Old 28th July 2024, 15:45   #2461
balenoed_'s Avatar
Thanked: 5,519 Times
Re: Home Construction / Makeover / Maintenance Thread
Originally Posted by vinvin View Post
Would like to hear feedback/advice in terms of things to keep in mind, if I were to proceed ahead in engaging them.
Thanks.
For a job of something like building an entire home, I would rather go with a known person or someone who has been refered by any of the friends/relatives and endorsed by them and also after inspecting their work. Like, to have a mutual connection with them instead of a total stranger.
balenoed_ is offline   (1) Thanks
Old 10th August 2024, 11:28   #2462
Thanked: 959 Times
Dear BHPians
Kindly suggest a good budget friendly 4G sim based CCTV camera for monitoring the construction of a house. This camera will be installed in the Delhi NCR region.
Thank you.
kushagra452 is offline
Old 26th August 2024, 14:20   #2463
Thanked: 3,672 Times
This is a strange one (kind of dumb too) but I am hoping someone else has faced this before and solved it.
The kitchen faucet in my rented apartment in Bengaluru (attached pic) has been leaking for the past few days. Now, at my parents place I would simply remove the spindle (cartridge) and pop in a new one.
But this model kind of has a weird setup (though it's ubiquitous in India as far as I can see) and I am not sure how to get the spindle off it. Checked for it on YouTube but couldn't find any similar faucet over there either.
I have been able to remove the cap on the handle and the screw inside it but got stuck at that point. Any insights appreciated.
Note: Not really looking forward to calling a plumber because he has already scammed me before and didn't show any shame when I called him out for it. Besides, this is something I regularly do at my parents place.
Home Construction / Makeover / Maintenance Thread-img_20240822_154349731_ae3.jpg
JithinR is offline
Old 26th August 2024, 14:54   #2464
sagarpadaki's Avatar
Thanked: 6,448 Times
Please share a photo of how it looks on the inside once you remove the chrome cap on the turning Knob.
Old 26th August 2024, 15:25   #2465
Thanked: 365 Times
Originally Posted by JithinR View Post
This is a strange one (kind of dumb too) but I am hoping someone else has faced this before and solved it...
Hope this helps -
null is offline   (3) Thanks
Old 27th August 2024, 02:04   #2466
Thad E Ginathom's Avatar
Thanked: 28,447 Times
Originally Posted by null View Post
Hope this helps
Except don't use wrenches or other steel objects to hit or apply force to the tap cover or any chromium-plated or polished surface! Use a piece of wood. Or use the wood to transmit the force from a heavier object.
Back in the day, taps had washers that were easy to replace (as long as one could turn off the water supply!) and leaks like the one shown were fixed by tightening the packing piece, or adding a bit of string underneath it and re-tightening.
Thad E Ginathom is offline
Old 27th August 2024, 10:29   #2467
Thanked: 604 Times
Hope this helps
Good. But he is wasting so much water. Better to keep an empty vessel or bucket while testing for leaks post or during repairs.
Capri89 is offline
Old 28th August 2024, 10:11   #2468
Thanked: 2,888 Times
Steps
. Pry the cap off
. Unscrew the bolt
. Using a soft hammer or wooden batten hit the bottom of the knob, rotating around it.
. Once the knob is taken out use a wrench to open up the "face", that is the part holding the washer.
. Change the washer and reassemble the tap.
NOTE if there is a play/backslash in the tap, then change the "face". It should not cost more than 100 at local plumbing store. Other wise
https://www.flipkart.com/jkc-jaguar-...mb43be047d6a18
https://www.amazon.in/Senkiddpro-Car.../dp/B0CBMDVDMM
Aroy is offline   (1) Thanks
Old 28th August 2024, 16:16   #2469
Thanked: 492 Times
Any recommendations for interior designers / contractors in Delhi?
cryptarchy is offline
Old 28th August 2024, 16:19   #2470
Thanked: 492 Times
Originally Posted by kushagra452 View Post
Dear BHPians
Thank you.
There are cloud storage based cameras from Philips and TP link. You can pair it with a Wi-Fi dongle.
cryptarchy is offline   (1) Thanks
Old 8th September 2024, 02:30   #2471
My wife is complaining about the heat. I have to listen, as it is affecting her health. Whether this is psychology or not I do not know: we have plenty of AC.
We have a small, mostly-single-floor house, with a studio flat on the terrace, about 1/3rd of the area. So that much is protected from direct-sun heating. The terrace surface itself it painted with heat-reflective paint. One can tell that it does do something, as I can quite easily walk or stand on it when I can't do the same on our plain-cement drive.
Whilst she would like to cover the terrace With a simple roof of some kind (maybe even thatch) or even solar electricity panels, we do not have the money for it. (I'd love to have solar electric: another year, maybe!)
So she is turning her attention to the inside. The ceiling surface. Line/cover it with something.
One room, our second bedroom and her "den" area, is all, so it would be small job. I'd like it to be DIY even.
All my life, I've been seeing expanded polystyrene (thermacol) stuck on ceilings. Easy and cheap, but not great in appearance, and looks old fairly quickly. I read about something harder called PUF. Don't really know what it is, is it the stuff they insulate fridges with? All I can find from google for PUF is external roofing components.
Any ideas? And where (Chennai) to buy?
Thad E Ginathom is offline   (1) Thanks
Old 8th September 2024, 07:43   #2472
Thanked: 365 Times
Any ideas?
One easy solution to reduce sun light hitting your roof is to use those green shade nets (the ones used in garden nurseries to control sunlight on saplings). You get them at different %age of light blocking. You can get them stitched to your required dimensions to cover the 2/3rds roof area and get it hung at 8-10 ft height (over the open roof area). This should help keep your rooms below cool.
Edit: it's better to extend it to cover the side walls (prevent direct sun light falling on the side walls - your south facing walls?) as well since they too heat up during the day and make the room feel hot.
null is offline   (2) Thanks
Old 8th September 2024, 10:24   #2473
Prowler's Avatar
Thanked: 1,393 Times
I searched in Indiamart for PUF insulation panels for False ceiling:
1. https://www.omkarpufinsulation.com/puf-slabs.html
2.https://www.indiamart.com/proddetail...109390888.html
It seems a bit expensive in the second link: Rs.310/- per sqft
We did POP fc more than a dozen years ago and it cost us less than a Rs.100/- per sq ft with installation. It was before the days of GST and many things attracted 5 % VAT.
Prowler is offline   (1) Thanks
Old 8th September 2024, 17:16   #2474
Thanks for that idea. There is also traditional thatch, or the metal sheeting used as sun shades (etc, including our car port).
I'm worried that it will blow away in the first substantial wind. I'm worried that, the more secure it is, the more of the house it might destroy when it blows away. I'm thinking cyclone stuff: it happens!
Yes, I've looked for similar stuff. I think we have to start asking around the tiles/building shops to see if they have any domestic equivalent.
Old 8th September 2024, 17:41   #2475
whitewing's Avatar
Thanked: 1,779 Times
Shade nets seem to be the best quick fix for your use case, a bunch of 10*10 nets anchored to sandbags on the terrace should do the trick and not pose a danger in high wind situations.
Alternately, if the terrace space area is not actively used, just laying a bunch of mangalore tiles (with ridges) may do the trick.
Adding insulation in the "inside" may not be such a good idea, since eventually the heat will get in and due to the added insulation,stay in longer.
whitewing is offline
