1:72 Boeing AH-64E Apache Guardian ZV-4808, No. 125 Helicopter Squadron “Gladiators”, Indian Air Force (Hobbymaster)
The second ever Indian Air Force model by Hobbymaster and they have done a stunning job on this one.!!! The model, serial numbered ZV-4808 (15-4808, test serial N4808C) comes armed with 2 X Hydra Rocket Pods, 2 X AGM-114 Hellfire Quad Launcher & M230 cannon (all removable) and Stinger launch tubes on the stub wing edges(non-removable)).
**To anyone who has this model or buys it in the future - Get tweezers to fit tiny parts in the slots. Do not try to glue the antenna attachment that is supposed to be fixed to the starboard side on the tail boom. The model does not have any holes to plug it in. The connecting legs of the antenna simply will not stick on the tail boom and you might end up damaging the model paint if you use fevi-kwik.
Instead, use tiny bit of blue tack on the connecting 'legs' to gently "stick" it in place. Blue Tack does not damage the paint or leave behind any residue if you want to remove the antenna in the future. The "Echo" model Apache
The AH-64E Apache Guardian was originally designated AH-64D Block III in 2012 but because of its advanced capabilities compared to previous variants, it was re-designated and the E model & renamed as the Apache Guardian. Everything about the AH-64E is bigger and better or improved when compared to earlier variants. A large number of improvements are meant to protect the crew from guns up to 27 mm rounds as well as crash resistant seats. The AH-64E features improved digital connectivity, the Joint Tactical Information Distribution System, more powerful T700-GE-701D engines with upgraded face gear transmission to accommodate more power, capability to control unmanned aerial vehicles, full IFR navigation capability, and improved landing gear. New composite rotor blades.
Longbow Radar
The AN/APG-78 "Longbow" is a millimeter-wave fire-control Radar (FCR) target acquisition system and the Radar Frequency Interferometer (RFI), which are housed in a dome located above the main rotor. The radome's raised position enables target detection while the helicopter is behind obstacles (e.g. terrain, trees or buildings).
![Name: hid.jpg
Size: 43.7 KB](https://www.team-bhp.com/forum/attachments/shifting-gears/2255200d1641461793-scale-models-aircraft-battle-tanks-ships-hid.jpg)
The APG-78 is capable of simultaneously tracking up to 128 targets and engaging up to 16 at once; an attack can be initiated within 30 seconds. A radio modem integrated with the sensor suite allows data to be shared with ground units and other Apaches, allowing them to fire on targets detected by a single helicopter.
The updated AN/APG-78 radar for the AH-64E Guardian has overwater capabilities, potentially enabling naval strikes.
The Longbow radar is the most obvious distinguishing feature of an AH-64D & AH-64E from the AH-64A model. However, the Longbow radar is removable. In Afghanistan, and in the later years of the Iraq War, there were no armored vehicles for the radar to track, so it was convenient to remove the radars. So even if it hasn't got the Longbow radar on top, it might be an AH-64D or E, not necessarily an AH-64A.
Weapons
The AH-64E comes with a 30 mm M230 cannon with 1200 rounds of ammunition. It has 4 hardpoints on stub wings and can carry various missiles and/or Rocket Pods. The AH-64E can carry up to 16 AGM-114 Hellfire II anti-tank guided missiles. For self defense against hostile helicopters, the Apache Guardian can carry up to two AIM-9 Sidewinders or four AIM-92 Stingers or four Mistral air-to-air missiles. It can also carry two AGM-122 Sidearm air-to-ground anti-radiation missiles, that can target hostile radars. The gunship is often equipped with 19-shot pods with Hydra 70 unguided rockets. The helicopter can carry up to 4 of these pods.
With the Longbow fire control radar mounted, it gives the AH-64E the capability to fire AGM-114R Hellfire II anti-tank guided missiles in fire-and-forget mode. Without the Longbow radar, the Hellfire II missiles are launched in the line-of-sight/Optical Guidance mode. The radar can detect, classify and prioritize 12 targets simultaneously, and can see through the fog an smoke, that foils infra-red or TV sensors.
AH-64E & the Gladiators
No.125 Helicopter Sqdn "Gladiators" was the IAF's first dedicated Attack Helicopter Squadron and was commissioned on November 1, 1983 with the Mi-25 Hind being their mount. Later they received Mi-35s. The Gladiators are stationed at Pathankot AFS. On 3 September 2019, 8 AH-64Es were inducted into the Squadron at Pathankot.
India had ordered 22 Apache Guardians, with the last one arriving in June 2020. In the wake of the India-China border tension, a detachment of IAF Apaches from the Sqdn remain forward deployed near the India-China border. IAF Apaches are serial numbered ZV-4801 to ZV-4822.
In February 2020, India ordered 6 AH-64Es for the Indian Army Aviation to be delivered by 2023 and I hope they get delivered in standard Apache Army Olive Green paint scheme.
AH-64E Specifications Crew: Two (Pilot & Gunner)
Dimensions and weight
Length : 17.7 m
Main rotor diameter : 14.6 m
Height: 5 m
Weight (empty) : 5.17 Tons
Weight (maximum take off): 10.43 Tons
Engines : 2 x General Electric T700-GE-701D turboshafts
Engine power : 2 x 1 994 shp
Maximum speed : 300 km/h
Cruising speed : 275 km/h
Service ceiling : 6.4 km
Range : 476 km
Armament:
Cannon : 1 x M230 30 mm cannon (1200 rounds)
Missiles : 16 AGM-114L Hellfire II anti-tank missiles, 4 x AIM-92 Stingers, or 4 x Mistral, or 2 x AIM-9 Sidewinder air-to-air missiles, 2 x AGM-122 Sidearm anti-radiation missiles, 19-shot pods with Hydra 70 unguided rockets
Ride of the Valkyries - the three HM Apaches in my collection - AH-64D, WAH-64D & AH-64E
The real AH-64E ZV-4808
AH-64 Apache Launching Missiles at multiple targets in Iraq. DTV In-Cockpit Audio and Video. Desert Storm, Jan 22, 1991. 101st Airborne Division.
