supposedly are the remains of Ensign Jack Ernie of VF-17. Ernie died during Okinawa invasion in World War II while fighting against two Japanese Zeroes with his Corsair losing engine oil. Before
crashing in his flaming aircraft he made two transmissions; “Skipper, I can’t get out!” followed by a short pause and then, “Remember me with the Jolly Rogers!” His family later presented the squadron with the set of skull and crossbones and asked the squadron to fulfill Ernie’s last wish: from that moment, “Passing of the bones” from the outgoing skipper to the incoming one was a time-honored Jolly Rogers tradition.
In 1975, the VF-84 Jolly Rogers transitioned to the F-14A Tomcat from the F-4B Phantom. Much before the movie Top Gun, there was a movie centered around the Tomcat called "The Final Countdown". In 1980 VF-84 participated in the motion picture The Final Countdown which propelled the skull and-crossbones-adorned F-14’s to international stardom. The movie featured a memorable scene involving two VF-84 Tomcats engaging two Japanese A6M Zeroes. In the mid-90s, VF-84 Tomcats made a memorable appearance in yet another motion picture--Executive Decision. Following VF-84’s decommissioning in October 1995, the decision was made to retire the “Club and Cloverleaf” insignia of the VF-103 “Sluggers” and have Fighting 103 adopt the Jolly Roger insignia and the Tactical callsign, “Victory”
1:72 Hobby Master F-14A Tomcat VF-84 "Jolly Rogers" USS Nimitz 1986
A diecast metal Tomcat in 1:72 scale was something I had been wanting for a long time, getting it in VF-84 markings was an additional bonus. Quality wise this is became my favourite model from my collection. the IAF Su-30 falls to second place because of JC's slightly inferior build quality.
Grumman F-14A Tomcat 160406 c/n 207 was assigned to VF-84 “Jolly Rogers” on December 30,1986 when the squadron sailed from Norfolk Virginia aboard the USS Nimitz. The deployment would entail a cruise to the Mediterranean then navigating Cape Horn on its way to a new home for the Nimitz in Bremerton, Washington. The deployment for the USS Nimitz lasted until July 1987. Off the coast of San Diego the aircraft aboard Nimitz, including VF-84 launched and returned to their home bases. On June 7, 1999 160406 was sent to AMARC for storage.
Specifications for the Grumman F-14A Tomcat
Role - Carrier-based multi-role strike fighter
First Flight – 1970
Last Production Year – F-14D July 20, 1992
Number All Variants Produced – 710
Crew - 2 (pilot and radar intercept officer).
Dimensions
Length 62 ft 8 inches
Wingspan (Swept) 38 ft 2.5 inches
Wingspan (Unswept) 64 ft 1.5 inches
Height 16 ft
Performance
Powerplants: 2 x P&W TF-30-P414A
Maximum Thrust :34,154 lbs
Maximum Speed :Mach 2.38
Ceiling : 50,000+ ft
Range : 1,730 nm
Weight
Empty : 40,104 pounds
Maximum : 72,000 pounds
Armament
1 x M61A1 Vulcan 20mm cannon
Maximum Weight – 13,000 lbs. Of Combined Ordnance
Air-Air Missiles
6 AIM-7 Sparrows
4 AIM-9 Sidewinder
6 AIM-54 Phoenix
Air-To-Ground
MK-82 (500 lbs.)
4 MK-83 (1,000 lbs.)
4 MK-84 (2,000 lbs.)
MK-20 cluster bombs
4 GBU-10 LGB
GBU-12 MK-82 LGB
4 GBU-16 MK-83 LGB
4 GBU-24 MK-84 LGB
The thing I loved about HM models - the kind of attention to detailing. Even the control stick & cockpit has been modelled, Something which other brands don't do. Notice how the crew models also get yellow VF-84 helmets.
Note the AAX-1 TCS(TV Camera Set) of the Tomcat on the chin that has been removed and replaced with an aerodynamic cover. The AAX-1 helped pilots visually identify and track aircraft, up to a range of 60 miles (97 km) for large aircraft. The Tomcat's AN/AWG-9 radar and the AAX-1 are linked, allowing the one detector to follow the direction of the other. A dual infrared/optical detection system was adopted on the later F-14D. The Tomcat had different chin pods installed, depending on the year and variant.
The much maligned P&W TF30-P-414A engine. The TF30 was found to be ill-adapted, underpowered to the demands of air combat and was prone to compressor stalls at high angle of attack (AOA) if the throttles were moved aggressively. Because of the Tomcat's widely spaced engine nacelles, compressor stalls at high AOA were especially dangerous because they tended to produce asymmetric thrust that could send the Tomcat into an upright or inverted spin, from which recovery was very difficult. The A+/B & D Tomcat models came with 2 x GE F-110-GE-400 engines. These engines solved the reliability problems and provided nearly 30% more thrust, achieving a 1:1 dry thrust to weight ratio with a low fuel load.
In its classic Fleet Defender missile loadout : 6 X AIM-54 Phoenix, 2XAIM-9 Sidewinder
An optional TARPS pod has also been provided, which can be mounted in place of 2 AIM-54s.
F-14A Tomcat 160406 c/n 207 , as seen in VF-84 markings
The same aircraft as 104 flying with VF-32 "Swordsmen"
The chief antagonists in quite a few air clashes over Libya, Iran/Iraq and to some extent in Lebanon and the first Gulf War. Both were conceived as high speed interceptors, one became highly successful, the other did not. I believe the Soviets marketed the MiG-23 as the single engined equivalent of the F-14, something which the Arab Air Forces fell for,as Iran had acquired the F-14A by then. India acquired the MiG-23MF as a knee jerk reaction to PAF acquiring the F-16A/B, which gave the IAF its first R-23R equipped BVR aircraft (though the effectiveness of the MiG-23's BVR capabilities and reliability remain questionable).
VF-84 Tomcats in the movie Executive Decision
VF-84 Tomcats dogfighting IJN Zeroes(T-6 Harvards) in the movie Final Countdown
